nVidia target not found error
I’ve tried installing the nvidia driver using the cli commands in the user guide and using the GUI tool but both give me this error. I tried installing the LTS kernel but I wasn’t able to select in GRUB menu it just showed the 5.15 kernel.
This is on a fresh xcfe install. When I mostly found people saying their kernel was too new or out of date. What does that error reference to that there isn’t a target?
OS: Manjaro Linux x86_64
Kernel: 5.15.12-1-MANJARO
Uptime: 20 mins
Packages: 1079 (pacman)
Shell: bash 5.1.12
Resolution: 1920x1080
DE: Xfce 4.16
WM: Xfwm4
WM Theme: Matcha-sea
Theme: Adwaita-dark [GTK2/3]
Icons: Papirus-Maia [GTK2], Adwaita [GTK3]
Terminal: xfce4-terminal
Terminal Font: Monospace 12
CPU: Intel i7-8700K (12) @ 4.700GHz
GPU: NVIDIA GeForce GTX 1070
Memory: 1912MiB / 32037MiB
Error from GUI attempt but CLI shows same thing.
Starting
> Using config 'video-nvidia' for device: 0000:02:00.0 (0300:10de:1b81) Display controller nVidia Corporation GP104 [GeForce GTX 1070]
> Installing video-nvidia...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
 core downloading...
 extra downloading...
 community downloading...
 multilib downloading...
error: target not found: linux510-nvidia
error: target not found: linux515-nvidia
Error: pacman failed!
Error: script failed!
Done ...
Also possibly related I found that doing the first update after the install the mirror list some how defaulted to using ftp and i eventually found pacman-mirrors -i and that seemed to straighten out some other issues with packages installing older versions and conflicts.
Hello @jajao555,
that seems like you have problems with your package databases. Please try to update these first with the following command:
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
Then try to install the driver again.
@kisun thanks! That worked.
