i go to konsole and type anaconda-navigator there’s nothing to show or found.
there nothing in the search bar of task manager too.
what should i do?
i download the anaconda on AUR the full size is 3.3gb.
Anaconda Navigator is a desktop graphical user interface (GUI) included in Anaconda® distribution…
https://docs.anaconda.com/anaconda/navigator/
Isn’t it included in the anaconda
package?
See all files installed by anaconda
pamac list -f anaconda
or
pacman -Ql anaconda
If you only want to narrow the results, you can use grep
. For example, the following will list the included binaries in /usr/bin/
pamac list -f anaconda | grep /usr/bin/
or
pacman -Ql anaconda | grep /usr/bin/
Assuming that you have set up anaconda and initiated it, you need to run anaconda-navigator
from terminal. If that doesn’t work and Anaconda spills our an error regarding DISTRO = NAME then you need to update anaconda navigator, this has happened to me. My issue was resolved by conda install anaconda-navigator
If you Wont solve this problem refer to this video.
https://www.youtube.com/watch?v=cMRdYqpPKIEThe conda update anaconda-navigator
shown in the Youtube video fixed the UnboundLocalError
