I can change my resolution using xrandr
but where and what do I configure it to use the resolution at bootup?
I used xrandr --output HDMI2 --mode 1920x1080
to set the resolution.
Thank you. My settings are below:
inxi -FAZ --no-host
System: Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 Desktop: i3 4.18.2 Distro: Manjaro Linux
Machine: Type: Laptop Mobo: INTEL model: CRESCENTBAY serial: <superuser/root required> UEFI: American Megatrends v: 5.6.5
date: 08/29/2015
CPU: Topology: Dual Core model: Intel Core i7-4650U bits: 64 type: MT MCP L2 cache: 4096 KiB
Speed: 1696 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 1696 2: 1696 3: 1696 4: 1696
Graphics: Device-1: Intel Haswell-ULT Integrated Graphics driver: i915 v: kernel
Display: server: X.Org 1.20.8 driver: intel unloaded: modesetting s-res: 1920x1080
OpenGL: renderer: Mesa DRI Intel HD Graphics 5000 (HSW GT3) v: 4.5 Mesa 20.1.7
Audio: Device-1: Intel Haswell-ULT HD Audio driver: snd_hda_intel
Device-2: Intel 8 Series HD Audio driver: snd_hda_intel
Sound Server: ALSA v: k5.8.6-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: enp2s0 state: down mac: 00:e0:4c:68:86:74
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: enp3s0 state: down mac: 00:e0:4c:68:86:75
Device-3: Intel Centrino Advanced-N 6235 driver: iwlwifi
IF: wlp4s0 state: up mac: b4:b6:76:8c:99:66
Drives: Local Storage: total: 1.05 TiB used: 9.53 GiB (0.9%)
ID-1: /dev/sda vendor: Kingfast model: N/A size: 119.24 GiB
ID-2: /dev/sdb vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB
ID-3: /dev/sdc type: USB model: Mass Storage Device size: 7.40 GiB
ID-4: /dev/sdd type: USB vendor: Generic model: STORAGE size: 14.43 GiB
Partition: ID-1: / size: 1.04 GiB used: 14.5 MiB (1.4%) fs: btrfs dev: /dev/sda3
ID-2: /boot size: 487.9 MiB used: 59.1 MiB (12.1%) fs: ext4 dev: /dev/sda2
ID-3: /home size: 70.00 GiB used: 1.11 GiB (1.6%) fs: btrfs dev: /dev/sda8
ID-4: /opt size: 2.05 GiB used: 163.8 MiB (7.8%) fs: btrfs dev: /dev/sda6
ID-5: /usr size: 22.00 GiB used: 6.03 GiB (27.4%) fs: btrfs dev: /dev/sda4
ID-6: /var size: 12.65 GiB used: 647.8 MiB (5.0%) fs: btrfs dev: /dev/sda9
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 44.0 C mobo: N/A
Info: Processes: 345 Uptime: 1d 14h 38m Memory: 15.55 GiB used: 3.21 GiB (20.6%) Shell: Bash inxi: 3.1.05
