Sound over Thunderbolt randomly becomes distorted
Hey! I’ve been running Manjaro on a ThinkPad X1 Extreme Gen2 for about a year and a half now, and it runs great. One thing I’ve started noticing though is that randomly, the sound out of my Thunderbolt dock (ThinkPad Thunderbolt 3 Workstation Dock Gen 2, gosh that’s a mouthful) will randomly become garbled and distorted. The only fix (besides rebooting) is to toggle what type of Audio Device profile it uses. Note, it only happens with my Thunderbolt dock – my internal speakers are unaffected.
Here’s a video showing what I’m talking about (unmute for sound): https://imgur.com/a/OhzPLSU
Thanks in advance for any help!
  1. Please read this:
    How to provide good information
    and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
:+1:
The profile for the dock is initially set to Digital stereo (S/PDIF) output
and audio changes when profile is switched to Analog Stereo Output
But what has me really puzzled is that there does not appear to be any digital S/PDIF connection available on this device
There only appears to be one analog audio jack for headphones, headset or microphone
And online data scans for this device only show an analog output (PCM) and microphone input
Lenovo ThinkPad Thunderbolt 3 Dock USB Audio
Card sysdefault:2 'USB'/'Lenovo ThinkPad Thunderbolt 3 Dock USB at usb-0000:08:00.0-2.1.1.2, full speed'
  Mixer name	: 'USB Mixer'
  Components	: 'USB17ef:3083'
  Controls      : 6
  Simple ctrls  : 3
Simple mixer control 'PCM',0
  Capabilities: pswitch pswitch-joined
  Playback channels: Mono
  Mono: Playback [on]
Simple mixer control 'Mic',0
  Capabilities: cvolume cvolume-joined cswitch cswitch-joined
  Capture channels: Mono
  Limits: Capture 0 - 30
  Mono: Capture 30 [100%] [0.00dB] [on]
Simple mixer control 'Auto Gain Control',0
  Mono: Playback [off]
There are no controls for IEC958 digital audio, so it appears that this dock does not support digital audio over the HDMI or Displayport sockets
If you are using headphones or speakers plugged in to the audio jack you should probably be using the profile Analog Stereo Output
Oh my goodness, I’m sorry – totally forgot to provide the output! Here it is:
  Kernel: 5.4.138-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=ed8ca4e9-2572-4296-8eef-13f1234f4093 rw sysrq_always_enabled=1
  apparmor=1 security=apparmor
  resume=UUID=0e2ca42e-8e55-4ee9-8dd0-f6af0ba2f1e0 udev.log_priority=3
  Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: LENOVO product: 20QVCTO1WW v: ThinkPad X1 Extreme 2nd
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: LENOVO model: 20QVCTO1WW v: SDK0J40697 WIN serial: <filter>
  UEFI: LENOVO v: N2OET44W (1.31 ) date: 05/07/2020
  ID-1: BAT0 charge: 70.6 Wh (100.0%) condition: 70.6/80.4 Wh (87.8%)
  volts: 17.2 min: 15.4 model: SMP 01YU911 type: Li-poly serial: <filter>
  status: Full cycles: 108
  RAM: total: 31.02 GiB used: 16.03 GiB (51.7%)
  Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
  microcode: EA cache: L2: 12 MiB bogomips: 62431
  Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
  xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Lenovo
  driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
  driver: nvidia v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:1f91 class-ID: 0300
  Device-3: Chicony Integrated Camera type: USB driver: usbfs bus-ID: 1-8:2
  chip-ID: 04f2:b67c class-ID: 0e02 serial: <filter>
  loaded: modesetting,nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1520x285mm (59.8x11.2")
  s-diag: 1546mm (60.9")
  Monitor-1: DP-1.1 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2")
  diag: 686mm (27")
  Monitor-2: DP-1.3 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2")
  diag: 686mm (27")
  Monitor-3: eDP-1-1 res: 1920x1080 hz: 60 dpi: 142
  size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
  OpenGL: renderer: NVIDIA GeForce GTX 1650 with Max-Q Design/PCIe/SSE2
  v: 4.6.0 NVIDIA 470.57.02 direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
  v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
  Device-2: Lenovo ThinkPad Thunderbolt 3 Dock USB Audio type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2.1.1.2:7
  chip-ID: 17ef:3083 class-ID: 0300 serial: <filter>
  Device-3: Antlion Audio Antlion Wireless Microphone type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2.3.4:11
  chip-ID: 2f96:0100 class-ID: 0300
  Sound Server-1: ALSA v: k5.4.138-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.33 running: no
  Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: 3.2.6-k
  port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 2000
  bus-ID: 52:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp82s0 state: up mac: <filter>
  Device-3: Lenovo ThinkPad TBT 3 Dock type: USB driver: cdc_ether
  bus-ID: 4-2.1.2:4 chip-ID: 17ef:3082 class-ID: 0a00 serial: <filter>
  IF: enp9s0u2u1u2c2 state: up speed: N/A duplex: N/A mac: <filter>
  IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
  IP v6: <filter> scope: link
  IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
  bus-ID: 1-14:4 chip-ID: 8087:0029 class-ID: e001
  Local Storage: total: 3.18 TiB used: 2.29 TiB (71.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
  lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD4
  size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  type: SSD serial: <filter> rev: 022 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate model: BUP Slim SL
  size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: N/A
  serial: <filter> rev: 0304 scheme: MBR
  ID-1: / raw-size: 897.1 GiB size: 882.02 GiB (98.32%)
  used: 429.51 GiB (48.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  label: / uuid: ed8ca4e9-2572-4296-8eef-13f1234f4093
  used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
  uuid: 1440-5CC7
  ID-3: /mnt/datadump raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
  used: 1.75 TiB (96.2%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17
  label: Data Dump uuid: 3218CA6518CA27A5
  ID-4: /mnt/vm-storage raw-size: 465.76 GiB size: 233.73 GiB (50.18%)
  used: 121.87 GiB (52.1%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
  label: vm-storage uuid: df165fe1-db94-4799-9448-745a87e7a1a0
  ID-1: swap-1 type: partition size: 34.12 GiB used: 1.5 MiB (0.0%)
  priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
  uuid: 0e2ca42e-8e55-4ee9-8dd0-f6af0ba2f1e0
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Device-1: 1-8:2 info: Chicony Integrated Camera type: Video driver: usbfs
  interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b67c
  Device-2: 1-9:3 info: Synaptics Prometheus MIS Touch Fingerprint Reader
  type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
  Device-3: 1-14:4 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
  class-ID: e001
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
  speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 3-2:2 info: Lenovo USB2.0 Hub ports: 5 rev: 2.1 speed: 480 Mb/s
  chip-ID: 17ef:3080 class-ID: 0900
  Hub-5: 3-2.1:3 info: Lenovo USB2.0 Hub ports: 5 rev: 2.1 speed: 480 Mb/s
  Hub-6: 3-2.1.1:5 info: Lenovo USB2.0 HUB ports: 2 rev: 2.0 speed: 480 Mb/s
  power: 100mA chip-ID: 17ef:3081 class-ID: 0900
  Device-1: 3-2.1.1.2:7 info: Lenovo ThinkPad Thunderbolt 3 Dock USB Audio
  type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
  rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 17ef:3083 class-ID: 0300
  serial: <filter>
  Device-2: 3-2.1.5:6 info: VIA Labs USB Billboard Device type: Billboard
  driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
  chip-ID: 2109:8818 class-ID: 1100 serial: <filter>
  Hub-7: 3-2.3:8 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  power: 100mA chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 3-2.3.1:9 info: MosArt USB 2.4G Keyboard type: Keyboard,Mouse
  power: 100mA chip-ID: 062a:38b3 class-ID: 0301
  Device-2: 3-2.3.2:10 info: Logitech G502 Mouse type: Mouse,HID
  power: 300mA chip-ID: 046d:c07d class-ID: 0300 serial: <filter>
  Device-3: 3-2.3.4:11 info: Antlion Audio Antlion Wireless Microphone
  type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 3
  rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 2f96:0100 class-ID: 0300
  Device-4: 3-2.5:4 info: VIA Labs USB Billboard Device type: Billboard
  Hub-8: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-9: 4-2:2 info: Lenovo USB3.1 Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  chip-ID: 17ef:307f class-ID: 0900
  Hub-10: 4-2.1:3 info: Lenovo USB3.1 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
  Device-1: 4-2.1.2:4 info: Lenovo ThinkPad TBT 3 Dock
  type: Ethernet Network,CDC-Data driver: cdc_ether interfaces: 2 rev: 3.0
  speed: 5 Gb/s power: 288mA chip-ID: 17ef:3082 class-ID: 0a00
  serial: <filter>
  Device-2: 4-2.1.4:5 info: Seagate RSS LLC Backup Plus Portable Drive
  type: Mass Storage driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s
  power: 144mA chip-ID: 0bc2:ab24 class-ID: 0806 serial: <filter>
  Hub-11: 4-2.3:6 info: Genesys Logic Hub ports: 4 rev: 3.0 speed: 5 Gb/s
  chip-ID: 05e3:0612 class-ID: 0900
  System Temperatures: cpu: 72.0 C mobo: 50.0 C gpu: nvidia temp: 50 C
  Fan Speeds (RPM): cpu: 3274 fan-2: 2956
  Processes: 361 Uptime: 5h 23m wakeups: 1 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 alt: 8 clang: 12.0.1 Packages:
  pacman: 1765 lib: 516 flatpak: 0 Shell: Bash v: 5.1.8 running-in: yakuake
  inxi: 3.3.06
IIRC, I actually get the distortion regardless of which profile it’s set to. It just goes away when I switch it, in either direction. But I’ll keep it on Analog for now and see if the distortion comes up!
Is there a compelling reason for you to be on kernel 5.4 LTS instead of 5.10 LTS?
If not: have you tried 5.10 LTS already?
:thinking:
There actually is. I had serious issues with WiFi on this machine on kernels higher than 5.7, and the Linux client for veeam backup doesn’t support kernels higher than 5.8. And of course, 5.7 wasn’t LTS and has since ceased development.
So for now, I’m stuck on 5.4. Once the veeam issue is fixed (they’re working on it), I’ll try out higher kernels than that.
In the meantime, I’ve had the audio profile set to Analog since yesterday and there are no issues so far. If it distorts again while set on this profile, I’ll temporarily try a new kernel to see if the issue recurs. :slight_smile:
Thanks for your help!
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
