Transparent bar at the bottom after installing Plank
After installing Plank, this transparent panel appeared and cannot find any way to remove it. Any ideas? I am using Manjaro XFCE, latest edition. Only the border shadow is visible, rest of the panel is invisible. It’s visible over all the screens.
This should help
Thanks for the reference. The setting to search for is Window Manager Tweak. I was going through Window Manager only.
