manjaro-arm-installer problem + empty BOOT_MNJRO
Hi, i have problems with the installer, the process seems to finish but BOOT_MNJRO partition is empty and the device clearly does not boot
Tested both the one from the repo and the one from GitLab, same result
Here si the full install log
==> Proceeding....
  -> Getting package lists ready for rpi4 lxqt edition...
grep: /var/tmp/manjaro-arm-installer/arm-profiles/devices/rpi4: No such file or directory
grep: /var/tmp/manjaro-arm-installer/arm-profiles/editions/lxqt: No such file or directory
grep: /var/tmp/manjaro-arm-installer/arm-profiles/services/lxqt: No such file or directory
==> Getting /dev/mmcblk0 ready for rpi4...
==> Creating install for rpi4...
  -> Used device is /dev/mmcblk0p
  -> Downloading latest aarch64 rootfs...
Manjaro-ARM-aarch64-latest.tar.gz       100%[=============================================================================>] 184,38M  6,05MB/s    in 28s
  -> Extracting aarch64 rootfs...
  -> Setting up keyrings...
  -> Generating mirrorlist...
  -> Installing packages for lxqt on rpi4...
 core                                                              217.4 KiB  1976 KiB/s 00:00 [########################################################] 100%
 extra                                                               2.3 MiB  6.17 MiB/s 00:00 [########################################################] 100%
 community                                                           5.1 MiB  7.14 MiB/s 00:01 [########################################################] 100%
resolving dependencies...
Packages (85) acl-2.2.53-3  archlinux-keyring-20200603-1  argon2-20190702-3  attr-2.4.48-3  bash-5.0.017-1  ca-certificates-mozilla-3.53-1  coreutils-8.32-1
              cryptsetup-2.3.3-1  curl-7.70.0-1  dbus-1.12.18-1  device-mapper-2.02.187-3  e2fsprogs-1.45.6-2  file-5.38-3  filesystem-2020.05-1
              gawk-5.1.0-1  gcc-libs-9.3.0-1  gettext-0.20.2-1  glib2-2.64.3-2  glibc-2.31-2  gnupg-2.2.20-4  gnutls-3.6.14-1  gpgme-1.13.1-7  grep-3.4-1
              gzip-1.10-3  iana-etc-20200601-1  icu-67.1-1  iproute2-5.7.0-1  iptables-1:1.8.5-2  iputils-20190709-2  json-c-0.14-4  keyutils-1.6.1-4
              krb5-1.18.1-1  less-551-3  libarchive-3.4.3-1  libcap-2.34-1  libcroco-0.6.13-2  libelf-0.179-1  libffi-3.3-3  libgpg-error-1.38-1
              libksba-1.4.0-1  libnetfilter_conntrack-1.0.8-1  libnfnetlink-1.0.1-4  libnftnl-1.1.6-1  libnghttp2-1.41.0-1  libp11-kit-0.23.20-5
              libsasl-2.1.27-3  libsecret-0.20.3-1  libtirpc-1.2.6-1  libutil-linux-2.35.2-1  libxml2-2.9.10-2  licenses-20200427-1
              linux-api-headers-5.6.11-1  lsb-release-1.4-13  manjaro-keyring-20200421-1  mpfr-4.0.2-2  nettle-3.6-1  openssl-1.1.1.g-2  p11-kit-0.23.20-5
              pacman-5.2.1-5  pciutils-3.7.0-1  pcre2-10.35-1  perl-5.30.3-1  procps-ng-3.3.16-2  psmisc-23.3-2  python-3.8.3-1  python-appdirs-1.4.4-1
              python-chardet-3.0.4-5  python-ordered-set-3.1.1-2  python-packaging-20.4-1  python-pyparsing-2.4.7-1  python-setuptools-1:47.1.1-1
              python-six-1.15.0-1  python-urllib3-1.25.9-1  sed-4.8-1  sqlite-3.32.2-1  systemd-sysvcompat-245.6-6  tar-1.32-3  tzdata-2020a-1
              util-linux-2.35.2-1  zstd-1.4.5-1  base-2-2  manjaro-release-20.06-1  manjaro-system-20200428-1  systemd-245.6-6  systemd-libs-245.6-6
Total Installed Size:  546.98 MiB
Net Upgrade Size:       76.64 MiB
(85/85) checking keys in keyring                                                               [########################################################] 100%
(85/85) checking package integrity                                                             [########################################################] 100%
(85/85) loading package files        [########################################################] 100%
(85/85) checking for file conflicts                                                            [########################################################] 100%
(85/85) checking available disk space                                                          [########################################################] 100%
( 1/85) upgrading iana-etc        [########################################################] 100%
( 2/85) upgrading filesystem        [########################################################] 100%
( 3/85) upgrading linux-api-headers                                                            [########################################################] 100%
( 4/85) upgrading tzdata        [########################################################] 100%
( 5/85) upgrading glibc        [########################################################] 100%
Generating locales...
Generation complete.
( 6/85) upgrading gcc-libs        [########################################################] 100%
( 7/85) upgrading bash        [########################################################] 100%
( 8/85) upgrading attr        [########################################################] 100%
( 9/85) upgrading acl        [########################################################] 100%
(10/85) upgrading libcap        [########################################################] 100%
(11/85) upgrading perl        [########################################################] 100%
(12/85) upgrading openssl        [########################################################] 100%
(13/85) upgrading coreutils        [########################################################] 100%
(14/85) installing file        [########################################################] 100%
(15/85) installing mpfr        [########################################################] 100%
(16/85) installing gawk        [########################################################] 100%
(17/85) installing grep        [########################################################] 100%
(18/85) upgrading libgpg-error        [########################################################] 100%
(19/85) upgrading systemd-libs        [########################################################] 100%
(20/85) installing procps-ng        [########################################################] 100%
(21/85) installing sed        [########################################################] 100%
(22/85) installing tar        [########################################################] 100%
(23/85) upgrading libffi        [########################################################] 100%
(24/85) upgrading libutil-linux        [########################################################] 100%
(25/85) upgrading glib2        [########################################################] 100%
(26/85) installing icu        [########################################################] 100%
(27/85) installing libxml2        [########################################################] 100%
(28/85) installing libcroco        [########################################################] 100%
(29/85) installing gettext        [########################################################] 100%
Optional dependencies for gettext
    git: for autopoint infrastructure updates
(30/85) installing pciutils        [########################################################] 100%
(31/85) installing psmisc        [########################################################] 100%
(32/85) upgrading e2fsprogs        [########################################################] 100%
(33/85) upgrading keyutils        [########################################################] 100%
(34/85) upgrading libsasl        [########################################################] 100%
(35/85) upgrading krb5        [########################################################] 100%
(36/85) upgrading libtirpc        [########################################################] 100%
(37/85) upgrading util-linux        [########################################################] 100%
(38/85) installing less        [########################################################] 100%
(39/85) installing gzip        [########################################################] 100%
(40/85) installing licenses        [########################################################] 100%
(41/85) upgrading zstd        [########################################################] 100%
(42/85) upgrading libarchive        [########################################################] 100%
(43/85) upgrading libnghttp2        [########################################################] 100%
(44/85) upgrading libp11-kit        [########################################################] 100%
(45/85) upgrading p11-kit        [########################################################] 100%
(46/85) upgrading ca-certificates-mozilla                                                      [########################################################] 100%
(47/85) upgrading curl        [########################################################] 100%
(48/85) upgrading libksba        [########################################################] 100%
(49/85) upgrading nettle        [########################################################] 100%
(50/85) upgrading gnutls        [########################################################] 100%
(51/85) upgrading sqlite        [########################################################] 100%
(52/85) upgrading libsecret        [########################################################] 100%
(53/85) upgrading gnupg        [########################################################] 100%
(54/85) upgrading gpgme        [########################################################] 100%
(55/85) upgrading archlinux-keyring                                                            [########################################################] 100%
==> Appending keys from archlinux.gpg...
gpg: Warning: using insecure memory!
==> Locally signing trusted keys in keyring...
  -> Locally signing key D8AFDDA07A5B6EDFA7D8CCDAD6D055F927843F1C...
  -> Locally signing key DDB867B92AA789C165EEFA799B729B06A680C281...
  -> Locally signing key 91FFE0700E80619CEB73235CA88E23E377514E00...
  -> Locally signing key 0E8B644079F599DFC1DDC3973348882F6AC6A4C2...
  -> Locally signing key AB19265E5D7D20687D303246BA1DFB64FFF979E7...
==> Importing owner trust values...
==> Disabling revoked keys in keyring...
  -> Disabling key 8F76BEEA0289F9E1D3E229C05F946DED983D4366...
  -> Disabling key 63F395DE2D6398BBE458F281F2DBB4931985A992...
  -> Disabling key 50F33E2E5B0C3D900424ABE89BDCF497A4BBCC7F...
  -> Disabling key 27FFC4769E19F096D41D9265A04F9397CDFD6BB0...
  -> Disabling key 39F880E50E49A4D11341E8F939E4F17F295AFBF4...
  -> Disabling key 8840BD07FC24CB7CE394A07CCF7037A4F27FB7DA...
  -> Disabling key 5559BC1A32B8F76B3FCCD9555FA5E5544F010D48...
  -> Disabling key 0B20CA1931F5DA3A70D0F8D2EA6836E1AB441196...
  -> Disabling key 07DFD3A0BC213FA12EDC217559B3122E2FA915EC...
  -> Disabling key 4FCF887689C41B09506BE8D5F3E1D5C5D30DB0AD...
  -> Disabling key 5A2257D19FF7E1E0E415968CE62F853100F0D0F0...
  -> Disabling key D921CABED130A5690EF1896E81AF739EC0711BF1...
  -> Disabling key 7FA647CD89891DEDC060287BB9113D1ED21E1A55...
  -> Disabling key BC1FBE4D2826A0B51E47ED62E2539214C6C11350...
  -> Disabling key 4A8B17E20B88ACA61860009B5CED81B7C2E5C0D2...
  -> Disabling key 5696C003B0854206450C8E5BE613C09CB4440678...
  -> Disabling key 684148BB25B49E986A4944C55184252D824B18E8...
  -> Disabling key 8CF934E339CAD8ABF342E822E711306E3C4F88BC...
  -> Disabling key F5A361A3A13554B85E57DDDAAF7EF7873CFD4BB6...
  -> Disabling key 5E7585ADFF106BFFBBA319DC654B877A0864983E...
  -> Disabling key 65EEFE022108E2B708CBFCF7F9E712E59AF5F22A...
  -> Disabling key 40440DC037C05620984379A6761FAD69BA06C6A9...
  -> Disabling key 34C5D94FE7E7913E86DC427E7FB1A3800C84C0A5...
  -> Disabling key 81D7F8241DB38BC759C80FCE3A726C6170E80477...
  -> Disabling key E7210A59715F6940CF9A4E36A001876699AD6E84...
  -> Disabling key 5357F3B111688D88C1D88119FCF2CB179205AC90...
  -> Disabling key 4D913AECD81726D9A6C74F0ADA6426DD215B37AD...
  -> Disabling key FB871F0131FEA4FB5A9192B4C8880A6406361833...
  -> Disabling key 66BD74A036D522F51DD70A3C7F2A16726521E06D...
  -> Disabling key B1F2C889CB2CCB2ADA36D963097D629E437520BD...
  -> Disabling key 9515D8A8EAB88E49BB65EDBCE6B456CAF15447D5...
  -> Disabling key 76B4192E902C0A52642C63C273B8ED52F1D357C1...
  -> Disabling key 40776A5221EF5AD468A4906D42A1DB15EC133BAD...
  -> Disabling key D4DE5ABDE2A7287644EAC7E36D1A9E70E19DAA50...
  -> Disabling key 44D4A033AC140143927397D47EFD567D4C7EA887...
==> Updating trust database...
gpg: next trustdb check due at 2020-10-17
(56/85) upgrading manjaro-keyring                                                              [########################################################] 100%
==> Appending keys from manjaro.gpg...
  -> Locally signing key B4663188A692DB1E45A98EE95BD96CC4247B52CC...
  -> Locally signing key 76C6E477042BFE985CC220BD9C08A255442FAFF0...
  -> Locally signing key 7C89F4D439B2BFACF425107B62443D89B35859F8...
  -> Locally signing key 1E7908935AAB9A00D6B47503363DFFFD59152F77...
  -> Locally signing key 04BB537F5BC2D399BFA72F8F17C752B61B2F2E90...
  -> Locally signing key 5A97ED6B72418199F0C22B23137C934B5DCB998E...
  -> Locally signing key 75C1B95A4D9514A57EB2DAE71817DC63CD3B5DF5...
  -> Locally signing key 39F0EC1AE50B37E5F3196F09DAD3B211663CA268...
  -> Locally signing key 2D14560CDCE6A75BB186DB758238651DDF5E0594...
  -> Locally signing key 7A443CEE69B6B3777740E258084A7FC0035B1D49...
  -> Locally signing key F66AD0FF0E57C561615A0901CEE477135C5872B0...
  -> Locally signing key 35B4FF23EA9477582C2A0AF12B80869C5C0102A6...
  -> Locally signing key E4CDFE50A2DA85D58C8A8C70CAA6A59611C7F07E...
  -> Locally signing key 74C2F2CC05A0AB7D859839938934292D604F8BA2...
  -> Locally signing key 77DC01C9971AC3C39A0626F72C089F09AC97B894...
  -> Locally signing key 16DC688DF3EECC72323954237EC47C82A42D53A2...
  -> Locally signing key 2C688B52E3FC0144B7484BABE3B3F44AC45EE0AA...
  -> Locally signing key 22C903DE964E6FE321656E318DB9F8C18DF53602...
  -> Locally signing key 688E8F82879D0E25CE541426150C200743ED46D8...
gpg: changing ownertrust from 1 to 4
gpg: setting ownertrust to 4
  -> Disabling key 540DE7083B89314CF70EA6F0C1B1AD0DA80EBF3E...
  -> Disabling key FAA6840E8C3FC7F89BEE0DC8AC7AB10BCB6CDD17...
gpg: key 1EB2638FF56C0C53: no user ID for key signature packet of class 10
gpg: key 786C63F330D7CB92: no user ID for key signature packet of class 10
gpg: marginals needed: 3  completes needed: 1  trust model: pgp
gpg: depth: 0  valid:   1  signed:  28  trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1  valid:  28  signed:  78  trust: 0-, 0q, 0n, 25m, 0f, 0u
gpg: depth: 2  valid:  75  signed:  24  trust: 75-, 0q, 0n, 0m, 0f, 0u
(57/85) upgrading python        [########################################################] 100%
(58/85) upgrading python-appdirs                                                               [########################################################] 100%
(59/85) upgrading python-pyparsing                                                             [########################################################] 100%
(60/85) upgrading python-six        [########################################################] 100%
(61/85) upgrading python-packaging                                                             [########################################################] 100%
(62/85) upgrading python-ordered-set                                                           [########################################################] 100%
(63/85) upgrading python-setuptools                                                            [########################################################] 100%
(64/85) upgrading python-chardet                                                               [########################################################] 100%
(65/85) upgrading python-urllib3                                                               [########################################################] 100%
(66/85) upgrading pacman        [########################################################] 100%
(67/85) upgrading device-mapper        [########################################################] 100%
(68/85) upgrading json-c        [########################################################] 100%
(69/85) upgrading argon2        [########################################################] 100%
(70/85) upgrading cryptsetup        [########################################################] 100%
(71/85) upgrading dbus        [########################################################] 100%
(72/85) upgrading libnftnl        [########################################################] 100%
(73/85) upgrading libnfnetlink        [########################################################] 100%
(74/85) upgrading libnetfilter_conntrack                                                       [########################################################] 100%
(75/85) upgrading iptables        [########################################################] 100%
(76/85) upgrading libelf        [########################################################] 100%
(77/85) upgrading pcre2        [########################################################] 100%
(78/85) upgrading systemd        [########################################################] 100%
Creating group sys with gid 3.
Creating group mem with gid 8.
Creating group ftp with gid 11.
Creating group mail with gid 12.
Creating group log with gid 19.
Creating group smmsp with gid 25.
Creating group proc with gid 26.
Creating group games with gid 50.
Creating group lock with gid 54.
Creating group network with gid 90.
Creating group floppy with gid 94.
Creating group scanner with gid 96.
Creating group power with gid 98.
Creating group adm with gid 999.
Creating group wheel with gid 998.
Creating group kmem with gid 997.
Creating group tty with gid 5.
Creating group utmp with gid 996.
Creating group audio with gid 995.
Creating group disk with gid 994.
Creating group input with gid 993.
Creating group kvm with gid 992.
Creating group lp with gid 991.
Creating group optical with gid 990.
Creating group render with gid 989.
Creating group storage with gid 988.
Creating group uucp with gid 987.
Creating group video with gid 986.
Creating group users with gid 985.
Creating group systemd-journal with gid 984.
Creating group rfkill with gid 983.
Creating group bin with gid 1.
Creating user bin (n/a) with uid 1 and gid 1.
Creating group daemon with gid 2.
Creating user daemon (n/a) with uid 2 and gid 2.
Creating user mail (n/a) with uid 8 and gid 12.
Creating user ftp (n/a) with uid 14 and gid 11.
Creating group http with gid 33.
Creating user http (n/a) with uid 33 and gid 33.
Creating group nobody with gid 65534.
Creating user nobody (Nobody) with uid 65534 and gid 65534.
Creating group dbus with gid 81.
Creating user dbus (System Message Bus) with uid 81 and gid 81.
Creating group systemd-journal-remote with gid 982.
Creating user systemd-journal-remote (systemd Journal Remote) with uid 982 and gid 982.
Creating group systemd-network with gid 981.
Creating user systemd-network (systemd Network Management) with uid 981 and gid 981.
Creating group systemd-resolve with gid 980.
Creating user systemd-resolve (systemd Resolver) with uid 980 and gid 980.
Creating group systemd-timesync with gid 979.
Creating user systemd-timesync (systemd Time Synchronization) with uid 979 and gid 979.
Creating group systemd-coredump with gid 978.
Creating user systemd-coredump (systemd Core Dumper) with uid 978 and gid 978.
Creating group uuidd with gid 68.
Creating user uuidd (n/a) with uid 68 and gid 68.
(79/85) installing systemd-sysvcompat                                                          [########################################################] 100%
(80/85) installing iputils        [########################################################] 100%
Optional dependencies for iputils
    xinetd: for tftpd
(81/85) installing iproute2        [########################################################] 100%
Optional dependencies for iproute2
    linux-atm: ATM support
(82/85) installing base        [########################################################] 100%
Optional dependencies for base
    linux: bare metal support
(83/85) installing manjaro-system                                                              [########################################################] 100%
(84/85) installing lsb-release        [########################################################] 100%
(85/85) installing manjaro-release                                                             [########################################################] 100%
( 1/11) Creating system user accounts...
( 2/11) Updating journal message catalog...
( 3/11) Reloading system manager configuration...
  Skipped: Current root is not booted.
( 4/11) Updating udev hardware database...
( 5/11) Applying kernel sysctl settings...
( 6/11) Creating temporary files...
[/usr/lib/tmpfiles.d/journal-nocow.conf:26] Failed to resolve specifier: uninitialized /etc detected, skipping
All rules containing unresolvable specifiers will be skipped.
( 7/11) Reloading device manager configuration...
  Skipped: Device manager is not running.
( 8/11) Arming ConditionNeedsUpdate...
( 9/11) Reloading system bus configuration...
(10/11) Warn about old perl modules
(11/11) Rebuilding certificate stores...
  -> Enabling services...
  -> Applying overlay for lxqt...
cp: cannot stat '/var/tmp/manjaro-arm-installer/arm-profiles/overlays/lxqt/*': No such file or directory
  -> Setting up users...
  -> Setting password for root ...
  -> Adding user...
  -> Enabling user services...
  -> Setting up system settings...
  en_GB.UTF-8... done
./manjaro-arm-installer: line 191: /var/tmp/manjaro-arm-installer/root/etc/X11/xorg.conf.d/00-keyboard.conf: No such file or directory
./manjaro-arm-installer: line 192: /var/tmp/manjaro-arm-installer/root/etc/X11/xorg.conf.d/00-keyboard.conf: No such file or directory
./manjaro-arm-installer: line 193: /var/tmp/manjaro-arm-installer/root/etc/X11/xorg.conf.d/00-keyboard.conf: No such file or directory
./manjaro-arm-installer: line 194: /var/tmp/manjaro-arm-installer/root/etc/X11/xorg.conf.d/00-keyboard.conf: No such file or directory
sed: can't read /var/tmp/manjaro-arm-installer/root/etc/X11/xorg.conf.d/00-keyboard.conf: No such file or directory
Correcting permissions from overlay...
chown: cannot access '/var/tmp/manjaro-arm-installer/root/etc/polkit-1/rules.d': No such file or directory
  -> Cleaning install for unwanted files...
==> rpi4 lxqt install complete
==> Writing bootloader and cleaning up after install...
mv: cannot stat '/var/tmp/manjaro-arm-installer/root/boot/*': No such file or directory
==> Time : 29.77 minutes...
Use lsblk to make sure you are targeting a device that meets the requirements and it is unmounted before you run the installer script.
It looks like it might be running out of space? The missing files and directories at the end suggest so, but I can't say for sure.
Looking at the script, it makes sanity checks on dependencies, but I don't think it checks eMMC/SD card size.
SD card is 16GB,(i tested a 32GB too), i formatted it (no partitions, just Unallocated Space), run the script as sudo but i always have the same problem.
i wonder about these missing configs/profiles...
Maybe something is auto-mounting partitions as the script creates them?
Then they are not where the installer expects them because they are mounted in /media/$USER/
I've been had by a file manager like this before, such as Thunar or PCManFM.
It might be the file manager auto mounting the new partitions... I'll test that and report back. Thanks
getarmprofiles () {
    info "Getting package lists ready for $DEVICE $EDITION edition..."
    if [ -d "$TMPDIR/arm-profiles/" ];
    then
        cd $TMPDIR/arm-profiles
        git fetch origin 1> /dev/null 2>&1
	git reset --hard origin/master 1> /dev/null 2>&1
    else
        mkdir -p $TMPDIR
        chmod 777 $TMPDIR
        git clone https://gitlab.manjaro.org/manjaro-arm/applications/arm-profiles.git $TMPDIR/arm-profiles/ 1> /dev/null 2>&1
    fi
this part of the script wasn't working(for me). The "arm-profiles" are not downloaded and placed in the tmp directory. i've done it manually before running the script and now the installation went fine.
I wonder why this didn't work for you. Did the /var/tmp/ folder exist for you, or did you not have git installed?
git is installed and /var/tmp is present. Can it be that the "$TMPDIR/arm-profiles/" folder was present but empty for some reason? the script is checking the folder but i'm not sure about the content.
It would only exist and be empty, if you created the folder yourself. Or the script has run, creating the folder, but failed to do a git clone in it.
