On KDE Desktop Enviroment -
After Latest Update about the middle of November 2020/11, several -git packages were installed, making it cross dependent on several others -Git packages.
On a fresh installation if you use Manjaro Architect Installer even if you choose Stable Branch, the -git developer packages are installed, giving the same problem, like digiKam failing to start and others, if you Install from the normal installer, no -git packages are used and everything seems OK!
