Manjaro-architect z-release 0.9.20
#22
There is no new iso. Only the installer got updated, and the iso automatically downloads the newest version. If you need a newer iso, you can use any manjaro iso, manjaro-architect is included with all editions.
#23
I will look into the font issue when I have time.
#24
Thank you for your time. I hope this issue also got fixed as well when i fire up my 18.0 architect iso any time im feeling adventurous again soon.
#25
I installed from a legacy boot install to a USB thumb drive and had to wait 5-10 minutes for grub to install (was doing other things). No activity at all in htop during this period.
#26
The fix is pushed to the git, but the package is not yet updated.
#27
I uploaded the version with fixed legacy-boot as manjaro-architect-dev to the unstable and testing repos. If someone can test it and confirm that it works, I can upload the fixes to the regular package.
#28
I can test later, but have to go out shortly.
#29
I triedto test it in virtualbox, but it works poorly with kde. So I just uploaded 0.9.21 to unstable, let’s see what happens
#30
Ooops - completely forgot. Testing now - I have the dev version is that correct?
#31
Duplication of mirrors, a problem @cscs spotted earlier in the week:
Moson.eu @fhdk
#32
I still cannot reproduce it (the probing of different protocols for the same mirror is normal and expected) (my sample below is from unstable - but has no bearing, just use whatever branch you are using)
~ >>> pacman-mirrors -v
Version 4.14.1
~ >>> sudo pacman-mirrors -c Germany,United_Kingdom
[sudo] password for fh:
::INFO Downloading mirrors from repo.manjaro.org
::INFO User generated mirror list
::INFO Custom mirror file saved: /var/lib/pacman-mirrors/custom-mirrors.json
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
  0.233 Germany        : https://mirror.alpix.eu/manjaro/
  0.152 Germany        : http://mirror.ragenetwork.de/manjaro/
  0.268 Germany        : https://mirror.netzspielplatz.de/manjaro/packages/
  0.187 Germany        : https://manjaro.moson.eu/
  0.130 Germany        : http://manjaro.moson.eu/
  0.174 United_Kingdom : http://mirror.catn.com/pub/manjaro/
  ..... United_Kingdom : http://repo.manjaro.org.uk/
  0.151 United_Kingdom : http://manjaro.mirrors.uk2.net/
::INFO Writing mirror list
::Germany         : https://manjaro.moson.eu/unstable
::United_Kingdom  : http://manjaro.mirrors.uk2.net/unstable
::Germany         : http://mirror.ragenetwork.de/manjaro/unstable
::United_Kingdom  : http://mirror.catn.com/pub/manjaro/unstable
::Germany         : https://mirror.alpix.eu/manjaro/unstable
::Germany         : https://mirror.netzspielplatz.de/manjaro/packages/unstable
::United_Kingdom  : http://repo.manjaro.org.uk/unstable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
Please list your custom-mirrors.json file
cat /var/lib/pacman-mirrors/custom-mirrors.json
Then reset your mirror pool
sudo pacman-mirrors -call -m random
Then rebuild your custom mirrorpool - and post the terminal output
sudo pacman-mirrors -c United_Kingdom,Germany
#33
@fhdk - this was from a fresh architect install.
I can list the info, but is it relevant? Does architect use my mirrors? Dunno :smiley:
       "country": "Germany",
       "protocols": [
           "https"
       "url": "https://mirror.alpix.eu/manjaro/"
       "protocols": [
           "https"
       "url": "https://mirror.netcologne.de/manjaro/"
       "protocols": [
           "https",
           "http"
       "url": "https://manjaro.moson.eu/"
       "protocols": [
           "https",
           "http"
       "protocols": [
           "https",
           "http"
       "protocols": [
           "https",
           "http"
       "protocols": [
           "https",
           "http"
       "protocols": [
           "https",
           "http"
       "protocols": [
           "https",
           "http"
       "protocols": [
           "https",
           "http"
       "protocols": [
           "https",
           "http"
       "protocols": [
           "https",
           "http"
       "protocols": [
           "https",
           "http"
       "protocols": [
           "https",
           "http"
       "protocols": [
           "https",
           "http"
       "protocols": [
           "https",
           "http"
       "protocols": [
           "https",
           "http"
       "protocols": [
           "https",
           "http"
       "country": "United_Kingdom",
       "protocols": [
           "http"
       "url": "http://mirror.catn.com/pub/manjaro/"
       "protocols": [
           "https"
       "url": "https://www.mirrorservice.org/sites/repo.manjaro.org/repos/"
       "protocols": [
           "http"
       "url": "http://manjaro.mirrors.uk2.net/"
#34
As I suggested in another thread you have your moson.eu doubled (and more :laughing: ) in your custom-mirrors.json - please reset as described - and yes architect uses the pacman-mirrors settings on the host computer.
Relevant? Absolutely - because your headache is in that file as I can count the moson.eu entry 16 times
       "protocols": [
           "https",
           "http"
       "protocols": [
           "https",
           "http"
On a far fetched idea - I tried to run the --interactive on a custom-mirror pool.
That is first I did a reset of the entire pool
sudo pacman-mirrors -call -mrandom
Then I did a country selection and selected everything on the list
sudo pacman-mirrors -c Germany,United_Kingdom -i
Then I did a new --interactive but without the country selection
sudo pacman-mirrors -i
And to my surprise - I have a list with doubled entries and it also appears to be only mirrors which offers several protocols.
Why some would do that I cannot figure out but I can reconstruct the issue.
Now that I know how to do it - I might be able to fix it.
Have a lot of packages been downgraded in unstable?
#35
:smiley: :smiley: Have reset as instructed.
Anyway back on topic - install went fine, grub installed, with no noticeable time problems. (from KDE, to KDE on usb).
#36
Great success! So, it is uploaded as 0.9.21 in unstable, I’ll push it to other branches then. Then I can move on to the next projects.
#37
@Chrysostomus so what was the problem?
#38
Grub-install had a massive delay inside chroot. Making /run/lvm available inside the chroot fixed it.
