I want to file a request that multitouch input doesn’t higlight text and objects anymore. Not sure which part of KDE I should file the bug for. kwin? plasma-frameworks?
@coldspark the reason for the above redirect is because Manjaro uses the official distribution’s versions, hence bugs in KDE parts should be reported to them…
Yeah sure but to which of the 200+ components?
I know right?
That’s unfortunately how they are, it took me a headspin also when i tried to post a bug there.
You might try some general section if you really can’t find a proper category, im sure someone there will change it if needed…
