Ok, this is likely the wrong spot to make this post, so if a mod can help me redirect it that would be great. I was expecting to find a “Manjaro ARM Beta8 with Plasma-Mobile (PinePhone)” thread, but one doesn’t exist yet (nor does a tag for Beta8 exist in github)… which is weird as I did apply an update today where pacman -Q <appname> revealed my kernel is linux-pinephone 5.14.12-1, pipewire is 1:03.38-1, and megapixels is 1.3.0-2… so beyond what Beta7 delivered. Unless that’s normal?
The Manjaro ARM 21.10 released! post is what inspired me to check check for and install updates, and although it does include mention of the pinephone in it… the pinephone is not listed in the “Supported Devices” list.
Anyway, below is what I wanted to report… so if this post does move, feel free to purge anything above this line.
Ran into issues on my Pinephone with the update via Discover today.
At some point I missed a message on the bottom of the phone (caught that it mentioned libtool tho)… and post install/reboot I was given a notification that the “package” had failed… with options to (1) Launch Discover or (2) Repair… neither which seemed to really trigger an action/change.
But once within Discover, I was informed there were no updates to install… so it made me question the notification.
Swapped to the terminal and ran sudo pacman -Syyu for a second opinion and learned two things:
Two packages I had installed were somehow newer… libtools and kpeoplevcard (likely what the missed message was about)
There was “nothing to do”… nothing further to update
Used pacman (sudo pacman -S <appname>) to re-install both packages which downgraded them to match the repository, ran sudo pacman -Syyu once more, and was only informed there was “nothing to do”.
Rebooted the phone to see it the notification resolved, but it repeated… which I eventually resolved by sudo rm /var/lib/PackageKit/offline-update-competed (yes, “completed” was spelled wrong).
The Beta releases of the PinePhone images are not tiedto strable updates as such. And yes, it’s normal that we don’t do a new Beta for Plasma Mobile for each stable update.
Discover on the PinePhone has been broken since the update of PackageKit and Pacman.
Likely those two packages was downgraded in the repo at some point.
If pacman says nothing to do, it can mean 2 things. Either you are completely up to date with the repo, or your mirror is out-of-date. To check for the latter you can run sudo pacman-mirrors -f5 && sudo pacman -Syyu.
Hi, sorry if this is a common question, but Google only pulls a rather old thread…Is there any updates regarding GPS connectivity? I haven’t seen much info other than that old thread mentioning that it wasn’t available at all…is there a roadmap for it? Or any buggy way of attempting to connect to it? I’d love to jump to manjaro-plasma, as I love everything else and how well it performs, but the lack of GPS seems to be my final stop before I can do so…
Posted this on Manjaro ARM Phosh as well, but this could be a flavour independent change
I would like to bring this topic to anybodies attention, if you would like to test it as well/give your opinion: Pinephone Discussion: using systemd-resolved as dns backend
