I’m a beginner on manjaro. Until yesterday my external HD was working well on manjaro, but today it can’t be mounted.
I tryed to run : “mount /dev/sdb1” on terminal, and the aswer is
mount: /dev/sdb1 can’t find in /etc/fstab
Somebody can help me, please?
I can’t format this external HD, I don’t wanna lose all my data.
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=2dd7c3c2-02d4-4ae5-ba30-ce854613e02e / ext4 defaults,noatime 0 1
~ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 931.5G 0 disk
└─sda1 8:1 0 931.5G 0 part /
sdb 8:16 0 931.5G 0 disk
└─sdb1 8:17 0 931.5G 0 part
sr0 11:0 1 1024M 0 rom
So … because the path or UUID is not associated with anything in /etc/fstab then it does not know what to do … because the syntax is mount /dev/X /mountpoint and you did not provide the mountpoint.
Therefor, without assuming the existence of the directory, you could execute;
sudo mkdir -p /mnt/external
sudo mount /dev/sdb1 /mnt/external
