Manjaro-Arm 18.12.1 - 3B+ - Turning off bluetooth
#1
The mainline kernel doesn’t come with the device tree overlays (.dtbo) - afaik.
On the RPI kernesl there’s been an overlay to turn off bluetooth:
dtoverlay=pi3-disable-bt
I already tried to blacklist the modules with no effect.
Any hints are appreciated.
Thx.
#2
Maybe just stop and disable the bluetooth service?
sudo systemctl stop bluetooth && sudo systemctl disable bluetooth
#3
The best method to disable bluetooth is to add the following entry to the configuration file:
/etc/modprobe.d/blacklist.conf
Add this line to the conf file:
install bluetooth /bin/false
Save the changes to with root privileges, and exit your text editor.
Next we must totally disable the bluetooth service:
sudo systemctl mask bluetooth
Then, restart.
#4
@tbg
Your bruteforce :wink: method did the trick!
Great. Thx a lot.
Just disabling the service would not cut it.
I’m wondering if this “process” could be introduced when disabling Bluetooth
from the GUI (what I tried in the first place) !?!?
Thx again.
#5
Glad to hear that worked.
Please mark your thread solved.
#6
That would entirely depend on the GUI application you use to disable it. :slight_smile:
I maintain nothing related to bluetooth, so that would be an upstream suggestion. :slight_smile:
#7
I used this command:
gsettings set org.blueman.plugins.powermanager auto-power-on false
