Manjaro 20.1 gnome - 14ARE05 Lenovo - Starting requires pkill x
hello fellas,
i am quite new to Linux and are running into a problem with my Lenovo 14ARE05.
I know this device had several problems due to its new release but AFAIK most of them are solved.
That’s why i decided to switch to Linux, cause i really dislike Windows :slight_smile:
My Problem:
after a cold start or a restart, i get to a black screen with a cursor("_") on the top left blinking. I have to switch to a second tty with CTRL+ALT+F2 and manually pkill x. Then, when i switch back to the first tty with CTRL+ALT+F1, the login screen loads and i can use the Laptop without any problems.
I really have no idea how to fix it.
inxi -F:
System:    Host: nb-manajarog Kernel: 5.9.0-1-MANJARO x86_64 bits: 64 Desktop: GNOME 3.36.6     Distro: Manjaro Linux
Machine:   Type: Laptop System: LENOVO product: 81YM v: IdeaPad 5 14ARE05 serial: MP1GZNCP
       Mobo: LENOVO model: LNVNB161216 v: No DPK serial: MP1GZNCP UEFI: LENOVO v: DTCN20WW(V1.06) date: 06/09/2020
Battery:   ID-1: BAT1 charge: 56.9 Wh condition: 58.4/56.5 Wh (103%)
CPU:       Topology: 8-Core model: AMD Ryzen 7 4800U with Radeon Graphics bits: 64 type: MT MCP L2 cache: 4096 KiB
       Speed: 1397 MHz min/max: 1400/1800 MHz Core speeds (MHz): 1: 1397 2: 1397 3: 1397 4: 1396 5: 1397 6: 1397 7: 1397
       8: 1397 9: 1397 10: 1396 11: 1397 12: 1397 13: 1397 14: 1397 15: 1397 16: 1397
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Renoir driver: amdgpu v: kernel
       Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
       Display: server: X.org 1.20.8 driver: amdgpu,ati unloaded: modesetting resolution: <xdpyinfo missing>
       OpenGL: renderer: AMD RENOIR (DRM 3.39.0 5.9.0-1-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.1.7
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel
       Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor driver: snd_rn_pci_acp3x
       Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio driver: snd_hda_intel
       Sound Server: ALSA v: k5.9.0-1-MANJARO
Network:   Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi
       IF: wlo1 state: up mac: c8:b2:9b:a0:55:e6
Drives:    Local Storage: total: 245.95 GiB used: 12.36 GiB (5.0%)
       ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFM256GDHTNI-87A0B size: 238.47 GiB
       ID-2: /dev/sda type: USB vendor: Generic model: Flash Disk size: 7.47 GiB
Partition: ID-1: / size: 233.43 GiB used: 12.07 GiB (5.2%) fs: ext4 dev: /dev/nvme0n1p2
Swap:      Alert: No Swap data was found.
Sensors:   System Temperatures: cpu: 48.8 C mobo: N/A gpu: amdgpu temp: 48 C
Info:      Processes: 387 Uptime: 17m Memory: 15.08 GiB used: 1.74 GiB (11.5%) Shell: Zsh inxi: 3.1.05
greets
linux59 is a dev version kernels ,
can you add linux version5.8
sudo mhwd-kernel -i linux58 linux58-headers
same problem with linux 5.8.6
here i did not have to pkill x, i simply switch to tty2 and switch back to tty1 and it loads x. i will try this on 5.9.1 aswell.
EDIT: yeah as i thought, there is no need to pkill x or anything else, i simply switch to TTY2, wait a second and switch back to TTY1 and the login screen appears.
Problem is solved with after updating to new kernel
inxi -b:
Host: nb-manajarog Kernel: 5.9.1-1-MANJARO x86_64 bits: 64
serial: <superuser/root required>
serial: <superuser/root required> UEFI: LENOVO v: DTCN20WW(V1.06)
date: 06/09/2020
ID-1: BAT1 charge: 54.9 Wh condition: 57.7/56.5 Wh (102%)
8-Core: AMD Ryzen 7 4800U with Radeon Graphics type: MT MCP
speed: 1397 MHz min/max: 1400/1800 MHz
Device-1: AMD Renoir driver: amdgpu v: kernel
Display: x11 server: X.org 1.20.9 driver: amdgpu,ati
unloaded: modesetting,radeon resolution:
OpenGL: renderer: AMD RENOIR (DRM 3.39.0 5.9.1-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.8
Local Storage: total: 238.47 GiB used: 14.07 GiB (5.9%)
Processes: 398 Uptime: 4h 52m Memory: 15.08 GiB used: 2.48 GiB (16.4%)
