Manjaro 32 - question
i am in the exactly the same situation as tonio. where can i get updates for a probable coming 32 bit support? can i still use the os as i have it now? i just need it for a browser
Manjaro32 only exist as an ISO - manjaro32 has been removed from the mirrors.
You can continue to use your system as it is - but no updates - your only avenue for updates is to convert the system to https://archlinux32.org/
thanks for your help. is there a way to install new software to my machine? pacman does not show any available apps. thank you very much
Only if you migrate to Arch 32.
