My (up to date, ~ 4 month old) Manjaro all settings is Hungarian (main language, number/date format, time zone etc.).
Hun. language packs installed for FireFox and Thunderbird.
Despite of this, all times when FireFox update done, it become English, I have to set it back to Hungarian manually.
My second problem is to FileZilla installed English and I can not set it to Hungarian (or other language).
I have a VirtualBox machine (also Manjaro) and an installed FileZilla with the same way (sudo pacman -S filezilla).
It is Hungarian from the first launch and I can change language!
I did not found other seeting than “Settings Manager → Locale settings and Language packs”
There is not possible to went somethimg wrong with my Manjaro?
Where and how can I it repair?
The first is very long list (more than 160 row, if you want, I will copy all here, Hungarian is in)
localectl list-locales
aa_DJ.UTF-8
hsb_DE.UTF-8
ht_HT.UTF-8
hu_HU.UTF-8
hy_AM.UTF-8
zu_ZA.UTF-8
localectl status
System Locale: LANG=hu_HU.UTF-8
VC Keymap: hu
X11 Layout: hu
My locale.gen contains two locale enabled, so it is good.
It is changed by Calamaris during the installation process.
I do not understand why you offer the link, what need to look?
I’d not touch either one of these.
The first one: /etc/mkinitcpio.conf.pacnew
is there because the syntax has changed - but the old syntax is still supported
and probably for quite long time
the difference is that the keywords used to be inside quotes
whereas now they are inside parentheses
like:
MODULES=“i915”
vs.
MODULES=(i915)
no need to tend to it right now
Even less need to address /etc/locale.gen right now.
Yours should be o.k.
although you seem to have enabled all of them, instead of just the few that you want/need.
grep -v ^# /etc/locale.gen
shows which lines are enabled (are not starting with #)
