How do i make my panel(Dock ) transparent in kde ?
i have spend some times searching the internet but i couldnt find any working solutions
Find a transparent Plasma Style in the KDE store.
i did find one and then clicked apply and nothing happened.
i even tried restarting
i get this error when i try to search a plasma theme but then the themes do pop up
i could nt find the one @omano mentioned in the plasma themes
Network error 5: Operation canceled
is this something i should be worried
of?
Go to the page I linked, download the version 0.2 of this widget, and then right click your Panel, Add a Graphical Component, then on top click the button to get more component, click Install From File, and select the plasmoid file, then search for it in the Component list, and add it to your Panel, the button is visible in Panel edit mode.
//EDIT: when I install some, they work on my end, some with blur, semi transparent, or fully transparent. The widget above is to make any Panel fully transparent (on/off button).
A good way to make the panel 100% transparent in KDE Plasma
It’s using the Orchis theme, this will make it much easier, even the taskbar is totally transparent
T+ = See you later
…also make sure that compositor is on, in settings, monitor, compositor …
