An NVIDIA kernel module 'nvidia' appears to already be loaded in your kernel.
This may be because it is in use (for example, by an X server, a CUDA program, or
the NVIDIA Persistence Daemon), but this may also happen if your kernel was
configured without support for module unloading. Please be sure to exit any
programs that may be using the GPU(s) before attempting to upgrade your driver.
If no GPU-based programs are running, you know that your kernel supports module
unloading, and you still receive this message, then an error may have occurred
that has corrupted an NVIDIA kernel module's usage count, for which the simplest
remedy is to reboot your computer.
I am a new user. I have a Monster laptop with İntel Core i7 and GTX 1650. What should I do?
