manjaro architect v0.9.29 mounting partition bug
I have the following setup:
[manjaro manjaro]# lsblk
NAME                          MAJ:MIN RM   SIZE RO TYPE  MOUNTPOINT
loop0                           7:0    0  17.9M  1 loop  /run/miso/sfs/livefs
loop1                           7:1    0 480.3M  1 loop  /run/miso/sfs/mhwdfs
loop2                           7:2    0   1.4G  1 loop  /run/miso/sfs/desktopfs
loop3                           7:3    0 510.7M  1 loop  /run/miso/sfs/rootfs
sda                             8:0    1   7.2G  0 disk
├─sda1                          8:1    1   2.4G  0 part
└─sda2                          8:2    1     4M  0 part
sdb                             8:16   1  28.8G  0 disk
├─sdb1                          8:17   1    21G  0 part
├─sdb2                          8:18   1   3.9G  0 part  /run/miso/bootmnt
└─sdb3                          8:19   1   3.9G  0 part
nvme0n1                       259:0    0 953.9G  0 disk
├─nvme0n1p1                   259:2    0     2G  0 part
├─nvme0n1p2                   259:5    0     2G  0 part
└─nvme0n1p3                   259:6    0   600G  0 part
  └─root                      254:0    0   600G  0 crypt
    ├─vg01-manjaro--kde--root 254:1    0    20G  0 lvm
    └─vg01-home               254:2    0   100G  0 lvm
and after correctly setting the root mount, NO Swapfile, and the /home extra mount, I end with the following mount options:
├─nvme0n1p1                   259:2    0     2G  0 part  /mnt/boot
    ├─vg01-manjaro--kde--root 254:1    0    20G  0 lvm   /mnt/home
    └─vg01-home               254:2    0   100G  0 lvm   /mnt/home
That is for some reason the manjaro architect mounts the root partition to the /mnt/home.
Btw; where can I find the source for the manjaro architect?
Thank you.
Btw, now I've restarted the manjaro architect...and cannot replicate the issue anymore. Should I submit the bugreport on the github or just leave it be?
I think someone else reported a similar issue, but I couldn't replicate it. It might be an issue with the live environment? I think opening an issue is a good idea
I think this happens when you mount partitions twice
This topic was automatically closed after 90 days. New replies are no longer allowed.
