Dear manjaro user!
I was try to install may macbook pro 8.1 manjaro KDE. Install OK but my keyboard alway use like “shift” is ON. I can’t use “1234” because it alway show this “!@#$”. Pls help me to fix this error.
Dear manjaro user!
You should restart your device and then try again. I hope it will work for you. All the best!
How did you get your keyboard to work? I have the exact same macbook and the keyboard and touchpad do not work.
in grub you can still select the OS, but after that the keyboard will not accept anything else.
