The problem:
Currently using 3 monitors, when at the login screen they are all on and working, however immediately upon logging in my main display goes black. When looking at display settings the display appears to be disabled. However re-enabling in display settings doesn’t turn it back on, and when I logout it turns back on and I can see the login box on all 3 screens.
What I’ve tried:
sudo pacman -Syyu
I’ve looked on the forum and the only thing I found the solution someone was told was to essentially make a new user and to delete the old one.
Update:
I made a new user and logged in and all my screens work. Main user still having issue.
Kernel: 5.15.94-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=76f101d5-00bd-4350-8e5d-964e0107cd45 rw quiet
resume=UUID=eb16335d-10ca-4421-9f7a-b25db1afa515 udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: Z370-A PRO (MS-7B48) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 2.D3
date: 11/18/2021
RAM: total: 15.57 GiB used: 2.74 GiB (17.6%)
Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4700 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 88824
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: eVga.com. driver: nvidia
v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1b06 class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-11.3:5 chip-ID: 046d:085c
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 8959x1440 s-dpi: 105 s-size: 2165x348mm (85.24x13.70")
s-diag: 2193mm (86.33")
Monitor-1: DP-3 pos: primary,left res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
Monitor-2: DP-4 size-res: N/A modes: N/A
Monitor-3: HDMI-0 pos: right res: 1920x1080 hz: 60 dpi: 55
size: 880x490mm (34.65x19.29") diag: 1007mm (39.65") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce GTX 1080
Ti/PCIe/SSE2 direct-render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel bus-ID: 1-11.1.1.1:8 v: kernel bus-ID: 00:1f.3
chip-ID: 1b1c:0a14 chip-ID: 8086:a2f0 class-ID: 0300 class-ID: 0403
Device-2: NVIDIA GP102 HDMI Audio vendor: eVga.com. driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10ef class-ID: 0403
Device-3: Corsair VOID PRO Wireless Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-4: Logitech C922 Pro Stream Webcam type: USB
Device-5: Native Instruments Komplete Audio 6 type: USB
driver: snd-usb-audio bus-ID: 1-11.4:9 chip-ID: 17cc:1001 class-ID: fe01
serial: <filter>
Sound API: ALSA v: k5.15.94-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 4.55 TiB used: 32.36 GiB (0.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO with
Heatsink 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: 4B2QGXA7
temp: 53.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA200
type: HDD rpm: 7200 serial: <filter> rev: ABB0 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
type: SSD serial: <filter> rev: 3B6Q scheme: GPT
ID-1: / raw-size: 48.83 GiB size: 47.76 GiB (97.81%) used: 20.71 GiB (43.4%)
fs: ext4 dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: 76f101d5-00bd-4350-8e5d-964e0107cd45
used: 316 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: 5F78-1B42
ID-3: /home raw-size: 866.56 GiB size: 851.88 GiB (98.31%)
used: 11.65 GiB (1.4%) fs: ext4 dev: /dev/sdb4 maj-min: 8:20 label: N/A
uuid: 7f9c47dc-06ab-4ea2-9214-6cb03f7f15a3
ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: eb16335d-10ca-4421-9f7a-b25db1afa515
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: FA50-FB5D
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 1.82 TiB fs: ntfs label: N/A
uuid: 7E3654043653BBB9
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 509 MiB fs: ntfs label: N/A
uuid: DA78DB3A78DB145B
ID-5: /dev/sda1 maj-min: 8:1 size: 128 MiB fs: <superuser required>
ID-6: /dev/sda2 maj-min: 8:2 size: 1.82 TiB fs: ntfs label: Big Daddy
uuid: 08503AA4503A9880
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-8:2 info: Razer USA RZ03-0203 Gaming Keyboard [BlackWidow
Chroma V2] type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 1532:0221 class-ID: 0300
Hub-2: 1-11:3 info: Hitachi ports: 4 rev: 2.0 speed: 480 Mb/s
chip-ID: 045b:0209 class-ID: 0900
Hub-3: 1-11.1:4 info: Hitachi ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-4: 1-11.1.1:7 info: Hitachi ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-11.1.1.1:8 info: Corsair VOID PRO Wireless Gaming Headset
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 1b1c:0a14 class-ID: 0300
Device-2: 1-11.1.3:6 info: Corsair Gaming SCIMITAR PRO RGB Mouse
type: Mouse,HID driver: corsair,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 300mA chip-ID: 1b1c:1b3e class-ID: 0300 serial: <filter>
Device-3: 1-11.3:5 info: Logitech C922 Pro Stream Webcam type: Video,Audio
power: 500mA chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Device-4: 1-11.4:9 info: Native Instruments Komplete Audio 6 type: Audio
driver: snd-usb-audio interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 17cc:1001 class-ID: fe01 serial: <filter>
Hub-5: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 36.0 C mobo: N/A gpu: nvidia temp: 49 C
Processes: 280 Uptime: 21m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1256 libs: 324 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
