【求助】manjaro 17.1 无法制作U盘启动
大家好:
我新下载的 manjaro 17.1 KDE 和 gnome 版本。验证了MD5值后,选择制作U盘启动,但每次都是无法检测到引导扇区,即使内容完全刻录进去,但也无法开机启动U盘。
更换过三个U盘,也更换了多个刻录ISO软件,都是同样的问题。
但是,使用 manjaro 17.0 KDE和 Gnome 版本,就能成功,在制作U盘启动过程中,也可以检测到引导扇区。
请问这是为什么?
补充一下:我用VMWare 尝试安装 manjaro 17.0.1 gnome ,可以进去grub,但也无法进去安装程序,点击后就一片漆黑了。
OP is saying he has no problem creating bootable Manjaro 17.0 KDE and Gnome.
But cannot boot usb install media 17.1 KDE and gnome (kde & gnome 17.1 is out? I thought only xfce). checksum is correct.
Somebody please help him as I do not usb boot. That’s why I write in English.
Thanks.
Same problem with this?
Tried ‘dd’ to make usb instead?
17.0.1 is different way of boot (uses grub). ‘dd’ should work.
As said, I do not use rufus and any other method of usb boots.
Thank you very much!
Xfce版本我还真没怎么用过,所以没有测试。
DD 命令 和 DD镜像模式,我也试过了,也还是无法引导。(17.0版本仍然可以)
非常感谢帮我翻译和求助。:grinning:
OP tried dd and still won’t work.
I have no idea why dd won’t work on 17.0.1 (and works on 17.0) and I doubt anyone here has any idea either (but some may have suggestions to try).
But sorry I cannot help further on this.
Oh… OP edited first post - He used VM to install.
Again, sorry, I do not have much experience on VM.
Anybody knows whether VM works on 17.01?
To OP (chery), ; can you try booting 17.01 not on VM?
(it works for me)
:blush::kissing_heart:
我的也出现这种情况 貌似是xfce的镜像有问题 17的mesa更新也有问题 一直没修复
我没有这个问题.
我帮不到.
更好你用英语写这里.
希望别人能帮忙.
保重.
我昨晚试了 dd 17.0.1 xfce 可以引导 以前在windows 下用poweriso 就不行
