Manjaro 21.1.6 optimus manager problems
I am a beginner to linux, and I choose manjaro as my first distribution to try.
The problem is that I have a laptop with a rtx3060 card with optimus, and followed this guide to install optimus manager.
After I installed optimus-manager and optimus-manager-qt and rebooted, it showed a black screen. Fortunately, I was able to get into tty2 and remove optimus-manager, which solved the booting problem. However, I really want to turn my dgpu off when I don’t need it. I reinstalled it twice, but it did not work :frowning: Please help
This is my inxi output
  Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=7f58f1cc-3760-4b3c-9516-da87689cd890 rw quiet apparmor=1
  Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: ASUSTeK product: ROG Zephyrus M16 GU603HM_GU603HM
  v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: GU603HM v: 1.0 serial: <filter>
  UEFI: American Megatrends LLC. v: GU603HM.312 date: 09/23/2021
  ID-1: BAT0 charge: 28.4 Wh (36.5%) condition: 77.8/90.0 Wh (86.4%)
  volts: 15.9 min: 15.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
  status: Charging cycles: 113
  RAM: total: 15.31 GiB used: 2.12 GiB (13.8%)
  Info: 8-Core model: 11th Gen Intel Core i9-11900H bits: 64 type: MT MCP
  arch: Tiger Lake family: 6 model-id: 8D (141) stepping: 1 microcode: 2C
  cache: L2: 24 MiB bogomips: 79888
  Speed: 1048 MHz min/max: 800/4800 MHz Core speeds (MHz): 1: 1048 2: 1088
  3: 1614 4: 801 5: 801 6: 801 7: 1704 8: 4410 9: 2753 10: 801 11: 801 12: 796
  13: 1294 14: 4245 15: 1479 16: 1885
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni
  avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
  avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2 cdp_l2 clflush
  clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl
  dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma
  fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify
  hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single
  lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
  nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
  pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
  sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
  ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
  tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave
  xsavec xsaveopt xsaves xtopology xtpr
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: ASUSTeK driver: i915
  v: kernel bus-ID: 0000:00:02.0 chip-ID: 8086:9a60 class-ID: 0300
  Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
  driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm
  bus-ID: 0000:01:00.0 chip-ID: 10de:2520 class-ID: 0300
  Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
  bus-ID: 3-2:2 chip-ID: 13d3:5458 class-ID: fe01 serial: <filter>
  loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa display-ID: :0
  screens: 1
  Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.7x16.7")
  s-diag: 798mm (31.4")
  Monitor-1: eDP-1 res: 2560x1600 hz: 165 dpi: 189 size: 344x215mm (13.5x8.5")
  diag: 406mm (16")
  OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 21.2.3
  direct render: Yes
  Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
  chip-ID: 8086:43c8 class-ID: 0403
  Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
  bus-ID: 0000:01:00.1 chip-ID: 10de:228e class-ID: 0403
  Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.38 running: yes
  vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 0000:2d:00.0
  IF: eno2 state: down mac: <filter>
  Device-2: MEDIATEK vendor: AzureWave driver: mt7921e v: kernel port: N/A
  bus-ID: 0000:2f:00.0 chip-ID: 14c3:7961 class-ID: 0280
  Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
  bus-ID: 3-14:5 chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
  v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 953.87 GiB used: 11.73 GiB (1.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL21T0HCLR-00B00
  size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
  lanes: 4 type: SSD serial: <filter> rev: GXA7301Q temp: 58.9 C scheme: GPT
  ID-1: / raw-size: 234.91 GiB size: 230.17 GiB (97.98%)
  used: 11.68 GiB (5.1%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
  label: N/A uuid: 7f58f1cc-3760-4b3c-9516-da87689cd890
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
  used: 49.3 MiB (19.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  label: SYSTEM uuid: 16B4-896D
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 695.66 GiB fs: ntfs label: OS
  uuid: 4C46B66646B65106
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 850 MiB fs: ntfs label: RECOVERY
  uuid: 1268014C68012FD1
  ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 22 GiB fs: ntfs label: RESTORE
  uuid: BAF236B1F236722D
  ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 200 MiB fs: vfat label: MYASUS
  uuid: E436-A1D4
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Device-1: 3-2:2 info: IMC Networks USB2.0 HD UVC WebCam type: Video
  driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
  Device-2: 3-9:3 info: Shenzhen Goodix FingerPrint type: <vendor specific>
  driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
  chip-ID: 27c6:521d class-ID: ff00
  Device-3: 3-10:4 info: ASUSTek N-KEY Device type: Keyboard
  driver: asus,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 100mA
  chip-ID: 0b05:19b6 class-ID: 0301
  Device-4: 3-14:5 info: IMC Networks Wireless_Device type: Bluetooth
  driver: btusb interfaces: 3 rev: 2.1 speed: 480 Mb/s power: 100mA
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 20 Gb/s
  System Temperatures: cpu: 53.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 2200
  Processes: 331 Uptime: 4m wakeups: 4 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: pacman: 1216 lib: 331 flatpak: 0 Shell: Zsh
  v: 5.8 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.08
You are not alone. I’ve got the same issue. Laptop with optimus technology (nvidia/Intel), optimus-manager installed with bbswitch activated in optimus-manager.conf. Each time I reboot, I’ve got a black screen. I try the CTRL+ALT+DEL keys, nothing happens. I need to cut off the computer with the power button. I use Manjaro 21.1.6 KDE version.
Note: No problem with shutdown.
I absolsutely agree!
I also tried changing the optimus manager switching to bbswitch, but that also didn’t work!
bbswitch works for me (the nvidia card is cut off) when I’m on my session but when I reboot the computer it is bugged. I don’t know why.
