my usb device is not showing up and i think its corrupted ive changed 4 linux distros and im trying to change to ubuntu i have alrdy unplugged and plugged it back in and i also ran dmesg and this is what showed up when i unplugged it and plugged it back in : [ 7855.429151] usb 1-11: new high-speed USB device number 25 using xhci_hcd
[ 7855.626258] usb 1-11: New USB device found, idVendor=058f, idProduct=1234, bcdDevice= 0.02
[ 7855.626275] usb 1-11: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 7855.626281] usb 1-11: Product: AU87101A UFDISK
[ 7855.626287] usb 1-11: Manufacturer: ALCOR
[ 7855.626293] usb 1-11: SerialNumber: 123456789ABCDEF
[ 7855.628422] usb-storage 1-11:1.0: USB Mass Storage device detected
[ 7855.629042] scsi host6: usb-storage 1-11:1.0
[ 7856.648567] scsi 6:0:0:0: Direct-Access GENERIC USB FLASH DISK 7.76 PQ: 0 ANSI: 6
[ 7856.649257] sd 6:0:0:0: [sdb] Media removed, stopped polling
[ 7856.649500] sd 6:0:0:0: [sdb] Attached SCSI removable dis
Maybe there’s a Ubuntu forum than can help.
However, if you’re still on Manjaro, this may (or may not) help:
sudo pacman -S ntfs-3g
echo 'blacklist ntfs3' | sudo tee /etc/modprobe.d/disable-ntfs3.conf
Cheers.
Sloppy misspelled, run-on sentences will never help anyone help you. Please show some respect no matter where you post. I imagine you’re also cross posting on every forum or subreddit you can find until you find someone to spoon feed you. This is not the way.
Please see:
