With pleasure I’ve installed Manjaro on my Sdcard for my RockPro64.
But now my WiFi isn’t working? Although the bluetooth is working. I already tried the to install some of the AP6**** drivers available on the AUR resp. And I did rebooted the RockPro after each time I installed a driver. But no luck.
Thanks for your quick reply. I’ve just seen that the Wifi board they sell now on Pine64.com is different then the one that I have. I’ve got mine a couple years now and it’s this one:
Note: This module compatible with ROCKPro64 SBC.
Based on AMPAK AP6359SA Combo Module and made specifically for the ROCKPro64 SBC.
This module has simultaneous dual band – which is critical for low latency wireless streaming for gaming
IEEE 802.11 AC/A/B/G/N dual band 2.4GHz/5GHz 2T2R MIMO WiFi with Real-time Simultaneous Dual Band (RSDB) and Bluetooth 4
Support SDIO Interface and HS-UART Mixed Interface.
Looks like ap6359SA uses the Broadcom chipset BCM4359 and support was supposed to be in the kernel according to mrfixit here in this dated thread. He found one source for firmware that works and gave a link. There are 3 “Add AP6359SA firmware” files there. I do not have the addon module to test as it is not available anymore. I do not know if just adding the 3 firmware files to /usr/lib/firmware/brcm/ will now work or not or if the .dts also needs to be modified or time has passed this chipset by.
Hmmm… I’ve downloaded those files and wanted to copy to them to that directory. But it won’t let me.
And looked around in that directory and there seems already a file for that BCM4359.
You where bit too early I’ve just found out that worked instead of dragging. Still no luck with the Wifi firmware. Do I maybe need to change some register file to load the firmware?
Good choice. It just is not feasible for us to support any device that is obsolete. As time goes by with the newer kernels the support for the obsolete devices will disappear.
copy this file to this directory with the name /usr/lib/firmware/brcm/brcmfmac4359-sdio.pine64,rockpro64-v2.1.txt
or /usr/lib/firmware/brcm/brcmfmac4359-sdio.pine64,rockpro64.txt
Depending on the dtb you’r using, check that from /boot/extlinux/extlinux.conf but looking at the dmesg it is using v2.1 are you sure your board is v2.1 ?
