hello everybody
I’m currently using an Asus VivoBook S14 with both Manjaro Openbox (with kernel 6.6.10-1) & Windows 11, that I occasionally use.
Today is the day I need Windows but I’ve realized that after switching on the laptop I’m not offered the choice any more and it just boots into Manjaro.
I’ve read that after the last major update others found the dual boot broken and fixed it with sudo grub-mkconfig
I’ve tried that but it hasn’t changed anything
I CAN still boot into windows: if I switch the boot priority in the Bios from Manjaro to Windows the laptop then boots into Windows. If there’s no other way I could still use this trick as I don’t need to use Windows that often but if possible I’d prefer to fix it.
Thanks
check your /etc/default/grub
Os prober and menu should be enabled, and then update with mkconfig
Summary
# GRUB boot loader configuration
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT=XXXXXXXXXXXXXXXXXXXXXXXX
GRUB_CMDLINE_LINUX=""
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'menu' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=menu
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
GRUB_DISABLE_OS_PROBER=false
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
thanks for the reply
This is what I see in my /etc/default/grub:
GRUB_DEFAULT=saved
GRUB_TIMEOUT=10
GRUB_TIMEOUT_STYLE=hidden
GRUB_CMDLINE_LINUX_DEFAULT="XXXXXXXXXXXXXXXXXXXXXXXX"
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_GFXMODE=auto
GRUB_THEME="/boot/grub/themes/pacbang/theme.txt"
Just an FYI, most newer BIOS EFI firmware have the ability select which OS to boot, either in the BIOS itself or by hitting the F key that opens your Boot menu. This can at least get you into Windows until you can fix your GRUB issue.
yes, thanks, I’ve already done that, I could even live with this work around if I can’t fix it
sorry Teo! I hadn’t realized you had attached all that
It seems me the main difference is in the line quoted… should I change that like yours? Or something else?
Thanks again
That is the only thing you should NOT change because it is specific to you, so i deleted/anonymized it.
Os prober is enabled, now unhide the menu adding
I also notice you use a different theme, maybe if you later removed it you should change to default. But unhide the menu first.
thanks I’ve anonymized mine too
done that, now how I do this part?
sudo update-grub
and reboot
hooray it worked, thank you VERY much
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
