Atleast it loaded the firmware.
Check if you can see wireless in this command
inxi -N
inxi -N
This is what I got
[g@gpine ~]$ inxi -N
Device-1: rk3399-gmac driver: rk_gmac_dwmac
[g@gpine ~]$
Did you restart the system after the rename ?
There is no Wireless found, so Idk what needs to be done in this case.
Without the hardware it is hard to figure the issue. Maybe it is best to use a usb dongle until someone finds the fix.
Maybe you can try to connect with someone on Pine64 forum who has this hardware and is using either Manjaro or Arch linux.
Good Luck.
For every action I took I rebooted the system. Yes, getting a dongle seems the best idea for now.
Thanks a lot!
