Hello!
Can someone please tell me how to change the size of the virtual keyboard on the login screen and lockscreen? I am using KDE on a machine with nvidia graphics. The problem is that it is huge and will fill the top half of the screen when activating it. Thus ‘‘blocking’’ username/password part. Am I correct by assuming that I need to change some plasma config file?
Thanx
Hello,
Yes, you are correct, but you would have to implement more to the code of what exists following this standards:
https://doc.qt.io/qt-5/qtvirtualkeyboard-deployment-guide.html
For now the qt5-virtualkeyboard
is made to use the entire width of the screen and would require a heavy amount of programming skills to change it.
You could probably fill a feature request to KDE Plasma developers.
Your answer is clear. Too bad that there is no easy solution. Perhaps future updates will have that option.
Thanx
