Here’s the result of lsmod | grep nvidia
nvidia_uvm 2756608 0
nvidia_drm 73728 0
nvidia_modeset 1425408 1 nvidia_drm
nvidia 45367296 2 nvidia_uvm,nvidia_modeset
And the result of cat /var/log/Xorg.0.log
is:
[ 21.451] (--) Log file renamed from "/var/log/Xorg.pid-597.log" to "/var/log/Xorg.0.log"
[ 21.452]
X.Org X Server 1.21.1.3
[ 21.452] Current Operating System: Linux milne-manjaro 5.18.5-1-MANJARO #1 SMP PREEMPT_DYNAMIC Thu Jun 16 12:28:47 UTC 2022 x86_64
[ 21.452] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64 root=UUID=221a4206-f74b-45c0-9b5e-ffcb9c0a798c rw quiet resume=UUID=88773768-8836-42db-9e35-95ee0a05cf38 udev.log_priority=3
[ 21.452]
[ 21.452] Current version of pixman: 0.40.0
[ 21.452] Before reporting problems, check http://wiki.x.org
[ 21.452] Markers: (--) probed, (**) from config file, (==) default setting,
[ 21.452] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Jun 17 08:28:39 2022
[ 21.452] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 21.452] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 21.452] (==) ServerLayout "layout"
[ 21.452] (**) |-->Screen "Screen0" (0)
[ 21.452] (**) | |-->Monitor "Monitor0"
[ 21.453] (**) | |-->Device "Device0"
[ 21.453] (==) Automatically adding devices
[ 21.453] (==) Automatically enabling devices
[ 21.453] (==) Automatically adding GPU devices
[ 21.453] (==) Automatically binding GPU devices
[ 21.453] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 21.453] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 21.453] Entry deleted from font path.
[ 21.453] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 21.453] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 21.453] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 21.453] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 21.453] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 21.453] (**) Extension "COMPOSITE" is enabled
[ 21.453] (II) The server relies on udev to provide the list of input devices.
[ 21.453] (II) Module ABI versions:
[ 21.453] X.Org ANSI C Emulation: 0.4
[ 21.453] X.Org Video Driver: 25.2
[ 21.453] X.Org XInput driver : 24.4
[ 21.453] X.Org Server Extension : 10.0
[ 21.454] (++) using VT number 1
[ 21.454] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 21.455] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 21.455] (II) Platform probe for /sys/devices/pci0000:00/0000:00:03.1/0000:25:00.0/drm/card0
[ 21.459] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 21.459] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 21.463] (--) PCI:*(37@0:0:0) 10de:2504:3842:3656 rev 161, Mem @ 0xfc000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000f000/128, BIOS @ 0x????????/131072
[ 21.463] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 21.463] (II) LoadModule: "glx"
[ 21.463] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 21.465] (II) Module glx: vendor="X.Org Foundation"
[ 21.465] compiled for 1.21.1.3, module version = 1.0.0
[ 21.465] ABI class: X.Org Server Extension, version 10.0
[ 21.465] (II) LoadModule: "nvidia"
[ 21.466] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 21.466] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 21.466] compiled for 1.6.99.901, module version = 1.0.0
[ 21.466] Module class: X.Org Video Driver
[ 21.466] (II) NVIDIA dlloader X Driver 515.48.07 Fri May 27 03:23:48 UTC 2022
[ 21.466] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 21.471] (II) Loading sub module "fb"
[ 21.471] (II) LoadModule: "fb"
[ 21.471] (II) Module "fb" already built-in
[ 21.471] (II) Loading sub module "wfb"
[ 21.471] (II) LoadModule: "wfb"
[ 21.471] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 21.471] (II) Module wfb: vendor="X.Org Foundation"
[ 21.471] compiled for 1.21.1.3, module version = 1.0.0
[ 21.471] ABI class: X.Org ANSI C Emulation, version 0.4
[ 21.471] (II) Loading sub module "ramdac"
[ 21.471] (II) LoadModule: "ramdac"
[ 21.471] (II) Module "ramdac" already built-in
[ 21.472] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 21.472] (==) NVIDIA(0): RGB weight 888
[ 21.472] (==) NVIDIA(0): Default visual is TrueColor
[ 21.472] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 21.472] (**) Option "AllowNVIDIAGpuScreens"
[ 21.472] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 21.472] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 21.472] (**) NVIDIA(0): Enabling 2D acceleration
[ 21.472] (II) Loading sub module "glxserver_nvidia"
[ 21.472] (II) LoadModule: "glxserver_nvidia"
[ 21.472] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 21.483] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 21.483] compiled for 1.6.99.901, module version = 1.0.0
[ 21.483] Module class: X.Org Server Extension
[ 21.483] (II) NVIDIA GLX Module 515.48.07 Fri May 27 03:22:01 UTC 2022
[ 21.483] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 23.873] (EE) NVIDIA(GPU-0): Failed to initialize the NVIDIA GPU at PCI:37:0:0. Please
[ 23.873] (EE) NVIDIA(GPU-0): check your system's kernel log for additional error
[ 23.873] (EE) NVIDIA(GPU-0): messages and refer to Chapter 8: Common Problems in the
[ 23.873] (EE) NVIDIA(GPU-0): README for additional information.
[ 23.873] (EE) NVIDIA(GPU-0): Failed to initialize the NVIDIA graphics device!
[ 23.873] (EE) NVIDIA(0): Failing initialization of X screen
[ 23.873] (II) UnloadModule: "nvidia"
[ 23.873] (II) UnloadSubModule: "glxserver_nvidia"
[ 23.873] (II) Unloading glxserver_nvidia
[ 23.873] (II) UnloadSubModule: "wfb"
[ 23.873] (EE) Screen(s) found, but none have a usable configuration.
[ 23.873] (EE)
Fatal server error:
[ 23.873] (EE) no screens found(EE)
[ 23.873] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 23.873] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 23.873] (EE)
[ 23.876] (EE) Server terminated with error (1). Closing log file.
