manjaro awesome too large xfce icons
I installed manjaro awesome and everything works fine, except that I have very large and colorful icons which apparently come from the xfce desktop environment.
Also, I believe, they force a larger height of the entire upper bar than necessary.
How can I change them to custom png images? I tried setting path for theme.widget-vol myself but that didnt work =/
right click on the applet that holds those icons,
you should be able to go to settings and change the size
i had the same issue when running on intel gpu, i adjusted it by setting a dpi option line to a xorg configuration.
i never even considered this and im kicking myself for it, good observation. and even more strange, if i start awesome on the intel gpu i get a different set of icons than i do if i start awesome on the nvidia. :man_facepalming:
the intel looking larger than on nvidia is a normal occurance so it never even crossed my mind. (still doesnt explain the icons being different) :man_shrugging:
i'll take a look now and see if scaling down the icon size has an effect on the bar size which i think your spot on with that one. :+1:
I think you mean the system tray in the upper right corner. That is not a part of xfce, but the system tray implementation of awesome in a wibar, if you set the size of the wibar, the icons of the systemtray are scaled accordingly. At least thats the case in my case.
You can do that with beautiful.wibar_height = <size> (e.g. I use for <size> 24 for 24 pixels) before you create the wibar (best you do this at the theme definitions)
https://awesomewm.org/doc/api/classes/awful.wibar.html#beautiful.wibar_height
There is also a forced_height property in the api, but I have to look up how that is set :thinking: : https://awesomewm.org/apidoc/widgets/wibox.widget.systray.html
im apparently blind, i looked for something like this and couldnt find it :man_facepalming: . theres still a couple things i cant really figure out, but wibar height = :ballot_box_with_check: thanks.
thank you guys. So I have to insert this line myself then? It does not exist already in my config.
Also, what about the icons themselves? I have a minimalistic set of symbols from my old config that I would like to reuse, if only I knew how. awesome seems to grap stuff from the /usr/share/awesome directories e.g. for the screen layout images in the upper right corner while I managed to set the wallpaper to a file located within the local awesome folder, which is where also my desired icon set resides
My theme file (cesious) is posted below
    Cesious Awesome WM theme
    Created by Culinax
    Modified by Thanos Apostolou
local themes_path = require("gears.filesystem").get_themes_dir()
theme = {}
theme.font              = "Noto Sans Regular 10"
theme.notification_font = "Noto Sans Bold 14"
theme.bg_normal   = "#1A1A1A"
theme.bg_focus    = "#1A1A1A"
theme.bg_urgent   = "#1A1A1A"
theme.bg_minimize = "#101010"
theme.bg_systray  = theme.bg_normal
theme.fg_normal   = "#ffffff"
theme.fg_focus    = "#00a1c6"
theme.fg_urgent   = "#af012b"
theme.fg_minimize = "#ffffff"
theme.border_width  = 1
theme.border_normal = "#000000"
theme.border_focus  = "#00a1c6"
theme.border_marked = "#16A085"
theme.titlebar_bg_focus = theme.bg_normal
theme.titlebar_bg_normal = theme.bg_normal
theme.titlebar_fg_focus = theme.bg_normal
theme.hotkeys_modifiers_fg = "#2EB398"
theme.widget_vol = themes_path .. "cesious/taglist/squarefw.png"
--theme.widget_ac = themes_path .. "cesious/icons_powerarrow-dark/ac.png"
--theme.widget_battery = themes_path .. "cesious/icons/mem.png"
theme.tasklist_disable_icon = true
theme.tasklist_plain_task_name = true
-- Display the taglist squares
theme.taglist_squares_sel   = themes_path .. "cesious/taglist/squarefw.png"
theme.taglist_squares_unsel = themes_path .. "cesious/taglist/squarew.png"
theme.wallpaper = "~/.config/awesome/themes/cesious/awesome-scrabble.png"
-- You can use your own layout icons like this:
theme.layout_fairh      = themes_path .. "cesious/layouts/fairh.png"
theme.layout_fairv      = themes_path .. "cesious/layouts/fairv.png"
theme.layout_floating   = themes_path .. "cesious/layouts/floating.png"
theme.layout_magnifier  = themes_path .. "cesious/layouts/magnifier.png"
theme.layout_max        = themes_path .. "cesious/layouts/max.png"
theme.layout_fullscreen = themes_path .. "cesious/layouts/fullscreen.png"
theme.layout_tilebottom = themes_path .. "cesious/layouts/tilebottom.png"
theme.layout_tileleft   = themes_path .. "cesious/layouts/tileleft.png"
theme.layout_tile       = themes_path .. "cesious/layouts/tile.png"
theme.layout_tiletop    = themes_path .. "cesious/layouts/tiletop.png"
theme.layout_spiral     = themes_path .. "cesious/layouts/spiral.png"
theme.layout_dwindle    = themes_path .. "cesious/layouts/dwindle.png"
theme.layout_cornernw   = themes_path .. "cesious/layouts/cornernw.png"
theme.layout_cornerne   = themes_path .. "cesious/layouts/cornerne.png"
theme.layout_cornersw   = themes_path .. "cesious/layouts/cornersw.png"
theme.layout_cornerse   = themes_path .. "cesious/layouts/cornerse.png"
--theme.awesome_icon = themes_path .. "cesious/icons/manjaro64.png"
-- Define the icon theme for application icons. If not set then the icons
-- from /usr/share/icons and /usr/share/icons/hicolor will be used.
theme.icon_theme = "Arc-Maia"
return theme
update:
weird! I changed the wibar height to 20 and the icons do not only change in size but are also displayed now in a simplistic white. I can live with that =) but dont understand it
That is because they are derived from the set global icon-theme. An icon-theme can have different icons for different pixel-sizes (e.g. the folder-icon of the papirus-dark theme is white for anything smaller than 22 pixels and colored above)
They are derived from the icon-theme. I think you could change them by using xdg-icon-resource to add your custom icons for your user: https://wiki.archlinux.org/index.php/Icons However, I have never done this and do not know how well this works and what additionally needs to be done.
An alternative could also be to create a custom icon theme in ~/.icons or ~/.local/share/icons, which inherits the theme you would like to use and overwrites the icons you want to change.
Here, is what I found on creating icon-themes and the explanation for inheritance:
https://www.linux.org/threads/creating-icon-themes.11826/
https://standards.freedesktop.org/icon-theme-spec/icon-theme-spec-latest.html#file_formats
@Sewing31 , you can grab icon packs and place them in /usr/share/icons
~ >>> ls -la /usr/share/icons
total 144
drwxr-xr-x  25 root root  4096 Aug 22 17:23 .
drwxr-xr-x 329 root root 12288 Aug 22 07:42 ..
drwxr-xr-x  15 root root  4096 Mar 23 14:11 Adwaita
drwxr-xr-x  12 root root  4096 Jul 12 17:27 Arc
drwx------   6 dglt dglt  4096 Aug 22 17:27 candy-icons
drwxr-xr-x   2 root root  4096 Mar 17 15:48 default
drwxr-xr-x  11 root root  4096 Jul  7 23:27 Enlightenment-X
drwxr-xr-x   5 root root  4096 Aug 18 07:03 ePapirus
drwxr-xr-x  10 root root  4096 Jul 12 17:27 Faba
drwxr-xr-x  10 root root  4096 Apr 16 10:19 gnome
drwxr-xr-x  26 root root  4096 Aug 22 06:42 hicolor
drwxr-xr-x   9 root root  4096 Nov  7  2018 HighContrast
drwxr-xr-x  20 root root  4096 Jul 12 17:27 Moka
drwxr-xr-x  10 root root  4096 Aug 18 07:03 Papirus
drwxr-xr-x   2 root root  4096 Aug 22 16:55 Papirus-Adapta-Maia
drwxr-xr-x   2 root root  4096 Jul 27 08:21 Papirus-Adapta-Nokto-Maia
drwxr-xr-x   6 root root  4096 Aug 18 07:03 Papirus-Dark
drwxr-xr-x   3 root root  4096 Jul 27 08:21 Papirus-Dark-Maia
drwxr-xr-x   5 root root  4096 Aug 18 07:03 Papirus-Light
drwxr-xr-x   3 root root  4096 Jul 27 08:21 Papirus-Light-Maia
drwxr-xr-x   8 root root  4096 Jul 27 08:21 Papirus-Maia
drwxr-xr-x   3 root root  4096 Mar 17 15:42 scalable
drwxr-xr-x   3 root root  4096 Mar 20 15:09 ubuntu-mono-dark
drwxr-xr-x   3 root root  4096 Nov  7  2018 xcursor-breeze
drwxr-xr-x   3 root root  4096 Nov  7  2018 xcursor-breeze-snow
each folder is it's owm icon theme, theres icons themes in the aur and other places
thank you guys
