Kernel: 5.8.3-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/vmlinuz-5.8-x86_64
root=UUID=eb1b3616-27ac-418c-9754-9ff4a3e014a2 rw quiet apparmor=1
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: Dell product: Vostro 14-3468 v: N/A serial: <filter>
Chassis: type: 9 serial: <filter>
Mobo: Dell model: 0VCX0K v: A00 serial: <filter> UEFI [Legacy]: Dell
v: 2.6.0 date: 05/15/2018
ID-1: BAT0 charge: 28.8 Wh condition: 29.1/41.4 Wh (70%) volts: 17.2/14.8
model: SMP DELL VN3N047 type: Li-ion serial: <filter> status: Charging
Topology: Dual Core model: Intel Core i7-7500U bits: 64 type: MT MCP
arch: Amber Lake family: 6 model-id: 8E (142) stepping: 9 microcode: D6
L2 cache: 4096 KiB
bogomips: 23209
Speed: 1569 MHz min/max: 400/3500 MHz Core speeds (MHz): 1: 1160 2: 1168
3: 1120 4: 1245
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:5916
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-5:2 chip ID: 0c45:6a05
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 112 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.1.6
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71
Sound Server: ALSA v: k5.8.3-2-MANJARO
Local Storage: total: 465.76 GiB used: 27.87 GiB (6.0%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 2D scheme: GPT
ID-1: / raw size: 44.91 GiB size: 43.96 GiB (97.87%)
used: 15.14 GiB (34.4%) fs: ext4 dev: /dev/sda8
ID-2: /boot raw size: 6.00 GiB size: 5.84 GiB (97.39%)
used: 126.0 MiB (2.1%) fs: ext4 dev: /dev/sda4
ID-3: /home raw size: 71.04 GiB size: 69.42 GiB (97.72%)
used: 11.14 GiB (16.0%) fs: ext4 dev: /dev/sda14
ID-4: /opt raw size: 26.42 GiB size: 25.88 GiB (97.96%)
used: 1.48 GiB (5.7%) fs: ext4 dev: /dev/sda15
ID-1: swap-1 type: partition size: 7.45 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda10
System Temperatures: cpu: 48.0 C mobo: 44.0 C
Fan Speeds (RPM): cpu: 0
Processes: 200 Uptime: 5h 03m Memory: 7.44 GiB used: 1.73 GiB (23.3%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages:
pacman: 1337 lib: 363 flatpak: 0 Shell: Zsh v: 5.8 running in: alacritty
inxi: 3.1.05
