To make a long story short, because of vmware-issues I switched to Kernel 5.10 (LTS). Before that, I used 5.15.7_rt23-1 and also had an install of 5.13.19-2 (unsupported). While on version 5.15, I installed 5.10 and uninstalled 5.15 & 5.13.
After I rebooted, manjaro automatically booted in 5.13 emergency mode. I now have to specifically select 5.10 every time I boot into manjaro with advanced options.
The weird thing is that I do not even have 5.13 installed any more. When I run mhwd-kernel -li, the output is as follow: (after that, I also installed 5.4 but that is not of the issue here)
Currently running: 5.10.89-1-MANJARO (linux510)
* linux510
* linux54
How can I remove 5.13 from my system or how can I prevent manjaro from automatically booting into 5.13?
Any help is appreciated, thank you!
After executing your find-command, I did find some 5.13 remnants, but after executing the rm-commands and re-initialization, the issue was fixed.
Thank you very much!
