If you install with pamac/yay, it would provide you an option to edit the PKGBUILD. Choose E option to EDIT. After change the fields shown below, press ctrl + x to exit the editor, and proceed with the installation.
Change the field: _disable_budgie=false
to: _disable_budgie=true
If you don´t do this an error will appear:
vala-panel-appmenu/meson.build:81:0: ERROR: Dependency “budgie-1.0” not found, tried pkgconfig and cmake
Change the field: arch=(‘i686’ ‘x86_64’)
to: arch=(‘i686’ ‘x86_64’ ‘aarch64’). Instead everything I could put arch=(‘any’)
- Dependencies installed: (ex: mutter, budgie-desktop, gnome-desktop, gnome-session, xorg-xwayland and etc)
OPTION 1:
$ sudo pamac build vala-panel-appmenu-xfce
- If you use pamac, after finish you have to uninstall manually the dependencies with:
$ sudo pamac remove -o
OPTION 2:
$ yay --editmenu -S vala-panel-appmenu-xfce
- If you use yay, after finish, yay will uninstall automatically the dependencies, if you chose this when asked.
OPTION 3:
Use the pamac GUI to edit the PKGBUILD.
After change the indicated field, press SAVE. At the next window, press APPLY.
- After finish, you have to uninstall manually the dependencies (Installed > orphans) or at terminal with:
Something usefull to is change AUR to let vala-panel-appmenu-xfce be installed easily too, without need to put the arch
