Hi guys i wanted to try zsh in terminal but the terminal prompt shows Zed% i know there are themes that i can install so i was thinking if there was a theme like manjaro bash because i like it that way please tell me if there is or something similar
Hi, in your ~/.zhrc, you should have the link towards the zsh manjaro config directory. You will find there some prompt examples you could try.
