Making an encrypted BTRFS raid
I'm mostly confused about how to set this up right. I haven't done a system with raid.
I will have a system drive, shared with windows, and changing 3 hdd for manjaro only. I would like to make an even 4 but that can't happen for now. This leaves me with choosing raid 5 which from what I found is simple enough with BTRFS and could be changed later (I've made my mind on raid 5 for what I have, I see arguments about it).
After installing, how would I go about having the 3 encrypted drives raid 5 together for system boot? If set with the same encryption password as the system will it still ask for a password for the raid? For each drive? How is a raid like this added to fstab? Is expanding to 4 drives going to be too weird with the encryption?
Be careful with that. Arch wiki says:
Warning: Parity RAID (RAID 5/6) code has multiple serious data-loss bugs in it. See the Btrfs Wiki's RAID5/6 page and a bug report on linux-btrfs mailing list for more detailed information.
Why an encrypted RAID with 3 disks at all?
I would recommend to use LVM which has both a LUKS and a RAID configuration.
That's where I'm getting confused. Where is the difference for using LVM? I don't really know how it's used here.
To be fair, that wiki page is over a year old. I am leaning for raid 5 after seeing other people saying it's gotten better. From my understanding it isn't officially stated to work until way more verification is done, which takes a while.
This RAID5 issue is several years old. And it still exists:
https://news.ycombinator.com/item?id=22005823
And the kernel wiki still says RAID5/6 is "unstable":
https://btrfs.wiki.kernel.org/index.php/Status
Do what you want, but be cautious. If something happens to your data, you can not say you didn't know it.
