RStudio freezes when used only on laptop but not with monitor
Hi. I’m using RStudio but am finding it freezes when I’m using my laptop without a monitor plugged in. Freezing happens sporadically but can be triggered if I try to resize the window or minimise one of the panels in the RStudio app. The whole app window goes white and I can only close the window from the task manager. Strange thing is that the issue does not happen when my monitor is plugged in. Monitor is standard HD (1920x1080), laptop is 4k (3840x2160). Not sure how to troubleshoot this. I’ve tried changing the display settings, reinstalling, no joy. Any ideas? Running GNOME.
:+1: Welcome to Manjaro! :+1:
Please read this:
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
:+1:
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU you have, …
Hi @Fabby thanks for the pointers. Sorry for the slow reply - I thought I’d get notified if someone replied but didn’t for some reason. Output of inxi --admin --verbosity=7 --filter --no-host --width pasted below.
I’m not sure what else would be useful… let me know if I can provide more info.
  Kernel: 5.4.80-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=8643e13d-67fa-4e6a-a82c-e45ef5ea0cb9 rw apparmor=1
  bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
  snd_hda_intel.dmic_detect=0
  Desktop: GNOME 3.38.1 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.38.2
  Distro: Manjaro Linux
  Type: Convertible System: HP product: HP Spectre x360 Convertible 13-ap0xxx
  v: N/A serial: <filter> Chassis: type: 31 serial: <filter>
  Mobo: HP model: 8514 v: 09.68 serial: <filter> UEFI: AMI v: F.34
  date: 10/08/2019
  ID-1: BAT0 charge: 56.7 Wh condition: 56.7/56.7 Wh (100%) volts: 16.3/15.4
  model: HP Primary type: Li-ion serial: N/A status: Discharging
  Device-1: hid-0018:04F3:2810.0001-battery model: ELAN2514:00 04F3:2810
  serial: N/A charge: N/A status: N/A
  RAM: total: 15.30 GiB used: 1.63 GiB (10.7%)
  Info: Quad Core model: Intel Core i7-8565U bits: 64 type: MT MCP
  arch: Kaby Lake family: 6 model-id: 8E (142) stepping: B (11) microcode: DE
  L2 cache: 8192 KiB bogomips: 32012
  Speed: 800 MHz min/max: 400/4600 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 800 7: 801 8: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
  cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
  est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
  rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
  ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
  vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
  v: kernel bus ID: 00:02.0 chip ID: 8086:3ea0
  Device-2: Quanta HP Wide Vision FHD Camera type: USB driver: uvcvideo
  bus ID: 1-5:2 chip ID: 0408:5251 serial: <filter>
  Display: x11 server: X.org 1.20.9 compositor: gnome-shell driver: intel
  unloaded: modesetting alternate: fbdev,vesa resolution: <xdpyinfo missing>
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.2.3
  direct render: Yes
  Device-1: Intel Cannon Point-LP High Definition Audio
  vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
  alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:9dc8
  Sound Server: ALSA v: k5.4.80-2-MANJARO
  Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
  port: 3000 bus ID: 00:14.3 chip ID: 8086:9df0
  Local Storage: total: 953.87 GiB used: 603.30 GiB (63.2%)
  ID-1: /dev/nvme0n1 vendor: Toshiba model: N/A size: 953.87 GiB block size:
  physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter>
  rev: AAHA4102 scheme: GPT
  ID-1: / raw size: 953.57 GiB size: 937.60 GiB (98.33%)
  used: 603.30 GiB (64.3%) fs: ext4 dev: /dev/nvme0n1p2 label: N/A
  uuid: 8643e13d-67fa-4e6a-a82c-e45ef5ea0cb9
  ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%)
  used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 label: N/A uuid: 92FD-2E54
  Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s
  chip ID: 1d6b:0002
  Device-1: 1-5:2 info: Quanta HP Wide Vision FHD Camera type: Video
  driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s chip ID: 0408:5251
  serial: <filter>
  Device-2: 1-9:3 info: Synaptics type: <vendor specific> driver: N/A
  interfaces: 1 rev: 2.0 speed: 12 Mb/s chip ID: 06cb:00bb serial: <filter>
  Device-3: 1-10:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
  type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
  chip ID: 8087:0aaa
  Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
  chip ID: 1d6b:0003
  Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
  chip ID: 1d6b:0002
  Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  chip ID: 1d6b:0003
  System Temperatures: cpu: 47.0 C mobo: N/A
  Processes: 272 Uptime: 18m Init: systemd v: 246 Compilers: gcc: 10.2.0
  alt: 6 clang: 11.0.0 Packages: 1788 apt: 0 pacman: 1779 lib: 450 rpm: 0
  flatpak: 0 snap: 9 Shell: Bash v: 5.0.18 running in: gnome-terminal
  inxi: 3.1.08
When the external Monitor is plugged in, is the internal screen turned off and not being in use?
If yes, it could be you’re running into memory problems as:
the kernel’s OOM (Out-Of-Memory) Killer doesn’t work properly when swap is disabled and if you run OOM, the system just freezes and the internal screen uses much more memory at UHD Resolution compared to only your monitor at FHD.
to verify, keep this open in a terminal:
watch --interval=5 "free --human"
And please: enable swap (or add more memory) if my suspicion is correct.
Hi @Fabby, thanks for the reply, I don’t think that’s the problem though. There is no shortage of memory (16GB) and I’ve monitored the memory when RStudio freezes - there is no change. Laptop screen is on when external monitor is plugged in. This is what happens upload://v77GYxcQLvpT3bzOvuFHBVQ8naM.gif
I.E. Both monitors are active in non-mirror mode when this happens or not?
:thinking:
When the monitor is plugged in I have both the laptop screen and the monitor in use (not mirrored). But just to be clear: RStudio freezes when there is no external monitor - it freezes when it is just the laptop screen. When the external monitor is plugged in RStudio does not freeze. Could it be an issue with the resolution? Laptop is 4k (3840x2160), monitor is standard HD (1920x1080).
Then I have no further bright ideas: I thought you closed the laptop lid and it would free up the laptop GPU memory and then not freeze which does not seem to be the case.
:sob:
