17 posts were split to a new topic: BTRFS, Grub, and kernels on Zetar
It is aligned with the fact that Manjaro Summit is based on BTRFS as well. The user has still the option to change to ext4 or other file systems in auto partitioning.
I personally donât have any problem to change the partition if i would reinstall my system.
I wrote this only for one reason, because i had the unexperienced Windows to Linux switcher in mind⌠who maybe press auto install.
Yeah im aware there are some Proâs but there are many conâs also or maybe did that changed in the last 12 monthâs. You may remember a few topics where we was talking about the Proâs and the Conâs from BTRFS?
Maybe i miss something? I remember slightly where you disagreed with me that BTRFS is not the standard for a Manjaro install (i had mistaken the install procedure with nobara distro at this time) but where you agreed with me that BTRFS shouldnât be default install for Manjaro⌠maybe around 2 yearâs ago? What changed your mind or maybe i cant remember correctly?
I remember slightly where several people in this forum could easily lost their files, where a partition mistake happen and no one could help him in this forum.
That some snapshots because of BTRFS are weaker than Rsync. And additional the BTRFS snapshotâs was very difficult to rollback in some cases.
I remember also a guide from yourself, where you point in one of your help topicâs⌠what for additional steps the BTRFS user has to do if he donât use ext4, when he run into errors that he have to fight first the BTRFS hurdle.
Are this conâs are all history? Then maybe my viewpoint are total outdated about the dangers from BTRFS⌠that made me evade this filesystem in the past (no matter what). Even if i like the Proâs and wished that some of them introduced to ext4, like the autochecksum check⌠which sounds really nice but the write protection for partition looks very confusing⌠where i donât know if this is now the BTRFS feature or is my SSD dieing and went into write protection. ![]()
I saw you posted it countless times ![]()
Not alone that iâam a die-hard hardcore gamer and Manjaro is the right distro for me⌠i also think that Manjaro itself presented himself in a total differend light as you see what Manjaro is or should be.
For exactly this people it worried me this BTRFS changes⌠and yeah, i remember when i did this pacnew changes 2 yearâs ago.
But in which errors did this unexperienced people run from their unmaintend pacnew files? Nothing that comes close as a BTRFS Partition⌠where you can face a horror case if you use it blindly⌠and this wonât happend with ext4.
I think that ext4 is much more consumer friendly.
BTRFS is the way to go. We introduced auto-snapshots on major pacman -Syu cmds and updates with pamac. So everyone gets an easy way to roll back to a working install when using BTRFS. That is why it will be userfriendly in the end.
This has nothing to do with me. The default filesystem for Manjaro has up until now always been ext4, but now the Manjaro Team has decided that a fresh install with Manjaro 25.0.0 Zetar will be using btrfs by default, because this is also what the Summit edition of Manjaro will be using.
Nonsense. But btrfs snapshots are not backups. They reside on the same filesystem as the one that was snapshotted, and so if the drive dies, those snapshots are not going to save the day.
Backups should always be stored on a physically separate medium.
No, that was simply because of the fact that manjaro-chroot doesnât work with btrfs. It was designed for ext4 only.
Isnât going to happen. ext4 is an end-of-the-line filesystem. It has taken the ext filesystem family as far as possible, and even its developer says that btrfs is a much better and much more modern filesystem.
I do not know whether SSDs can enter a read-only mode in and of themselves, but mounting a filesystem â or in the event of btrfs, a subvolume â read-only is the same as you would do it with ext4, xfs, jfs, or whatever else.
Look, there is no way around it: people who are new to GNU/Linux â and especially so Manjaro or another Arch derivative â are going to have to assume a certain degree of responsibility. If they cannot do that, then perhaps they should stick to the operating system they came from.
Thereâs a huge difference between paying for an airplane ticket and flying an F-22 Raptor. In a Raptor, you hold the throttle and the stick, and thereâs no stewardess coming to serve you coffee.
I really donât understand where you are getting that misinformation, but misinformation it is.
btrfs is more robust than ext4 or even xfs. But every time you think youâve made something idiot-proof, the universe creates a bigger idiot.
Itâs simpler, but thatâs all there is to it.
