Manjaro Arm Raspbery pi 3 LXQT won't boot after installation setup
Manjaro Arm Raspbery pi 3 LXQT won't boot, after installation setup and gets stuck on a message saying:
brcmf_fw_alloc_request: brcm/brcmfmac43430-sdio for chip BCM43430/1 and just gets stuck there and won't continue.
[UPDATE]
it did finally get to the login screen after taking forever to boot than as I went to type in my username and password it kicked me out and went back to the same screen and stuck again..
This image needs to be fixed, might try the minimal image and see if it does the same thing.
I tested minimal and it does allow me to boot tho I had issues typing in a password and root password and wasn't able to do that on the minimal but it does at least boot so there is an issue with the LXQT iso
The image is tested on a Raspberry Pi 3B.
Is your device an 3B+?
I have no problems with the pi3b or pi3b+. Seems like when I first installed the image I had to ssh to it and do a sudo pacman -Syu to update the programs and then a sudo reboot.
I hope to fix some of these boot issues with the new release. :slight_smile:
Raspberry pi 3 not the newer b+ model
