Manjaro ARM 20.04 released!
We are proud to announce the release of Manjaro ARM 20.04!
We recommend re-installing using these images, because of major system changes between 20.02 and 20.04.
Currently we have download images for: Raspberry Pi 4, Rock Pi 4, RockPro64, Khadas Vim 1, Khadas Vim 3 and the Pinebook Pro.
Manjaro ARM is proud to also now be the default installation on the Pinebook Pro from Pine64.
We have put in a lot of work to get to this point and we are excited that we have been accepted by the creators of this laptop, as a great OS option.
We are also proud to now be part of the Manjaro infrastructure. This means our repositories are now available on a lot more mirrors around the world.
Thanks to the Manjaro Team for this upgrade.
eMMC flash image for Pinebooks
It's an image for supported laptops designed to flash Manjaro ARM to the built-in eMMC module, so you don't have to fiddle with DD and/or take out the eMMc module yourself.
Right now images for the Pinebook and Pinebook Pro are available in the download folders linked below, but will be named emmc-installer in addition to the regular filename.
These images will be available shortly after regular images release.
To use these images:
  1. Download the eMMC Installer image of your choice.
  2. Flash it to an SD card.
  3. Boot the SD card on the device.
  4. When the Manjaro logo has been present for about 15 seconds, press ESC (this is a bug, we know).
  5. Follow the instructions on the screen.
First Time setup
This release sports the First Time setup for all images, also via SSH. This means that at first boot, you will be asked about the following:
  • keyboard layout (except on pinebook, that is fixed to us layout)
  • username
  • additional user groups (optional)
  • full name
  • password for that username
  • password for root
  • timezone
  • locale
  • hostname
Then the setup script will set these settings and reboot to the login screen.
Screenshots
XFCE
KDE Plasma
Downloads:
Device XFCE KDE Plasma
Raspberrry Pi 4 20.04 20.04
Rock Pi 4 20.04 20.04
Pinebook Pro 20.04 20.04
RockPro64 20.04 20.04
Khadas Vim 1 20.04 20.04
Khadas Vim 3 20.04 20.04
Torrents are also available!
Features:
  • New packages from upstream and Manjaro ARM.
  • Manjaro now uses a branch based repo structure. Meaning you can now switch between arm-stable, arm-testing and arm-unstable branches by editing /etc/pacman-mirrors.conf.
  • All new images now use a 2 partition layout and use extlinux.conf where applicable. Devices not using extlinux are Raspberry Pi 4, Odroid N2 and Khadas Vims.
  • XFCE 4.14
  • KDE Plasma 5.18
  • Pinebook Pro now mutes Speaker audio when headphones are detected.
  • Odroid N2 images made with Manjaro ARM Installer now works from SD card too.
Updating from 20.02:
  • Please follow the instructions mentioned in the Another mirror transition thread, to use our new infrastruture and the latest stable update solution post to fix your Extlinux before you reboot.
  • We recommend re-installing the system, since we made major changes between the 20.02 and 20.04 releases, that are not part of package updates.
Known issues:
  • No audio cards on Odroid-C2, Odroid N2, Rock64 and Khadas Vim 3.
  • Bootsplash does not work on Raspberry Pi devices.
  • Bootsplash also seems to hide the First Time setup on XFCE images and the eMMC flasher images. To access it, power on device, wait for 30 seconds, then press ESC.
  • Lid Close trigger on the Pinebook Pro does not work on the XFCE edition.
Supported Devices:
Images:
  • Raspberry Pi 4 (tested on B)
  • Rock Pi 4
  • Pinebook Pro
  • RockPro64
  • Khadas Vim 1 (maintained by @spikerguy)
  • Khadas Vim 3 (maintained by @spikerguy)
With Manjaro ARM Installer (in addition to the above devices): (Download it here)
  • Raspberry Pi 3 (tested on B)
  • Pinebook
  • Odroid C2
  • Odroid N2
  • Rock64
  • Khadas Vim 2 (not tested)
  • Pine64-LTS / Sopine (tested on Pine64-LTS board, profile renamed from sopine to pine64-lts)
What about other devices?
Manjaro ARM no longer supports the armv7h architecture. So if you have/use an armv7h device, you should be looking at other distro's. Some could be:
  • Arch Linux ARM
  • Armbian
  • Raspbian (for the raspberrypi)
  • Ubuntu Mate
  • Parabola
The armv7h repo has been removed from the repo server and mirrors.
We won't be making images for all the supported devices. If your desired image for your desired supported device does not exist, please use manjaro-arm-installer to install it to an SD/eMMC card.
We already started releasing Alpha images for the PinePhone and PineTab.
Donation
Please consider supporting Manjaro ARM directly via Patreon, Ko-Fi or Open Collective.
You can also donate to our upstream, which is Arch Linux ARM.
Glad to see there is support for the Pi 3.
Hi,
I tried to build a 20.04 c2 image, something go wrong during the process
[nicolas@nls-pc ~]$ sudo buildarmimg -d oc2 -e kde-plasma -v 20.04 -n
[sudo] Mot de passe de nicolas :
==> Creating OEM image of kde-plasma for oc2...
  -> Removing old rootfs...
  -> Downloading latest aarch64 rootfs...
Manjaro-ARM-aarch64-latest. 100%[=========================================>] 184,38M   911KB/s    ds 3m 32s
  -> Extracting aarch64 rootfs...
  -> Setting up keyrings...
  -> Setting branch to stable...
::INFO Downloading mirrors from repo.manjaro.org
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
  ..... Australia      : http://manjaro.mirror.serversaustralia.com.au/
  0.480 Austria        : http://mirror.inode.at/manjaro/
  0.457 Austria        : http://mirror.easyname.at/manjaro/
  0.704 Austria        : ftp://mirror.easyname.at/manjaro/
  ..... Bangladesh     : http://mirror.xeonbd.com/manjaro/
  0.712 Belarus        : http://mirror.datacenter.by/pub/mirrors/manjaro/
  0.449 Belgium        : https://mirror.futureweb.be/manjaro/
  0.358 Belgium        : http://mirror.futureweb.be/manjaro/
  1.748 Brazil         : https://manjaro.c3sl.ufpr.br/
  1.877 Brazil         : http://linorg.usp.br/manjaro/
  0.826 Bulgaria       : https://mirrors.netix.net/manjaro/
  0.650 Bulgaria       : https://manjaro.ipacct.com/manjaro/
  0.716 Bulgaria       : http://manjaro.telecoms.bg/
  1.413 Canada         : https://mirror.csclub.uwaterloo.ca/manjaro/
  0.927 Canada         : https://osmirror.org/manjaro/
  1.857 Chile          : http://manjaro.dcc.uchile.cl/
  2.418 Chile          : https://mirror.ufro.cl/manjaro/
  2.471 China          : https://mirrors.tuna.tsinghua.edu.cn/manjaro/
  2.692 China          : https://mirrors.sjtug.sjtu.edu.cn/manjaro/
  1.650 Costa_Rica     : https://mirrors.ucr.ac.cr/manjaro/
  0.521 Czech          : https://mirror.dkm.cz/manjaro/
  0.476 Denmark        : https://mirrors.dotsrc.org/manjaro/
  0.864 Denmark        : https://www.uex.dk/public/manjaro/
  0.878 France         : https://mirror.oldsql.cc/manjaro/
  0.612 France         : https://manjaro.mcofficer.me/
  0.511 France         : https://manjaro.ynh.ovh/
  0.245 France         : http://ftp.free.org/mirrors/repo.manjaro.org/repos/
  0.431 France         : ftp://ftp.free.org/mirrors/repo.manjaro.org/repos/
  0.380 France         : http://kibo.remi.lu/
  ..... Georgia        : https://manjaro.grena.ge/
::ERROR Not Found 'https://manjaro.grena.ge/'
  ..... Georgia        : http://manjaro.grena.ge/
::ERROR Not Found 'http://manjaro.grena.ge/'
  0.523 Germany        : https://mirror.alpix.eu/manjaro/
  0.430 Germany        : https://mirror.23media.com/manjaro/
  0.377 Germany        : http://mirror.23media.com/manjaro/
  0.542 Germany        : https://ftp.halifax.rwth-aachen.de/manjaro/
  0.925 Germany        : ftp://ftp.halifax.rwth-aachen.de/manjaro/
  0.476 Germany        : http://ftp.tu-chemnitz.de/pub/linux/manjaro/
  0.795 Germany        : ftp://ftp.tu-chemnitz.de/pub/linux/manjaro/
  0.445 Germany        : https://mirror.netzspielplatz.de/manjaro/packages/
  0.552 Germany        : https://mirror.netcologne.de/manjaro/
  0.506 Germany        : https://manjaro.moson.eu/
  0.349 Germany        : http://manjaro.moson.eu/
  0.553 Germany        : https://manjaro.moson.org/
  0.435 Germany        : http://manjaro.moson.org/
  0.752 Greece         : https://ftp.cc.uoc.gr/mirrors/linux/manjaro/
  0.695 Greece         : http://ftp.cc.uoc.gr/mirrors/linux/manjaro/
  1.310 Greece         : ftp://ftp.cc.uoc.gr/mirrors/linux/manjaro/
  ..... Hong_Kong      : http://ftp.cuhk.edu.hk/pub/Linux/manjaro/
  ..... Hong_Kong      : ftp://ftp.cuhk.edu.hk/pub/Linux/manjaro/
  0.616 Hungary        : https://quantum-mirror.hu/mirrors/pub/manjaro/
  0.502 Hungary        : http://quantum-mirror.hu/mirrors/pub/manjaro/
  0.645 Hungary        : https://nova.quantum-mirror.hu/mirrors/pub/manjaro/
  0.481 Hungary        : http://nova.quantum-mirror.hu/mirrors/pub/manjaro/
  1.120 Iceland        : https://mirrors.opensource.is/manjaro/
  0.500 Iceland        : http://mirrors.opensource.is/manjaro/
  ..... Iceland        : ftp://mirrors.opensource.is/manjaro/
::ERROR ftp error: error_perm('550 Failed to change directory.') 'ftp://mirrors.opensource.is/manjaro/'
  1.350 India          : https://mirrors.piconets.webwerks.in/manjaro-mirror/
  0.949 India          : http://mirrors.piconets.webwerks.in/manjaro-mirror/
  1.293 Indonesia      : https://mirror.deace.id/manjaro/
  0.969 Indonesia      : http://mirror.deace.id/manjaro/
  1.928 Indonesia      : http://kartolo.sby.datautama.net.id/manjaro/
  0.634 Italy          : https://manjaro.mirror.garr.it/mirrors/manjaro/
  0.867 Italy          : https://ba.mirror.garr.it/mirrors/manjaro/
  0.984 Italy          : https://ct.mirror.garr.it/mirrors/manjaro/
  1.636 Japan          : http://ftp.riken.jp/Linux/manjaro/
  ..... Japan          : ftp://ftp.riken.jp/Linux/manjaro/
  1.820 Japan          : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/
  1.609 Kenya          : https://manjaro.mirror.liquidtelecom.com/
  1.195 Kenya          : http://manjaro.mirror.liquidtelecom.com/
  0.445 Netherlands    : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/
  0.613 Netherlands    : ftp://ftp.nluug.nl/pub/os/Linux/distr/manjaro/
  0.514 Netherlands    : http://ftp.snt.utwente.nl/pub/linux/manjaro/
  0.525 Netherlands    : ftp://ftp.snt.utwente.nl/pub/linux/manjaro/
  0.444 Netherlands    : https://mirror.koddos.net/manjaro/
  1.928 New_Zealand    : http://manjaro.mirrors.theom.nz/
  0.710 Norway         : http://mirror.terrahost.no/linux/manjaro/
  ..... Philippines    : http://mirror.rise.ph/manjaro/
  ..... Philippines    : ftp://mirror.rise.ph/manjaro/
  ..... Poland         : https://mirror.tuchola-dc.pl/manjaro/
  0.599 Poland         : http://ftp.vectranet.pl/manjaro/
  1.137 Poland         : ftp://ftp.vectranet.pl/manjaro/
  0.463 Portugal       : http://ftp.dei.uc.pt/pub/linux/manjaro/
  0.656 Russia         : https://mirror.yandex.ru/mirrors/manjaro/
  1.107 Russia         : http://mirror.truenetwork.ru/manjaro/
  3.367 Singapore      : https://download.nus.edu.sg/mirror/manjaro/
  1.327 South_Africa   : http://mirror.is.co.za/mirrors/manjaro.org/
  2.465 South_Korea    : https://mirror.d-tl.com/manjaro/
  0.812 Spain          : https://ftp.caliu.cat/pub/distribucions/manjaro/
  0.545 Spain          : http://ftp.caliu.cat/pub/distribucions/manjaro/
  0.558 Sweden         : https://ftp.lysator.liu.se/pub/manjaro/
  0.732 Sweden         : ftp://ftp.lysator.liu.se/pub/manjaro/
  0.555 Sweden         : https://mirror.zetup.net/manjaro/
  0.652 Switzerland    : https://manjaro.osmir.ch/
  0.530 Switzerland    : http://manjaro.osmir.ch/
  ..... Taiwan         : http://free.nchc.org.tw/manjaro/
  1.690 Thailand       : https://mirror.kku.ac.th/manjaro/
  1.300 Thailand       : http://mirror.kku.ac.th/manjaro/
  ..... Thailand       : ftp://mirror.kku.ac.th/manjaro/
  ..... Turkey         : http://ftp.linux.org.tr/manjaro/
  1.157 Turkey         : ftp://ftp.linux.org.tr/manjaro/
  0.549 Ukraine        : http://mirrors.colocall.net/manjaro/
  0.909 Ukraine        : ftp://mirrors.colocall.net/manjaro/
  0.288 United_Kingdom : http://repo.manjaro.org.uk/
  0.529 United_Kingdom : https://www.mirrorservice.org/sites/repo.manjaro.org/repos/
  0.299 United_Kingdom : http://manjaro.mirrors.uk2.net/
  1.236 United_States  : https://repo.ialab.dsu.edu/manjaro/
  1.006 United_States  : http://repo.ialab.dsu.edu/manjaro/
  0.789 United_States  : http://distro.ibiblio.org/manjaro/
  ..... United_States  : https://mirrors.ocf.berkeley.edu/manjaro/
  0.876 United_States  : https://mirror.math.princeton.edu/pub/manjaro/
  1.078 United_States  : https://mirror.clarkson.edu/manjaro/
  1.088 United_States  : https://mirrors.gigenet.com/manjaro/
  0.873 United_States  : http://mirrors.gigenet.com/manjaro/
::INFO Writing mirror list
::United_Kingdom  : http://repo.manjaro.org.uk/arm-stable
::United_Kingdom  : http://manjaro.mirrors.uk2.net/arm-stable
::Germany         : https://manjaro.moson.eu/arm-stable
::Belgium         : https://mirror.futureweb.be/manjaro/arm-stable
::Germany         : https://mirror.23media.com/manjaro/arm-stable
::France          : http://kibo.remi.lu/arm-stable
::France          : http://ftp.free.org/mirrors/repo.manjaro.org/repos/arm-stable
::Germany         : https://manjaro.moson.org/arm-stable
::Netherlands     : https://mirror.koddos.net/manjaro/arm-stable
::Germany         : https://mirror.netzspielplatz.de/manjaro/packages/arm-stable
::Portugal        : http://ftp.dei.uc.pt/pub/linux/manjaro/arm-stable
::Denmark         : https://mirrors.dotsrc.org/manjaro/arm-stable
::Austria         : http://mirror.inode.at/manjaro/arm-stable
::Hungary         : https://nova.quantum-mirror.hu/mirrors/pub/manjaro/arm-stable
::Hungary         : https://quantum-mirror.hu/mirrors/pub/manjaro/arm-stable
::France          : https://manjaro.ynh.ovh/arm-stable
::Czech           : https://mirror.dkm.cz/manjaro/arm-stable
::Germany         : https://mirror.alpix.eu/manjaro/arm-stable
::Netherlands     : http://ftp.snt.utwente.nl/pub/linux/manjaro/arm-stable
::United_Kingdom  : https://www.mirrorservice.org/sites/repo.manjaro.org/repos/arm-stable
::Switzerland     : https://manjaro.osmir.ch/arm-stable
::Spain           : https://ftp.caliu.cat/pub/distribucions/manjaro/arm-stable
::Germany         : https://mirror.netcologne.de/manjaro/arm-stable
::Sweden          : https://mirror.zetup.net/manjaro/arm-stable
::France          : https://manjaro.mcofficer.me/arm-stable
::Netherlands     : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/arm-stable
::Italy           : https://manjaro.mirror.garr.it/mirrors/manjaro/arm-stable
::Bulgaria        : https://manjaro.ipacct.com/manjaro/arm-stable
::Russia          : https://mirror.yandex.ru/mirrors/manjaro/arm-stable
::Austria         : http://mirror.easyname.at/manjaro/arm-stable
::Norway          : http://mirror.terrahost.no/linux/manjaro/arm-stable
::Belarus         : http://mirror.datacenter.by/pub/mirrors/manjaro/arm-stable
::Bulgaria        : http://manjaro.telecoms.bg/arm-stable
::Sweden          : https://ftp.lysator.liu.se/pub/manjaro/arm-stable
::United_States   : http://distro.ibiblio.org/manjaro/arm-stable
::Germany         : http://ftp.tu-chemnitz.de/pub/linux/manjaro/arm-stable
::Bulgaria        : https://mirrors.netix.net/manjaro/arm-stable
::Denmark         : https://www.uex.dk/public/manjaro/arm-stable
::Italy           : https://ba.mirror.garr.it/mirrors/manjaro/arm-stable
::United_States   : https://mirrors.gigenet.com/manjaro/arm-stable
::United_States   : https://mirror.math.princeton.edu/pub/manjaro/arm-stable
::France          : https://mirror.oldsql.cc/manjaro/arm-stable
::Ukraine         : http://mirrors.colocall.net/manjaro/arm-stable
::Germany         : https://ftp.halifax.rwth-aachen.de/manjaro/arm-stable
::Canada          : https://osmirror.org/manjaro/arm-stable
::India           : https://mirrors.piconets.webwerks.in/manjaro-mirror/arm-stable
::Indonesia       : https://mirror.deace.id/manjaro/arm-stable
::Italy           : https://ct.mirror.garr.it/mirrors/manjaro/arm-stable
::United_States   : https://repo.ialab.dsu.edu/manjaro/arm-stable
::United_States   : https://mirror.clarkson.edu/manjaro/arm-stable
::Russia          : http://mirror.truenetwork.ru/manjaro/arm-stable
::Poland          : http://ftp.vectranet.pl/manjaro/arm-stable
::Turkey          : http://ftp.linux.org.tr/manjaro/arm-stable
::Kenya           : https://manjaro.mirror.liquidtelecom.com/arm-stable
::Greece          : https://ftp.cc.uoc.gr/mirrors/linux/manjaro/arm-stable
::South_Africa    : http://mirror.is.co.za/mirrors/manjaro.org/arm-stable
::Canada          : https://mirror.csclub.uwaterloo.ca/manjaro/arm-stable
::Costa_Rica      : https://mirrors.ucr.ac.cr/manjaro/arm-stable
::Brazil          : https://manjaro.c3sl.ufpr.br/arm-stable
::Japan           : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/arm-stable
::Chile           : http://manjaro.dcc.uchile.cl/arm-stable
::Brazil          : http://linorg.usp.br/manjaro/arm-stable
::Indonesia       : http://kartolo.sby.datautama.net.id/manjaro/arm-stable
::New_Zealand     : http://manjaro.mirrors.theom.nz/arm-stable
::Australia       : http://manjaro.mirror.serversaustralia.com.au/arm-stable
::Chile           : https://mirror.ufro.cl/manjaro/arm-stable
::South_Korea     : https://mirror.d-tl.com/manjaro/arm-stable
::China           : https://mirrors.tuna.tsinghua.edu.cn/manjaro/arm-stable
::Taiwan          : http://free.nchc.org.tw/manjaro/arm-stable
::China           : https://mirrors.sjtug.sjtu.edu.cn/manjaro/arm-stable
::Hong_Kong       : http://ftp.cuhk.edu.hk/pub/Linux/manjaro/arm-stable
::Singapore       : https://download.nus.edu.sg/mirror/manjaro/arm-stable
::Philippines     : http://mirror.rise.ph/manjaro/arm-stable
::Japan           : http://ftp.riken.jp/Linux/manjaro/arm-stable
::Poland          : https://mirror.tuchola-dc.pl/manjaro/arm-stable
::Thailand        : https://mirror.kku.ac.th/manjaro/arm-stable
::United_States   : https://mirrors.ocf.berkeley.edu/manjaro/arm-stable
::Bangladesh      : http://mirror.xeonbd.com/manjaro/arm-stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
==> Installing packages for kde-plasma edition on oc2...
 core                                  215.5 KiB   937 KiB/s 00:00 [####################################] 100%
 extra                                   2.3 MiB  1090 KiB/s 00:02 [####################################] 100%
 community                               5.0 MiB  1116 KiB/s 00:05 [####################################] 100%
error: target not found: manjaro-settings-manager-knotifier
  -> Enabling services...
  -> Applying overlay for kde-plasma edition...
  -> Setting up system settings...
Enabling SSH login for root user for headless setup...
sed: impossible de lire /var/lib/manjaro-arm-tools/img/rootfs_aarch64/etc/ssh/sshd_config: Aucun fichier ou dossier de ce type
Enabling autologin for OEM setup...
Correcting permissions from overlay...
chown: impossible d'accéder à '/var/lib/manjaro-arm-tools/img/rootfs_aarch64/etc/polkit-1/rules.d': Aucun fichier ou dossier de ce type
  -> Cleaning rootfs for unwanted files...
==> oc2 kde-plasma rootfs complete
==> Finishing image for oc2 kde-plasma edition...
  -> Creating partitions...
  -> Copying files to image...
mv: impossible d'Ă©valuer '/var/lib/manjaro-arm-tools/tmp/root/boot/*': Aucun fichier ou dossier de ce type
  -> Flashing bootloader...
  -> Cleaning up image...
  -> Compressing Manjaro-ARM-kde-plasma-oc2-20.04.img...
Manjaro-ARM-kde-plasma-oc2-20.04.img (1/1)
  100 %       126,4 MiB / 918,0 MiB = 0,138    19 MiB/s       0:47
  -> Removing rootfs_aarch64
==> Time : 9.03 minutes...
[nicolas@nls-pc ~]$
yes. Your arm-profiles is out of date. Please update them.
Sorry, I follow the [Wiki] Contributing to Manjaro-ARM and the issue come back
I did maybe something wrong.
==> Creating image of kde-plasma for oc2...
Manjaro-ARM-aarch64-latest. 100%[=========================================>] 184,38M   888KB/s    ds 3m 23s
  -> Setting branch to arm-stable...
  2.034 Kenya          : https://manjaro.mirror.liquidtelecom.com/
  1.178 Kenya          : http://manjaro.mirror.liquidtelecom.com/
  0.794 Russia         : http://mirror.truenetwork.ru/manjaro/
  0.584 Italy          : https://manjaro.mirror.garr.it/mirrors/manjaro/
  1.818 Taiwan         : http://free.nchc.org.tw/manjaro/
 core                                  215.5 KiB   798 KiB/s 00:00 [####################################] 100%
 extra                                   2.3 MiB  1486 KiB/s 00:02 [####################################] 100%
 community                               5.0 MiB  1539 KiB/s 00:03 [####################################] 100%
  100 %       126,1 MiB / 918,0 MiB = 0,137    19 MiB/s       0:48
==> Time : 6.57 minutes...
[nicolas@nls-pc ~]$
You need to run sudo getarmprofiles -f.
Your profiles are still not up to date.
ok
[nicolas@nls-pc ~]$ sudo getarmprofiles -f
Forcing git update...
Clonage dans 'arm-profiles'...
remote: Enumerating objects: 53, done.
remote: Counting objects: 100% (53/53), done.
remote: Compressing objects: 100% (53/53), done.
remote: Total 15444 (delta 14), reused 0 (delta 0), pack-reused 15391
RĂ©ception d'objets: 100% (15444/15444), 28.17 Mio | 1.13 Mio/s, fait.
RĂ©solution des deltas: 100% (2039/2039), fait.
[nicolas@nls-pc ~]$ sudo pacman -Syyu
:: Synchronising package databases...
 core                                  171,2 KiB  1662 KiB/s 00:00 [####################################] 100%
 extra                                2000,8 KiB  1704 KiB/s 00:01 [####################################] 100%
 community                               5,9 MiB  1842 KiB/s 00:03 [####################################] 100%
 multilib                              192,5 KiB  1552 KiB/s 00:00 [####################################] 100%
 manjaro-strit                          15,9 KiB   397 KiB/s 00:00 [####################################] 100%
 there is nothing to do
[nicolas@nls-pc ~]$
Nice, it works to create image for c2 and n2.
c2 and n2 reboot :slight_smile:
n2 is very slow to reboot...
Not sure if this a bug that has been there all along, but even if I set my keyboard to Norwegian during setup, it's still english in Xorg. (XFCE/rpi4)
Did you change it in Manjaro Settings Manager?
Yes, that works.
But when it says it's using "System default" it's lying :wink: Because in console, I get norwegian layout.
Sorry, I misunder stood what you asked.
In Manjaro Settings Manager is says it's using a norwegian layout. It's just that XFCE (and/or Xorg) ignores that. I have to set keyboard to norwegian in XFCE as well.
Thank you for your hard work and continue improvement :slight_smile:
Since this update I have a big problem with sd card reader on my PBP (can't boot and can't read any sd card from fresh install on emmc).
For information, I installed Manjaro on emmc and sd card (emmc was my old installation, not used anymore).
What I did :
I tried to update installation on my sd card (modified mirrors and extlinux file) and did an "update" of uboot with provided commands :
sudo dd if=/boot/idbloader.img of=/dev/mmcblk2 seek=64 conv=notrunc
sudo dd if=/boot/u-boot.itb of=/dev/mmcblk2 seek=16384 conv=notrunc
After reboot, my PBP have an orange power light and become green after some seconds but sd card doesn't boot anymore.
If I remove my sd card I can boot on my old installation on emmc.
I flashed my emmc with usb adaptor with this new image (20.04) and booted successfully on it.
But now, I still can't boot on sd card and cant mount any other sd card.
I have tried with gdisk but I can't create any partition, and can't mount any partition, dmesg always show me something like
[ 2337.952651] mmcblk1: recovery failed!
[ 2337.952713] blk_update_request: I/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 2337.952732] Buffer I/O error on dev mmcblk1, logical block 0, async page read
[ 2337.952869] Dev mmcblk1: unable to read RDB block 0
I tried a second time to update uboot but with the same result.
Do you have any idea about this problem ?
Hi,
What is the best graphic option for the c2 ?
I found some drivers on the Mali website, I hope it will be helpful
Mali drivers web site
You are posting in the 20.04 image release thread, so I assume you have downloaded the 20.04 image, flashed that and boot that on your PBP.
If that's not the case, please read the ARM Stable Update announcement's Known Issues and Solutions post:
I don't know which is best, but if you install the x11 one, it will probably install the others as dependencies.
I haven't used a GUI on the C2 for years now.
Hi,
Thanks for your reply, I try it and come back later with my feedback.
So, I tested X11 and the 2 other drivers, I feel no difference, I keep the 20.02 image for the c2 :slight_smile:
the c2 reboot without problem with the screen plugged on it or the hdmi dummy
The kde short cut are working well for c2 and n2 (20.02 and 20.04 image)
have a good day.
You don't use the gui with the c2? you use the minimal version, you are a power user, for sure.
I use my C2's as part of my build server, so yeah, they are minimal versions.
