"Failed to start Load Kernel Modules" appeared after the last update
After today’s update I received this message at start. this is the first time I run into problems at the start, I will be glad of any help
[Failed] Failed to start Load Kernes Modules.
[Failed] Failed to mount Mount unit for core18, revision 1932.
[Failed] Failed to mount Mount unit for core18, revision 1944.
[Failed] Failed to mount Mount unit for snapd, revision 10492
[Failed] Failed to mount Mount unit for snapd, revision 10707
[Failed] Failed to mount Mount unit for spotify, revision 42
[Failed] Failed to mount Mount unit for spotify, revision 43
[Failed] Failed to mount /boot/efi
[DEPEND] Dependency failed for LocalFile Systems
After trying using chroot, I have this
how I solved the problem: uninstalled linux and installed windows
