That might be worthwhile option to add? For example
- Boot without enabling the discrete graphics
In that case, the option will simply be a no-op. I also donāt see why it should not be possible to edit the GRUB menu when this happens (I doubt it).
Current draft:
How would you go about detecting a NVIDIA optimus setup using grub?
You nailed it so fast
See, thereās no easy way out except for what you have already āmockupedā above.
And thatās why I edited my post with another āmagicā option which is not so strict and blacklisting, but raises a chance for a successful boot/operation.
I donāt think thatās feasible, thatās why I suggested a separate boot option for it if we decide to go that way at some point (For example if nvidia becomes unfeasible to package)
It just must be clear that non-free selected by default is no option. We can offer it for sure as a selection, but a regular user which hits enter should always have free drivers pre-selected. Also when the timer times out.
I mean⦠I really donāt understand why, but if thatās what you wantā¦
The moment NVIDIA drivers are dropped, I will be out of here and probably go back to a Debian based distro. But again, thatās a very unlikely scenario.
That seems good to me ans is in accordance with what Philm said. Can you send a merge request?
1 minute ahead of you! https://gitlab.manjaro.org/artwork/branding/grub-theme/-/merge_requests/9
Tested on a new ISO build I made on an Nvidia Optimus laptop with a GTX 1660ti and an Intel iGPU
Is this really the case? That the kernel is removing support for GRUB? That would be surprising, did you read about this somewhere that you can share with everyone here?
The grub-theme-live-common package has not been updated yet, just FYI
Yes, everyone is busy. But new iso release is coming, so it will soon be. We are also in the process of redoing the theming for it.
EDIT: updated now
As well as grub. Every distro has its custom grub scripts, which are not a part of the bootloader itself.
That is not true.
Other points are valid, however one should remember that systemd-boot is made simple intentionally. It is just a minimalistic loader for UEFI systems, no more, no less.
And yep, Linux is not moving to it, thatās nonsense.
I think we might be talking about different things. Of course systemd-boot has always supported booting encrypted root. Last I checked, systemd-boot requires kernel and initcpio to reside on the efi partition. This means that /boot will necessarily be on unencrypted partition. Has this changed? If so Iām interested in hearing more.
Yes an no at the same time.
To boot, it needs those files that are necessary for that: kernel, initramfs. But these files could be either mirrored from encrypted boot or unified into a single image. To prevent tampering, such image and loader could be signed with Secure Boot certificate.
But there is very little of interest in /boot partition besides the kernel. Mirroring it from encrypted /boot partition seems to defeat the purpose of /boot encryption.
But, since encrypting that partition is not very productive in the first place, I conceed that this technicality counts
New user chipping in with an opinion.
Many people using Linux are using it for itās higher confidence in lack of spying given by open source, and few to none blobs even in the more mainstream versions of the kernel as is the case here.
The nonfree drivers I see are only an issue with nvidia cards, so it would be logical to only have nonfree by default on nvidia only! (through a hardware detection mechanism)
Otherwise manjaro is in the danger of becoming the shill that is ubuntuā¦
I know that mainline Linux kernel favours systemd also, and itās because of corporate backing and itās political, but I am sure rEFInd and OpenRC from Parabola will get a lot of traction in the near future.
Guys, kep it as open source as possible! Donāt cave in to political lobby!
