Not sure what you mean by copy text only but here is what it gives for the first lines:
grub-probe: error: cannot find a GRUB drive for /dev/sdc1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/sdb2]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
--> mount: [/mnt/home/kaiba/Kiophen/]
The disk contains an unclean file system (0, 0).
Metadata kept in Windows cache, refused to mount.
Falling back to read-only mount because the NTFS partition is in an
unsafe state. Please resume and shutdown Windows fully (no hibernation
or fast restarting.)
--> mount: [/mnt/home/kaiba/Koopa/]
--> mount: [/mnt/home/kaiba/Yoshi/]
[manjaro /]# pacman -Syu
core is up to date
extra is up to date
community is up to date
multilib is up to date
warning: manjaro-hello: local (0.6.7-2) is newer than extra (0.6.6-9)
there is nothing to do
[manjaro /]# exit
exit
--> umount: [/mnt/home/kaiba/Yoshi/]
--> umount: [/mnt/home/kaiba/Koopa/]
--> umount: [/mnt/home/kaiba/Kiophen/]
--> umount: [/mnt/boot/efi]
--> umount: [/mnt]
And here are the logs, they are long but I dont want to exclude anything.
The audacity errors were from last night, they didnt seem to break the computer then so I don’t know if they’re relavent or not
Boot 1a9b111496ea42eb94040a7917b19dc4 (Sep 03 13:11) is the boot when I installed the updates, and then restarted the computer when the package manager prompted me to do so. The rest of the boots after that are me mostly just staring at htop for a few minutes and failing to be able to do anything else
[manjaro /]# journalctl -p3 --no-pager --since=yesterday
Journal file /var/log/journal/e63a35d9de9e4f87ba8906a9fbb7e3a8/user-1000@0005cb1b8e34dfd3-9fdd956711d42105.journal~ is truncated, ignoring file.
-- Journal begins at Mon 2021-04-05 22:46:32 CDT, ends at Fri 2021-09-03 17:17:18 CDT. --
Sep 02 00:50:24 kaiba-manjaro systemd-coredump[165073]: Failed to connect to coredump service: Connection refused
Sep 02 00:50:25 kaiba-manjaro systemd-coredump[165422]: Failed to connect to coredump service: Connection refused
Sep 02 00:50:25 kaiba-manjaro pulseaudio[165416]: Unable to subscribe to signals: org.freedesktop.DBus.Error.Disconnected: Connection is closed
Sep 02 00:50:25 kaiba-manjaro pulseaudio[165416]: Failed to load module "module-jackdbus-detect" (argument: "channels=2"): initialization failed.
Sep 02 00:50:25 kaiba-manjaro pulseaudio[165416]: Failed to acquire org.PulseAudio1: org.freedesktop.DBus.Error.Disconnected: Connection is closed
-- Boot bfc9b7b147ae4c0687b17d0ed165f73d --
Sep 02 13:05:00 kaiba-manjaro kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Sep 02 13:05:00 kaiba-manjaro kernel: sd 5:0:0:0: [sdc] No Caching mode page found
Sep 02 13:05:00 kaiba-manjaro kernel: sd 5:0:0:0: [sdc] Assuming drive cache: write through
Sep 02 13:05:00 kaiba-manjaro kernel: kvm: disabled by bios
Sep 02 13:05:01 kaiba-manjaro kernel: kvm: disabled by bios
Sep 02 13:11:51 kaiba-manjaro krita[3629]: Shortcut for action "preserve_alpha" "Preserve Alpha" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Sep 02 13:57:07 kaiba-manjaro pulseaudio[1427]: ALSA woke us up to write new data to the device, but there was actually nothing to write.
Sep 02 13:57:07 kaiba-manjaro pulseaudio[1427]: Most likely this is a bug in the ALSA driver 'snd_usb_audio'. Please report this issue to the ALSA developers.
Sep 02 13:57:07 kaiba-manjaro pulseaudio[1427]: We were woken up with POLLOUT set -- however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
Sep 02 18:00:22 kaiba-manjaro systemd-coredump[46051]: [LNK] Process 33351 (audacity) of user 1000 dumped core.
Stack trace of thread 33351:
#0 0x0000564168b32c6a _ZN6Effect7PreviewEb (audacity + 0x8e3c6a)
#1 0x00007f8610399dde _ZN12wxEvtHandler23ProcessEventIfMatchesIdERK21wxEventTableEntryBasePS_R7wxEvent (libwx_baseu-3.0.so.0 + 0x1dedde)
#2 0x00007f8610399edc _ZN16wxEventHashTable11HandleEventER7wxEventP12wxEvtHandler (libwx_baseu-3.0.so.0 + 0x1deedc)
#3 0x00007f861039a21e _ZN12wxEvtHandler11TryHereOnlyER7wxEvent (libwx_baseu-3.0.so.0 + 0x1df21e)
#4 0x00007f861039a2ac _ZN12wxEvtHandler19ProcessEventLocallyER7wxEvent (libwx_baseu-3.0.so.0 + 0x1df2ac)
#5 0x00007f861039a382 _ZN12wxEvtHandler12ProcessEventER7wxEvent (libwx_baseu-3.0.so.0 + 0x1df382)
#6 0x00007f86108f0cba _ZN12wxWindowBase8TryAfterER7wxEvent (libwx_gtk3u_core-3.0.so.0 + 0x45ecba)
#7 0x00007f86108f0cba _ZN12wxWindowBase8TryAfterER7wxEvent (libwx_gtk3u_core-3.0.so.0 + 0x45ecba)
#8 0x00007f86108f0cba _ZN12wxWindowBase8TryAfterER7wxEvent (libwx_gtk3u_core-3.0.so.0 + 0x45ecba)
#9 0x00007f861039a0d7 _ZN12wxEvtHandler18SafelyProcessEventER7wxEvent (libwx_baseu-3.0.so.0 + 0x1df0d7)
#10 0x00007f86107706f9 n/a (libwx_gtk3u_core-3.0.so.0 + 0x2de6f9)
#11 0x00007f860f639030 g_signal_emit_valist (libgobject-2.0.so.0 + 0x30030)
#12 0x00007f860f6391a0 g_signal_emit (libgobject-2.0.so.0 + 0x301a0)
#13 0x00007f860f870109 n/a (libgtk-3.so.0 + 0xc8109)
#14 0x00007f860f61bd8f g_closure_invoke (libgobject-2.0.so.0 + 0x12d8f)
#15 0x00007f860f6371cf n/a (libgobject-2.0.so.0 + 0x2e1cf)
#16 0x00007f860f638c49 g_signal_emit_valist (libgobject-2.0.so.0 + 0x2fc49)
#17 0x00007f860f6391a0 g_signal_emit (libgobject-2.0.so.0 + 0x301a0)
#18 0x00007f860f86fec1 n/a (libgtk-3.so.0 + 0xc7ec1)
#19 0x00007f860f82ea8b n/a (libgtk-3.so.0 + 0x86a8b)
#20 0x00007f860f639030 g_signal_emit_valist (libgobject-2.0.so.0 + 0x30030)
#21 0x00007f860f6391a0 g_signal_emit (libgobject-2.0.so.0 + 0x301a0)
#22 0x00007f860f93c31d n/a (libgtk-3.so.0 + 0x19431d)
#23 0x00007f860f6204ac g_cclosure_marshal_VOID__BOXEDv (libgobject-2.0.so.0 + 0x174ac)
#24 0x00007f860f639030 g_signal_emit_valist (libgobject-2.0.so.0 + 0x30030)
#25 0x00007f860f6391a0 g_signal_emit (libgobject-2.0.so.0 + 0x301a0)
#26 0x00007f860f933ba8 n/a (libgtk-3.so.0 + 0x18bba8)
#27 0x00007f860f93bb2b n/a (libgtk-3.so.0 + 0x193b2b)
#28 0x00007f860f93c764 n/a (libgtk-3.so.0 + 0x194764)
#29 0x00007f860f902783 gtk_event_controller_handle_event (libgtk-3.so.0 + 0x15a783)
#30 0x00007f860fada6af n/a (libgtk-3.so.0 + 0x3326af)
#31 0x00007f860f82cf0b n/a (libgtk-3.so.0 + 0x84f0b)
#32 0x00007f860f61bcc9 g_closure_invoke (libgobject-2.0.so.0 + 0x12cc9)
#33 0x00007f860f636f5e n/a (libgobject-2.0.so.0 + 0x2df5e)
#34 0x00007f860f63827b g_signal_emit_valist (libgobject-2.0.so.0 + 0x2f27b)
#35 0x00007f860f6391a0 g_signal_emit (libgobject-2.0.so.0 + 0x301a0)
#36 0x00007f860fae8ce5 n/a (libgtk-3.so.0 + 0x340ce5)
#37 0x00007f860f9869a5 n/a (libgtk-3.so.0 + 0x1de9a5)
#38 0x00007f860f9878c3 gtk_main_do_event (libgtk-3.so.0 + 0x1df8c3)
#39 0x00007f860f6e67f3 n/a (libgdk-3.so.0 + 0x3d7f3)
#40 0x00007f860f736614 n/a (libgdk-3.so.0 + 0x8d614)
#41 0x00007f860f52810c g_main_context_dispatch (libglib-2.0.so.0 + 0x5410c)
#42 0x00007f860f57bb99 n/a (libglib-2.0.so.0 + 0xa7b99)
#43 0x00007f860f527693 g_main_loop_run (libglib-2.0.so.0 + 0x53693)
#44 0x00007f860f97d85f gtk_main (libgtk-3.so.0 + 0x1d585f)
#45 0x00007f8610712b26 _ZN14wxGUIEventLoop5DoRunEv (libwx_gtk3u_core-3.0.so.0 + 0x280b26)
#46 0x00007f861027237e _ZN15wxEventLoopBase3RunEv (libwx_baseu-3.0.so.0 + 0xb737e)
#47 0x00007f861077c892 _ZN8wxDialog9ShowModalEv (libwx_gtk3u_core-3.0.so.0 + 0x2ea892)
#48 0x0000564168b261b6 _ZN6Effect13ShowInterfaceER8wxWindowRKSt8functionIFP8wxDialogS1_P19EffectHostInterfaceP23EffectUIClientInterfaceEEb (audacity + 0x8d71b6)
#49 0x0000564168b2fe3c _ZN6Effect8DoEffectEdP9TrackListP12TrackFactoryR23NotifyingSelectedRegionP8wxWindowRKSt8functionIFP8wxDialogRS6_P19EffectHostInterfaceP23EffectUIClientInterfaceEE (audacity + 0x8e0e3c)
#50 0x0000564168b45e22 _ZN8EffectUI8DoEffectERK8wxStringRK14CommandContextj (audacity + 0x8f6e22)
#51 0x0000564168a91c85 _ZN14CommandManager18HandleCommandEntryER15AudacityProjectPK16CommandListEntrySt6bitsetILm64EEbPK7wxEvent (audacity + 0x842c85)
#52 0x0000564168a96ac6 _ZN14CommandManager12HandleMenuIDER15AudacityProjectiSt6bitsetILm64EEb (audacity + 0x847ac6)
#53 0x00005641689cc9f0 _ZN13ProjectWindow6OnMenuER14wxCommandEvent (audacity + 0x77d9f0)
#54 0x00007f8610399dde _ZN12wxEvtHandler23ProcessEventIfMatchesIdERK21wxEventTableEntryBasePS_R7wxEvent (libwx_baseu-3.0.so.0 + 0x1dedde)
#55 0x00007f8610399edc _ZN16wxEventHashTable11HandleEventER7wxEventP12wxEvtHandler (libwx_baseu-3.0.so.0 + 0x1deedc)
#56 0x00007f861039a21e _ZN12wxEvtHandler11TryHereOnlyER7wxEvent (libwx_baseu-3.0.so.0 + 0x1df21e)
#57 0x00007f861039a093 _ZN12wxEvtHandler10DoTryChainER7wxEvent (libwx_baseu-3.0.so.0 + 0x1df093)
#58 0x00007f861039a382 _ZN12wxEvtHandler12ProcessEventER7wxEvent (libwx_baseu-3.0.so.0 + 0x1df382)
#59 0x00007f86108f0cba _ZN12wxWindowBase8TryAfterER7wxEvent (libwx_gtk3u_core-3.0.so.0 + 0x45ecba)
#60 0x00007f861039a0d7 _ZN12wxEvtHandler18SafelyProcessEventER7wxEvent (libwx_baseu-3.0.so.0 + 0x1df0d7)
#61 0x00007f86108a263f _ZN10wxMenuBase9SendEventEii (libwx_gtk3u_core-3.0.so.0 + 0x41063f)
#62 0x00007f8610796c20 n/a (libwx_gtk3u_core-3.0.so.0 + 0x304c20)
#63 0x00007f860f61bd8f g_closure_invoke (libgobject-2.0.so.0 + 0x12d8f)
Stack trace of thread 33369:
#0 0x00007f860eefca95 clock_nanosleep@@GLIBC_2.17 (libc.so.6 + 0xc6a95)
#1 0x00007f860ef01c77 __nanosleep (libc.so.6 + 0xcbc77)
#2 0x00007f861037362d _Z12wxMicroSleepm (libwx_baseu-3.0.so.0 + 0x1b862d)
#3 0x000056416887bd92 _ZN10MidiThread5EntryEv (audacity + 0x62cd92)
#4 0x00007f861036637a _ZN8wxThread9CallEntryEv (libwx_baseu-3.0.so.0 + 0x1ab37a)
#5 0x00007f861036eb79 n/a (libwx_baseu-3.0.so.0 + 0x1b3b79)
#6 0x00007f860f380259 start_thread (libpthread.so.0 + 0x9259)
#7 0x00007f860ef345e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 33352:
#0 0x00007f860ef29b2f __poll (libc.so.6 + 0xf3b2f)
#1 0x00007f860f57bb29 n/a (libglib-2.0.so.0 + 0xa7b29)
#2 0x00007f860f525871 g_main_context_iteration (libglib-2.0.so.0 + 0x51871)
#3 0x00007f860f5258c2 n/a (libglib-2.0.so.0 + 0x518c2)
#4 0x00007f860f5562c1 n/a (libglib-2.0.so.0 + 0x822c1)
#5 0x00007f860f380259 start_thread (libpthread.so.0 + 0x9259)
#6 0x00007f860ef345e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 33353:
#2 0x00007f860f527693 g_main_loop_run (libglib-2.0.so.0 + 0x53693)
#3 0x00007f860e8068c8 n/a (libgio-2.0.so.0 + 0x1018c8)
Stack trace of thread 33370:
#3 0x0000564168880500 _ZN11AudioThread5EntryEv (audacity + 0x631500)
Stack trace of thread 39633:
#3 0x00007f8608a51ebe n/a (libdconfsettings.so + 0x5ebe)
Sep 02 19:54:22 kaiba-manjaro systemd-coredump[58703]: [LNK] Process 58649 (services.exe) of user 1000 dumped core.
Stack trace of thread 58650:
#0 0x00007f34155ae3c7 n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x503c7)
#1 0x00007f34155ae833 n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x50833)
#2 0x00007f34157f6870 n/a (/usr/lib/libpthread-2.33.so + 0x13870)
Stack trace of thread 58653:
#0 0x00007f34157ec200 start_thread (/usr/lib/libpthread-2.33.so + 0x9200)
#1 0x00007f341570e5e3 __clone (/usr/lib/libc-2.33.so + 0xfe5e3)
Stack trace of thread 58649:
#0 0x00007f34157f56ff __write (/usr/lib/libpthread-2.33.so + 0x126ff)
#1 0x00007f34155a7644 n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x49644)
#2 0x00007f34155a7740 wine_server_call (/usr/lib/wine/x86_64-unix/ntdll.so + 0x49740)
#3 0x00007f341559c1ef NtTerminateProcess (/usr/lib/wine/x86_64-unix/ntdll.so + 0x3e1ef)
#4 0x00007f3415578e7d n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x1ae7d)
#5 0x0000000000000020 n/a (n/a + 0x0)
#6 0x0000000000000000 n/a (n/a + 0x0)
Sep 02 23:30:01 kaiba-manjaro systemd-coredump[101160]: [LNK] Process 96276 (srb2kart) of user 1000 dumped core.
Stack trace of thread 96276:
#0 0x0000561758013e28 n/a (srb2kart + 0x86e28)
#1 0x000056175801436e n/a (srb2kart + 0x8736e)
#2 0x0000561757fdba95 n/a (srb2kart + 0x4ea95)
#3 0x0000561757fe0cae n/a (srb2kart + 0x53cae)
#4 0x0000561757fe210d n/a (srb2kart + 0x5510d)
#5 0x0000561757ff6629 n/a (srb2kart + 0x69629)
#6 0x0000561757fe405f n/a (srb2kart + 0x5705f)
#7 0x0000561757fd5c24 n/a (srb2kart + 0x48c24)
#8 0x0000561757fd4d5c n/a (srb2kart + 0x47d5c)
#9 0x00007f626d739b25 __libc_start_main (libc.so.6 + 0x27b25)
#10 0x0000561757fd4dae n/a (srb2kart + 0x47dae)
Stack trace of thread 96306:
#0 0x00007f626d805c2e ppoll (libc.so.6 + 0xf3c2e)
#1 0x00007f6260059543 pa_mainloop_poll (libpulse.so.0 + 0x1d543)
#2 0x00007f6260063709 pa_mainloop_iterate (libpulse.so.0 + 0x27709)
#3 0x00007f62600637c1 pa_mainloop_run (libpulse.so.0 + 0x277c1)
#4 0x00007f626df68290 n/a (libSDL2-2.0.so.0 + 0xe0290)
#5 0x00007f626df00443 n/a (libSDL2-2.0.so.0 + 0x78443)
#6 0x00007f626dfa40ba n/a (libSDL2-2.0.so.0 + 0x11c0ba)
#7 0x00007f626d8e7259 start_thread (libpthread.so.0 + 0x9259)
#8 0x00007f626d8105e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 96288:
#0 0x00007f626d8f38ca __futex_abstimed_wait_common64 (libpthread.so.0 + 0x158ca)
#1 0x00007f626d8ed270 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf270)
#2 0x00007f6269f3653c n/a (radeonsi_dri.so + 0x1c653c)
#3 0x00007f6269f30598 n/a (radeonsi_dri.so + 0x1c0598)
#4 0x00007f626d8e7259 start_thread (libpthread.so.0 + 0x9259)
#5 0x00007f626d8105e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 96307:
#3 0x00007f626df67f87 n/a (libSDL2-2.0.so.0 + 0xdff87)
#4 0x00007f626deabbb6 n/a (libSDL2-2.0.so.0 + 0x23bb6)
Stack trace of thread 96277:
Stack trace of thread 96286:
Stack trace of thread 96279:
Stack trace of thread 96285:
Stack trace of thread 96278:
Stack trace of thread 96280:
Stack trace of thread 96281:
Stack trace of thread 96283:
Stack trace of thread 96284:
Stack trace of thread 96282:
Stack trace of thread 96289:
Stack trace of thread 96291:
Stack trace of thread 96287:
Stack trace of thread 96292:
Stack trace of thread 96290:
Stack trace of thread 96298:
Stack trace of thread 96294:
Stack trace of thread 96293:
Sep 03 00:50:23 kaiba-manjaro systemd-coredump[122777]: Failed to connect to coredump service: Connection refused
-- Boot 1a9b111496ea42eb94040a7917b19dc4 --
Sep 03 13:11:16 kaiba-manjaro kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Sep 03 13:11:16 kaiba-manjaro kernel: kvm: disabled by bios
Sep 03 13:11:16 kaiba-manjaro kernel: sd 5:0:0:0: [sdc] No Caching mode page found
Sep 03 13:11:16 kaiba-manjaro kernel: sd 5:0:0:0: [sdc] Assuming drive cache: write through
Sep 03 13:11:17 kaiba-manjaro kernel: kvm: disabled by bios
Sep 03 13:15:33 kaiba-manjaro systemd-coredump[7488]: Failed to connect to coredump service: Connection refused
Sep 03 13:15:34 kaiba-manjaro systemd-coredump[7779]: Failed to connect to coredump service: Connection refused
Sep 03 13:15:34 kaiba-manjaro pulseaudio[7775]: Unable to subscribe to signals: org.freedesktop.DBus.Error.Disconnected: Connection was disconnected before a reply was received
Sep 03 13:15:34 kaiba-manjaro pulseaudio[7775]: Failed to load module "module-jackdbus-detect" (argument: "channels=2"): initialization failed.
Sep 03 13:15:34 kaiba-manjaro pulseaudio[7775]: Failed to acquire org.PulseAudio1: org.freedesktop.DBus.Error.Disconnected: Connection is closed
-- Boot d1fc39c536f74deeb1fd2aae4fc34fe4 --
Sep 03 13:15:59 kaiba-manjaro kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Sep 03 13:15:59 kaiba-manjaro kernel: usb 3-6.1: device descriptor read/64, error -32
Sep 03 13:15:59 kaiba-manjaro kernel: sd 5:0:0:0: [sdc] No Caching mode page found
Sep 03 13:15:59 kaiba-manjaro kernel: sd 5:0:0:0: [sdc] Assuming drive cache: write through
Sep 03 13:15:59 kaiba-manjaro kernel: kvm: disabled by bios
Sep 03 13:16:00 kaiba-manjaro kernel: kvm: disabled by bios
Sep 03 13:16:00 kaiba-manjaro kernel: usb 3-6.1: device descriptor read/64, error -32
Sep 03 13:16:01 kaiba-manjaro kernel: usb 3-6.1: device not accepting address 7, error -71
Sep 03 13:16:01 kaiba-manjaro kernel: usb 3-6.1: device not accepting address 8, error -71
Sep 03 13:16:01 kaiba-manjaro kernel: usb 3-6-port1: unable to enumerate USB device
-- Boot b991578da66546b286fbeceb672701ee --
Sep 03 13:21:33 kaiba-manjaro kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Sep 03 13:21:33 kaiba-manjaro kernel: sd 5:0:0:0: [sdc] No Caching mode page found
Sep 03 13:21:33 kaiba-manjaro kernel: sd 5:0:0:0: [sdc] Assuming drive cache: write through
Sep 03 13:21:33 kaiba-manjaro kernel: kvm: disabled by bios
Sep 03 13:21:34 kaiba-manjaro kernel: kvm: disabled by bios
Sep 03 13:21:35 kaiba-manjaro kernel: kvm: disabled by bios
Sep 03 13:21:38 kaiba-manjaro kernel: [drm:dmub_abm_init_config [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:21:40 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:21:41 kaiba-manjaro kernel: [drm:set_pixel_clock_v7 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:21:41 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:21:42 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:21:43 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:21:44 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:21:45 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:21:46 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:21:47 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:21:48 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:21:49 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:21:50 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:21:51 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
-- Boot de2c3c3ce4b344d5a035c6f26da9c7ba --
Sep 03 13:31:32 kaiba-manjaro kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Sep 03 13:31:32 kaiba-manjaro kernel: sd 5:0:0:0: [sdc] No Caching mode page found
Sep 03 13:31:32 kaiba-manjaro kernel: sd 5:0:0:0: [sdc] Assuming drive cache: write through
Sep 03 13:31:32 kaiba-manjaro kernel: kvm: disabled by bios
Sep 03 13:31:32 kaiba-manjaro kernel: sd 6:0:0:0: [sdd] No Caching mode page found
Sep 03 13:31:32 kaiba-manjaro kernel: sd 6:0:0:0: [sdd] Assuming drive cache: write through
Sep 03 13:31:33 kaiba-manjaro kernel: kvm: disabled by bios
Sep 03 13:31:33 kaiba-manjaro kernel: blk_update_request: I/O error, dev sr0, sector 49144 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
Sep 03 13:31:33 kaiba-manjaro kernel: blk_update_request: I/O error, dev sr0, sector 49144 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Sep 03 13:31:33 kaiba-manjaro kernel: Buffer I/O error on dev sr0, logical block 49144, async page read
Sep 03 13:31:33 kaiba-manjaro kernel: blk_update_request: I/O error, dev sr0, sector 49145 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Sep 03 13:31:33 kaiba-manjaro kernel: Buffer I/O error on dev sr0, logical block 49145, async page read
Sep 03 13:31:33 kaiba-manjaro kernel: blk_update_request: I/O error, dev sr0, sector 49146 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Sep 03 13:31:33 kaiba-manjaro kernel: Buffer I/O error on dev sr0, logical block 49146, async page read
Sep 03 13:31:33 kaiba-manjaro kernel: blk_update_request: I/O error, dev sr0, sector 49147 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Sep 03 13:31:33 kaiba-manjaro kernel: Buffer I/O error on dev sr0, logical block 49147, async page read
Sep 03 13:31:33 kaiba-manjaro kernel: blk_update_request: I/O error, dev sr0, sector 49148 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Sep 03 13:31:33 kaiba-manjaro kernel: Buffer I/O error on dev sr0, logical block 49148, async page read
Sep 03 13:31:33 kaiba-manjaro kernel: blk_update_request: I/O error, dev sr0, sector 49149 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Sep 03 13:31:33 kaiba-manjaro kernel: Buffer I/O error on dev sr0, logical block 49149, async page read
Sep 03 13:31:33 kaiba-manjaro kernel: blk_update_request: I/O error, dev sr0, sector 49150 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Sep 03 13:31:33 kaiba-manjaro kernel: Buffer I/O error on dev sr0, logical block 49150, async page read
Sep 03 13:31:33 kaiba-manjaro kernel: blk_update_request: I/O error, dev sr0, sector 49151 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Sep 03 13:31:33 kaiba-manjaro kernel: Buffer I/O error on dev sr0, logical block 49151, async page read
Sep 03 13:31:33 kaiba-manjaro kernel: Buffer I/O error on dev sr0, logical block 12287, async page read
Sep 03 13:31:36 kaiba-manjaro kernel: [drm:dmub_abm_init_config [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:39 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:39 kaiba-manjaro kernel: [drm:set_pixel_clock_v7 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:40 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:41 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:42 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:43 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:44 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:45 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:46 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:47 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:48 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:49 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:50 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:51 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:52 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:53 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:54 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:54 kaiba-manjaro kernel: [drm:set_pixel_clock_v7 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:54 kaiba-manjaro kernel: [drm:encoder_control_digx_v1_5 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:55 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:56 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:57 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:58 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:59 kaiba-manjaro kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 03 13:31:59 kaiba-manjaro kernel: BUG: kernel NULL pointer dereference, address: 0000000000000010
Sep 03 13:31:59 kaiba-manjaro kernel: #PF: supervisor read access in kernel mode
Sep 03 13:31:59 kaiba-manjaro kernel: #PF: error_code(0x0000) - not-present page
-- Boot 1a8e8e9093b54f06950c28db2a69eb5e --
Sep 03 13:32:48 kaiba-manjaro kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Sep 03 13:32:48 kaiba-manjaro kernel: sd 5:0:0:0: [sdc] No Caching mode page found
Sep 03 13:32:48 kaiba-manjaro kernel: sd 5:0:0:0: [sdc] Assuming drive cache: write through
Sep 03 13:32:48 kaiba-manjaro kernel: kvm: disabled by bios
Sep 03 13:32:49 kaiba-manjaro kernel: kvm: disabled by bios
-- Boot 7a60afc963414ad2bbd61b696fa5de83 --
Sep 03 13:34:47 kaiba-manjaro kernel: sd 5:0:0:0: [sdc] No Caching mode page found
Sep 03 13:34:47 kaiba-manjaro kernel: sd 5:0:0:0: [sdc] Assuming drive cache: write through
Sep 03 13:34:47 kaiba-manjaro kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Sep 03 13:34:47 kaiba-manjaro kernel: kvm: disabled by bios
Sep 03 13:34:48 kaiba-manjaro kernel: kvm: disabled by bios
Sep 03 13:34:49 kaiba-manjaro kernel: kvm: disabled by bios
-- Boot 01794ddc5fba46dd99fac01b08cd418d --
Sep 03 15:09:26 kaiba-manjaro kernel: sd 5:0:0:0: [sdc] No Caching mode page found
Sep 03 15:09:26 kaiba-manjaro kernel: sd 5:0:0:0: [sdc] Assuming drive cache: write through
Sep 03 15:09:26 kaiba-manjaro kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Sep 03 15:09:27 kaiba-manjaro kernel: kvm: disabled by bios
Sep 03 15:09:28 kaiba-manjaro kernel: kvm: disabled by bios
-- Boot 3950a6690d704c25a51753085e5c3a31 --
Sep 03 15:12:01 kaiba-manjaro kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Sep 03 15:12:01 kaiba-manjaro kernel: kvm: disabled by bios
Sep 03 15:12:01 kaiba-manjaro kernel: sd 5:0:0:0: [sdc] No Caching mode page found
Sep 03 15:12:01 kaiba-manjaro kernel: sd 5:0:0:0: [sdc] Assuming drive cache: write through
Sep 03 15:12:02 kaiba-manjaro kernel: kvm: disabled by bios
-- Boot 915b40b00a7e4fd0a9ad5dbabdb50eb5 --
Sep 03 17:16:58 kaiba-manjaro kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Sep 03 17:16:58 kaiba-manjaro kernel: kvm: disabled by bios
Sep 03 17:16:59 kaiba-manjaro kernel: kvm: disabled by bios
Sep 03 17:17:00 kaiba-manjaro kernel: kvm: disabled by bios
[manjaro /]# exit
