Hello everyone. My laptop volume is a bit too low at the maximum volume attainable with the hotkeys, but acceptable with the maximum volume attainable with the system tray volume slider. I’m tired of having to leave full-screen to adjust the volume. Is there any way to make my hotkeys reach the extra volume that the slider can reach? I wouldn’t mind mapping new hotkeys for it if I need to. Thanks for any help.
System: Kernel: 5.10.41-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: Xfce 4.16.0 tk: Gtk 3.24.24
info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: LENOVO product: 20AN009CUS v: ThinkPad T440p serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: LENOVO model: 20AN009CUS v: 0B98401 PRO serial: <filter> UEFI: LENOVO v: GLETA1WW (2.55 ) date: 04/20/2020
Battery: ID-1: BAT0 charge: 45.6 Wh (100.0%) condition: 45.6/56.2 Wh (81.2%) volts: 12.4 min: 10.8 model: LGC 45N1147
type: Li-ion serial: <filter> status: Full
Memory: RAM: total: 15.52 GiB used: 2.7 GiB (17.4%)
Array-1: capacity: 16 GiB slots: 2 EC: None max-module-size: 8 GiB note: est.
Device-1: ChannelA-DIMM0 size: 8 GiB speed: 1600 MT/s type: DDR3 detail: synchronous bus-width: 64 bits
total: 64 bits manufacturer: 1324 part-no: N/A serial: N/A
Device-2: ChannelB-DIMM0 size: 8 GiB speed: 1600 MT/s type: DDR3 detail: synchronous bus-width: 64 bits
total: 64 bits manufacturer: 0000 part-no: N/A serial: N/A
CPU: Info: Quad Core model: Intel Core i7-4700MQ bits: 64 type: MT MCP arch: Haswell rev: 3 cache: L1: 64 KiB L2: 6 MiB
L3: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38324
Speed: 2392 MHz min/max: 800/2400 MHz volts: 0.8 V ext-clock: 100 MHz Core speeds (MHz): 1: 2392 2: 2392 3: 2394
4: 2394 5: 2394 6: 2394 7: 2394 8: 2395
Graphics: Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0416 class-ID: 0300
Device-2: NVIDIA GK208M [GeForce GT 730M] vendor: Lenovo driver: nvidia v: 465.31 bus-ID: 02:00.0
chip-ID: 10de:1290 class-ID: 0300
Device-3: Acer SunplusIT Integrated Camera type: USB driver: uvcvideo bus-ID: 2-12:8 chip-ID: 5986:0268
class-ID: 0e02
Display: server: X.Org 1.20.11 driver: loaded: modesetting,nvidia resolution: 1920x1080 s-dpi: 96
OpenGL: renderer: NVIDIA GeForce GT 730M/PCIe/SSE2 v: 4.6.0 NVIDIA 465.31 direct render: Yes
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Lenovo ThinkPad T440p driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo ThinkPad T440p driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Sound Server-1: ALSA v: k5.10.41-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Network: Device-1: Intel Ethernet I217-LM vendor: Lenovo ThinkPad T440p driver: e1000e v: kernel port: 4080 bus-ID: 00:19.0
chip-ID: 8086:153a class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel port: 3000 bus-ID: 04:00.0 chip-ID: 8086:08b2
class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-3: Qualcomm Atheros AR9271 802.11n type: USB driver: ath9k_htc bus-ID: 2-6:11 chip-ID: 0cf3:9271
class-ID: ff00 serial: <filter>
IF: wlp0s20u6 state: down mac: <filter>
Drives: Local Storage: total: 931.51 GiB used: 690.93 GiB (74.2%)
ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS721010A9E630 size: 931.51 GiB speed: 6.0 Gb/s rotation: 7200 rpm
serial: <filter> rev: A3U0 scheme: GPT
Partition: ID-1: / size: 31.25 GiB used: 24.59 GiB (78.7%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 98.4 MiB used: 422 KiB (0.4%) fs: vfat dev: /dev/sda1
ID-3: /home size: 789.8 GiB used: 666.34 GiB (84.4%) fs: ext4 dev: /dev/sda4
Swap: ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
Sensors: System Temperatures: cpu: 54.0 C mobo: 0.0 C gpu: nvidia temp: 50 C
Fan Speeds (RPM): cpu: 0
Info: Processes: 246 Uptime: 4h 04m wakeups: 2 Init: systemd v: 247 Compilers: gcc: 11.1.0 alt: 6 Packages: pacman: 1561
Shell: Bash (sudo) v: 5.1.8 running-in: terminator inxi: 3.3.04
