Manjaro ARM Preview1 for Rock Pi 4
Manjaro ARM Preview1 for Rock Pi 4!
The Manjaro ARM project is proud to anounce the first test release for the Rock Pi 4!
Download:
KDE
Features:
ROCK Pi 4 is a Rockchip RK3399 based SBC(Single Board Computer) by Radxa. It can run android or some Linux distributions. ROCK Pi 4 features a six core ARM processor, 64bit dual channel 3200Mb/s LPDDR4, up to 4K@60 HDMI, MIPI DSI, MIPI CSI, 3.5mm jack with mic, 802.11 ac WIFI, Bluetooth 5.0, USB Port, GbE LAN, 40-pin color expansion header, RTC. Also, ROCK Pi 4 supports USB PD and QC powering.
How to install:
Download the image/zip file from the download location. Verify that the download completed successfully.
After that, install Etcher (sudo pacman -S etcher if on Manjaro) and burn it to an SD or eMMC card (8 GB or larger).
Put the SD card into Rock Pi4's SD card slot or the eMMC on the main board, if you used eMMC, and boot it up. The Rock Pi 4 should recognize the SD/eMMC card as a bootable device and boot from it.
On the first boot, it will display an OEM type install. After you have made your choices it will reboot into your newly setup system.
Known Issues:
KDE
  • Favorites not set in menu.
  • No HW acceleration. (yet)
  • No Wifi/BT (probably need a kernel module)
  • No PCI-e/m.2 support.
  • No audio.
Donate!
Please consider supporting us via Patreon.
can you use fbdev?
sudo pacman -S xf86-video-fbdev
[    33.865] (--) Log file renamed from "/var/log/Xorg.pid-753.log" to "/var/log/Xorg.0.log"
[    33.886]
X.Org X Server 1.20.5
[    33.886] Build Operating System: Linux Arch Linux
[    33.886] Current Operating System: Linux rockpi4 5.1.9-1-MANJARO-ARM #1 SMP Wed Jun 12 14:09:23 UTC 2019 aarch64
[    33.886] Kernel command line: console=ttyS2,1500000 root=PARTUUID=33395474-01 rw rootwait initrd=0x04000000,20M ramdisk_size=10M
[    33.886] Build Date: 01 June 2019  04:42:15PM
[    33.886]
[    33.886] Current version of pixman: 0.38.4
[    33.886] 	Before reporting problems, check http://wiki.x.org
[    33.887] Markers: (--) probed, (**) from config file, (==) default setting,
[    33.887] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jun 13 17:57:50 2019
[    33.927] (==) Using config file: "/etc/X11/xorg.conf"
[    33.927] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    33.927] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    33.940] (==) No Layout section.  Using the first Screen section.
[    33.940] (==) No screen section available. Using defaults.
[    33.940] (**) |-->Screen "Default Screen Section" (0)
[    33.940] (**) |   |-->Monitor "<default monitor>"
[    33.941] (==) No device specified for screen "Default Screen Section".
	Using the first device section listed.
[    33.941] (**) |   |-->Device "FBDEV"
[    33.941] (==) No monitor specified for screen "Default Screen Section".
[    33.941] (**) Option "BlankTime" "0"
[    33.941] (**) Option "StandbyTime" "0"
[    33.941] (**) Option "SuspendTime" "0"
[    33.941] (**) Option "OffTime" "0"
[    33.941] (==) Automatically adding devices
[    33.941] (==) Automatically enabling devices
[    33.941] (==) Automatically adding GPU devices
[    33.941] (==) Automatically binding GPU devices
[    33.942] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    33.958] (WW) The directory "/usr/share/fonts/misc" does not exist.
[    33.958] 	Entry deleted from font path.
[    33.975] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    33.975] 	Entry deleted from font path.
[    33.975] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    33.975] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[    33.975] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[    33.975] (==) FontPath set to:
	/usr/share/fonts/TTF
[    33.975] (==) ModulePath set to "/usr/lib/xorg/modules"
[    33.975] (II) The server relies on udev to provide the list of input devices.
[    33.975] (II) Module ABI versions:
[    33.975] 	X.Org ANSI C Emulation: 0.4
[    33.975] 	X.Org Video Driver: 24.0
[    33.975] 	X.Org XInput driver : 24.1
[    33.975] 	X.Org Server Extension : 10.0
[    33.977] (++) using VT number 1
[    33.977] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    33.979] (II) xfree86: Adding drm device (/dev/dri/card0)
[    33.982] (II) no primary bus or device found
[    33.982] 	falling back to /sys/devices/platform/display-subsystem/drm/card0
[    33.983] (II) LoadModule: "glx"
[    33.993] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    34.218] (II) Module glx: vendor="X.Org Foundation"
[    34.218] 	compiled for 1.20.5, module version = 1.0.0
[    34.218] 	ABI class: X.Org Server Extension, version 10.0
[    34.218] (II) LoadModule: "fbdev"
[    34.237] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    34.250] (II) Module fbdev: vendor="X.Org Foundation"
[    34.250] 	compiled for 1.20.0, module version = 0.5.0
[    34.250] 	Module class: X.Org Video Driver
[    34.250] 	ABI class: X.Org Video Driver, version 24.0
[    34.250] (II) FBDEV: driver for framebuffer: fbdev
[    34.251] (WW) Falling back to old probe method for fbdev
[    34.251] (II) Loading sub module "fbdevhw"
[    34.251] (II) LoadModule: "fbdevhw"
[    34.251] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    34.256] (II) Module fbdevhw: vendor="X.Org Foundation"
[    34.256] 	compiled for 1.20.5, module version = 0.0.2
[    34.256] 	ABI class: X.Org Video Driver, version 24.0
[    34.257] (II) FBDEV(0): using /dev/fb0
[    34.257] (II) FBDEV(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[    34.257] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[    34.257] (==) FBDEV(0): RGB weight 888
[    34.257] (==) FBDEV(0): Default visual is TrueColor
[    34.257] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[    34.257] (II) FBDEV(0): hardware:  (video memory: 8100kB)
[    34.257] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[    34.257] (**) FBDEV(0): Option "fbdev" "/dev/fb0"
[    34.257] (II) FBDEV(0): checking modes against framebuffer device...
[    34.257] (II) FBDEV(0): checking modes against monitor...
[    34.257] (II) FBDEV(0): Virtual size is 1920x1080 (pitch 1920)
[    34.257] (**) FBDEV(0):  Built-in mode "current"
[    34.257] (==) FBDEV(0): DPI set to (96, 96)
[    34.257] (II) Loading sub module "fb"
[    34.257] (II) LoadModule: "fb"
[    34.257] (II) Loading /usr/lib/xorg/modules/libfb.so
[    34.282] (II) Module fb: vendor="X.Org Foundation"
[    34.282] 	compiled for 1.20.5, module version = 1.0.0
[    34.282] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    34.282] (**) FBDEV(0): using shadow framebuffer
[    34.282] (II) Loading sub module "shadow"
[    34.282] (II) LoadModule: "shadow"
[    34.294] (II) Loading /usr/lib/xorg/modules/libshadow.so
[    34.307] (II) Module shadow: vendor="X.Org Foundation"
[    34.307] 	compiled for 1.20.5, module version = 1.1.0
[    34.307] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    34.363] (==) FBDEV(0): Backing store enabled
[    34.369] (==) FBDEV(0): DPMS enabled
[    34.371] (II) Initializing extension Generic Event Extension
[    34.372] (II) Initializing extension SHAPE
[    34.373] (II) Initializing extension MIT-SHM
[    34.373] (II) Initializing extension XInputExtension
[    34.384] (II) Initializing extension XTEST
[    34.385] (II) Initializing extension BIG-REQUESTS
[    34.385] (II) Initializing extension SYNC
[    34.386] (II) Initializing extension XKEYBOARD
[    34.386] (II) Initializing extension XC-MISC
[    34.387] (II) Initializing extension SECURITY
[    34.387] (II) Initializing extension XFIXES
[    34.388] (II) Initializing extension RENDER
[    34.388] (II) Initializing extension RANDR
[    34.389] (II) Initializing extension COMPOSITE
[    34.390] (II) Initializing extension DAMAGE
[    34.390] (II) Initializing extension MIT-SCREEN-SAVER
[    34.391] (II) Initializing extension DOUBLE-BUFFER
[    34.391] (II) Initializing extension RECORD
[    34.392] (II) Initializing extension DPMS
[    34.392] (II) Initializing extension Present
[    34.393] (II) Initializing extension DRI3
[    34.393] (II) Initializing extension X-Resource
[    34.393] (II) Initializing extension XVideo
[    34.395] (II) Initializing extension XVideo-MotionCompensation
[    34.395] (II) Initializing extension GLX
[    34.395] (II) AIGLX: Screen 0 is not DRI2 capable
[    36.211] (II) IGLX: Loaded and initialized swrast
[    36.211] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[    36.211] (II) Initializing extension XFree86-VidModeExtension
[    36.212] (II) Initializing extension XFree86-DGA
[    36.213] (II) Initializing extension XFree86-DRI
[    36.213] (II) Initializing extension DRI2
[    36.419] (II) config/udev: Adding input device Telink Wireless Receiver Mouse (/dev/input/event0)
[    36.419] (**) Telink Wireless Receiver Mouse: Applying InputClass "libinput pointer catchall"
[    36.419] (II) LoadModule: "libinput"
[    36.420] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    36.451] (II) Module libinput: vendor="X.Org Foundation"
[    36.451] 	compiled for 1.20.3, module version = 0.28.2
[    36.451] 	Module class: X.Org XInput Driver
[    36.451] 	ABI class: X.Org XInput driver, version 24.1
[    36.451] (II) Using input driver 'libinput' for 'Telink Wireless Receiver Mouse'
[    36.451] (**) Telink Wireless Receiver Mouse: always reports core events
[    36.452] (**) Option "Device" "/dev/input/event0"
[    36.453] (**) Option "_source" "server/udev"
[    36.479] (II) event0  - Telink Wireless Receiver Mouse: is tagged by udev as: Mouse
[    36.480] (II) event0  - Telink Wireless Receiver Mouse: device is a pointer
[    36.480] (II) event0  - Telink Wireless Receiver Mouse: device removed
[    36.550] (**) Option "config_info" "udev:/sys/devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.0/0003:248A:00DA.0001/input/input0/event0"
[    36.550] (II) XINPUT: Adding extended input device "Telink Wireless Receiver Mouse" (type: MOUSE, id 6)
[    36.550] (**) Option "AccelerationScheme" "none"
[    36.550] (**) Telink Wireless Receiver Mouse: (accel) selected scheme none/0
[    36.551] (**) Telink Wireless Receiver Mouse: (accel) acceleration factor: 2.000
[    36.551] (**) Telink Wireless Receiver Mouse: (accel) acceleration threshold: 4
[    36.555] (II) event0  - Telink Wireless Receiver Mouse: is tagged by udev as: Mouse
[    36.555] (II) event0  - Telink Wireless Receiver Mouse: device is a pointer
[    36.558] (II) config/udev: Adding input device Telink Wireless Receiver Mouse (/dev/input/mouse0)
[    36.558] (II) No input driver specified, ignoring this device.
[    36.558] (II) This device may have been added with another device file.
[    36.561] (II) config/udev: Adding input device Telink Wireless Receiver Consumer Control (/dev/input/event1)
[    36.561] (**) Telink Wireless Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[    36.561] (**) Telink Wireless Receiver Consumer Control: Applying InputClass "system-keyboard"
[    36.561] (II) Using input driver 'libinput' for 'Telink Wireless Receiver Consumer Control'
[    36.562] (**) Telink Wireless Receiver Consumer Control: always reports core events
[    36.562] (**) Option "Device" "/dev/input/event1"
[    36.562] (**) Option "_source" "server/udev"
[    36.566] (II) event1  - Telink Wireless Receiver Consumer Control: is tagged by udev as: Keyboard
[    36.566] (II) event1  - Telink Wireless Receiver Consumer Control: device is a keyboard
[    36.567] (II) event1  - Telink Wireless Receiver Consumer Control: device removed
[    36.640] (II) libinput: Telink Wireless Receiver Consumer Control: needs a virtual subdevice
[    36.640] (**) Option "config_info" "udev:/sys/devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.0/0003:248A:00DA.0001/input/input1/event1"
[    36.640] (II) XINPUT: Adding extended input device "Telink Wireless Receiver Consumer Control" (type: MOUSE, id 7)
[    36.641] (**) Option "AccelerationScheme" "none"
[    36.641] (**) Telink Wireless Receiver Consumer Control: (accel) selected scheme none/0
[    36.641] (**) Telink Wireless Receiver Consumer Control: (accel) acceleration factor: 2.000
[    36.641] (**) Telink Wireless Receiver Consumer Control: (accel) acceleration threshold: 4
[    36.645] (II) event1  - Telink Wireless Receiver Consumer Control: is tagged by udev as: Keyboard
[    36.645] (II) event1  - Telink Wireless Receiver Consumer Control: device is a keyboard
[    36.647] (II) config/udev: Adding input device Telink Wireless Receiver System Control (/dev/input/event2)
[    36.648] (**) Telink Wireless Receiver System Control: Applying InputClass "libinput keyboard catchall"
[    36.648] (**) Telink Wireless Receiver System Control: Applying InputClass "system-keyboard"
[    36.648] (II) Using input driver 'libinput' for 'Telink Wireless Receiver System Control'
[    36.648] (**) Telink Wireless Receiver System Control: always reports core events
[    36.648] (**) Option "Device" "/dev/input/event2"
[    36.648] (**) Option "_source" "server/udev"
[    36.652] (II) event2  - Telink Wireless Receiver System Control: is tagged by udev as: Keyboard
[    36.652] (II) event2  - Telink Wireless Receiver System Control: device is a keyboard
[    36.652] (II) event2  - Telink Wireless Receiver System Control: device removed
[    36.690] (**) Option "config_info" "udev:/sys/devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.0/0003:248A:00DA.0001/input/input2/event2"
[    36.690] (II) XINPUT: Adding extended input device "Telink Wireless Receiver System Control" (type: KEYBOARD, id 8)
[    36.690] (**) Option "xkb_model" "pc105"
[    36.690] (**) Option "xkb_layout" "gb"
[    36.690] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    36.741] (II) event2  - Telink Wireless Receiver System Control: is tagged by udev as: Keyboard
[    36.741] (II) event2  - Telink Wireless Receiver System Control: device is a keyboard
[    36.744] (II) config/udev: Adding input device Telink Wireless Receiver (/dev/input/event3)
[    36.744] (**) Telink Wireless Receiver: Applying InputClass "libinput keyboard catchall"
[    36.744] (**) Telink Wireless Receiver: Applying InputClass "system-keyboard"
[    36.744] (II) Using input driver 'libinput' for 'Telink Wireless Receiver'
[    36.744] (**) Telink Wireless Receiver: always reports core events
[    36.744] (**) Option "Device" "/dev/input/event3"
[    36.744] (**) Option "_source" "server/udev"
[    36.748] (II) event3  - Telink Wireless Receiver: is tagged by udev as: Keyboard
[    36.748] (II) event3  - Telink Wireless Receiver: device is a keyboard
[    36.748] (II) event3  - Telink Wireless Receiver: device removed
[    36.790] (**) Option "config_info" "udev:/sys/devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:248A:00DA.0002/input/input3/event3"
[    36.790] (II) XINPUT: Adding extended input device "Telink Wireless Receiver" (type: KEYBOARD, id 9)
[    36.790] (**) Option "xkb_model" "pc105"
[    36.790] (**) Option "xkb_layout" "gb"
[    36.790] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    36.795] (II) event3  - Telink Wireless Receiver: is tagged by udev as: Keyboard
[    36.795] (II) event3  - Telink Wireless Receiver: device is a keyboard
[    36.797] (II) config/udev: Adding input device dw_hdmi (/dev/input/event4)
[    36.797] (**) dw_hdmi: Applying InputClass "libinput keyboard catchall"
[    36.797] (**) dw_hdmi: Applying InputClass "system-keyboard"
[    36.797] (II) Using input driver 'libinput' for 'dw_hdmi'
[    36.797] (**) dw_hdmi: always reports core events
[    36.797] (**) Option "Device" "/dev/input/event4"
[    36.798] (**) Option "_source" "server/udev"
[    36.800] (II) event4  - dw_hdmi: is tagged by udev as: Keyboard
[    36.800] (II) event4  - dw_hdmi: device is a keyboard
[    36.801] (II) event4  - dw_hdmi: device removed
[    36.840] (**) Option "config_info" "udev:/sys/devices/platform/ff940000.hdmi/rc/rc0/input4/event4"
[    36.840] (II) XINPUT: Adding extended input device "dw_hdmi" (type: KEYBOARD, id 10)
[    36.840] (**) Option "xkb_model" "pc105"
[    36.840] (**) Option "xkb_layout" "gb"
[    36.840] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    36.844] (II) event4  - dw_hdmi: is tagged by udev as: Keyboard
[    36.844] (II) event4  - dw_hdmi: device is a keyboard
[    36.867] (**) Telink Wireless Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[    36.867] (**) Telink Wireless Receiver Consumer Control: Applying InputClass "system-keyboard"
[    36.867] (II) Using input driver 'libinput' for 'Telink Wireless Receiver Consumer Control'
[    36.867] (**) Telink Wireless Receiver Consumer Control: always reports core events
[    36.867] (**) Option "Device" "/dev/input/event1"
[    36.867] (**) Option "_source" "_driver/libinput"
[    36.868] (II) libinput: Telink Wireless Receiver Consumer Control: is a virtual subdevice
[    36.868] (**) Option "config_info" "udev:/sys/devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.0/0003:248A:00DA.0001/input/input1/event1"
[    36.868] (II) XINPUT: Adding extended input device "Telink Wireless Receiver Consumer Control" (type: KEYBOARD, id 11)
[    36.868] (**) Option "xkb_model" "pc105"
[    36.868] (**) Option "xkb_layout" "gb"
[    36.868] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    36.888] (EE) Failed to open authorization file "/var/run/sddm/{19f0092d-c722-4b5c-baee-5778c8b96eab}": No such file or directory
Why would you use fbdev?
What does it bring that modesetting (used now) does not?
Also, the correct fbdev package would be xf86-video-fbturbo-git.
Always seems to complain about UMP and thought there was little diff now.
Dunno really as xorg loads fb anyway but seems to stop earlier complaints, was just wondering about No HW acceleration
Yeah, that's because the mali driver is missing.
That will probably arrive with kernel 5.2 and panfrost.
Its me really still stuck in my old non KMS raspberry VC4 mode out of old bad habits.
Would compiling https://github.com/rockchip-linux/libmali with and use libmali-midgard-t86x-r14p0-fbdev.so
work?
[EDIT]
For now should I say. Needs the mali kernel module though, but is pretty snappy as it is.
Panfrost might be great but presuming they will undergo optimisation
