Mabox Linux 17.02 - Manjaro re-spin with Openbox is ready
openbox
respin
#41
@napcok, thank you very much for an excellent Manjaro Respin!
I successfully installed the 17.02 iso and updated the install to the latest software on two separate hardware systems - an Dell Inspiron 660 desktop, and an HP-11 Streambook - with very little difficulty. I ran into one very minor snag during the update process which was quickly solved by searching the manjaro forums.
Keep up the great work on this excellent version of Manjaro!
#42
I’m still a bit hazy on the distinction between a window manager and a desktop environment. If Mabox is Openbox with a pre-installed suite of apps, doesn’t that make it a DE?
#43
The distinction becomes blurred at some point, but I’d say that including applications with a window manager is not enough to make it into a de if the combination doesn’t have other characteristics of de.
#44
A wonderful mix of two of my favoite distros. I’ve been using Manjaro since it’s inception and was a long time #! user. I really like the post install scripts for various software and the great theme options. Hope this one sticks around and keep up the great work!
#45
Any cool Mabox wallpapers out there? That green cube has design potential.
#46
You can find some not-very-cool Mabox wallpapers here -> https://pl.maboxlinux.org/forums/topic/tapety/
I will try to create some cool wallpapers for upcoming version.
#47
@napcok, I’ve been having problems updating packages from the mabox repo the last few weeks. Error message is that your repo keys are corrupted. I’ve followed the manjaro wiki instructions to clear and reinstall the keys many times (on 3 different days) but the mabox keys continually throw up the corruption message. I’ve also refreshed and reset pacman mirror list quite a few times but it doesn’t help. Because of that I didn’t update my mabox VM at all these last few weeks.
The other standard manjaro repos are fine and today I used pamac just to update the packages from those repos since only 3 updates came from the mabox repo.
Is that repo still in use? I noticed the pacman package is from the mabox repo and not from the standard manjaro repos. That means I haven’t updated pacman in mabox for some time.
#48
Been using Mabox for three days now, and having a few hassles:
  1. No Xorg updates will install due to conflicts
  2. Mabox doesn’t detect the volume and brightness F-keys like regular Manjaro does
  3. Menu > Settings > Pointing devices doesn’t open anything, and I assume that’s where tap-to-click and scrolling direction are changed.
  4. Tabs in Pale Moon often close on left click, regardless of where the pointer is on the tab. Also closes pinned tabs.
  5. Generally slow. Apps often take 20-30 seconds to open from first click
Any tips for improving performance?
#49
You can safely delete the offending file if you immediately run the full system update.
#50
So delete the conflicting file first? That won’t break Xorg and the display?
#51
@wongs you can try these wonderful pacman/keys/mirror fixing commands:
  1. delete pacman db:
sudo rm -r /var/lib/pacman/sync/core.db
  1. restore pacman db:
sudo pacman -Syy
If the issues are still with keys, do this:
sudo rm -r /etc/pacman.d/gnupg
sudo pacman -Sy gnupg archlinux-keyring manjaro-keyring
sudo pacman-key --init
sudo pacman-key --populate archlinux manjaro
sudo pacman-key --refresh-keys
sudo pacman -Sc
sudo pacman -Syu
If mirros are still a problem, at this moment it’s good to try again:
sudo pacman-mirrors -g
All of those should clean and restore correct files as databases, mirrors, keys.
#52
No - it won’t - I have done it twice - of course if you don’t plan to run a full system update immediatly then you should not delete it.
#53
This is some old bug. The file is listed as belonging to xorg but in reality it’s created by mhwd if I recall correctly and is no longer needed. You can safely remove the problematic file and then update system.
#54
Hmm. I’m getting libglx.so: Unable to trash file /lib/xorg/modules/extensions/libglx.so: Permission denied”.
Going through command line it says Xorg is not a directory.
#55
use
sudo rm -f  /lib/xorg/modules/extensions/libglx.so
#56
Success! Thank you so much.
And I learned a bit more CLI.
#57
Then it’s a different problem I had in mind. This one is described here and the fix is to delete with force, like suggested above:
#58
@michaldybczak, thanks for the input, but those were the commands I tried, with no success.
The developer @napcok contacted me via PM (very quick response, thanks!), and it’s through his message that I finally discovered the problem, which is that mabox OS has an additional keyring, ie the mabox-keyring.
The wiki instructions for keyrings were all for pure Manjaro community releases, so the only keyrings mentioned would be arch and manjaro keyrings. Once I realised this, I could adapt the keyring commands from Manjaro, with the added mabox-specific references:
sudo pacman -Sy gnupg archlinux-keyring manjaro-keyring mabox-keyring
and
sudo pacman-key --populate archlinux manjaro mabox
#59
Ah, didn’t know that. Thanks! :+1:
#60
Hi, when i try to install mabox i get “segmentation fault” when i click in next button at review changes page in calamares installer here is my “sudo calamares -d” output
[manjaro@mabox ~]$ sudo calamares -d
12:20:14 [1]: Calamares version: 2.4.5
Translation: Calamares: Using system locale: “en_US”
Translation: Qt: Using default locale, system locale one not found: “en_US”
12:20:15 [1]: Default font =====
Pixel size: -1
Point size: 9
Point sizeF: 9
Font family: “Sans Serif”
Metric height: 14
12:20:15 [1]: Font height: 14
12:20:15 [1]: Available languages: (“ar”, “ast”, “bg”, “ca”, “cs_CZ”, “da”, “de”, “el”, “en”, “en_GB”, “es_MX”, “es”, “eu”, “fr”, “hr”, “hu”, “id”, “is”, “it_IT”, “ja”, “lt”, “nl”, “pl”, “pt_BR”, “pt_PT”, “ro”, “ru”, “sk”, “sv”, “th”, “tr_TR”, “zh_CN”, “zh_TW”)
12:20:15 [1]: CalamaresApplication thread: 0xc9e1e0
12:20:15 [1]: Using log file: “/root/.cache/Calamares/Calamares/Calamares.log”
12:20:15 [1]: Using Calamares settings file at “/etc/calamares/settings.conf”
12:20:15 [1]: Using Calamares branding file at “/usr/share/calamares/branding/mabox/branding.desc”
12:20:15 [1]: WARNING: the selected branding component does not ship translations.
12:20:15 [1]: Loaded branding component “mabox”
12:20:15 [1]: STARTUP: initQmlPath, initSettings, initBranding done
12:20:15 [1]: STARTUP: initModuleManager: module init started
12:20:15 [1]: STARTUP: initModuleManager: all modules init done
12:20:16 [1]: STARTUP: initJobQueue done
12:20:16 [1]: Proposed window size: 1010 520
12:20:16 [1]: STARTUP: CalamaresWindow created; loadModules started
12:20:16 [1]: Initial locale “en_US”
12:20:16 [8]: Translation: Calamares: Using system locale: “en_US”
12:20:16 [8]: Translation: Qt: Using default locale, system locale one not found: “en_US”
12:20:16 [1]: ViewModule loading self for instance “welcome@welcome”
ViewModule at address 0xf4b330
Calamares::PluginFactory at address WelcomeViewStepFactory(0xd59ef0)
ViewStep at address WelcomeViewStep(0xf4b240)
12:20:16 [1]: WARNING: cannot acquire a list of available locales. The locale and localecfg modules will be broken as long as this system does not provide * a /usr/share/i18n/SUPPORTED file OR * a well-formed /etc/locale.gen OR * a complete pre-compiled locale-gen database which allows complete locale -a output.
12:20:16 [1]: ViewModule loading self for instance “locale@locale”
ViewModule at address 0xd8aea0
Calamares::PluginFactory at address LocaleViewStepFactory(0xfc6a20)
ViewStep at address LocaleViewStep(0xfb95b0)
12:20:17 [1]: ViewModule loading self for instance “keyboard@keyboard”
ViewModule at address 0xfd7b60
Calamares::PluginFactory at address KeyboardViewStepFactory(0xfd4270)
ViewStep at address KeyboardViewStep(0xfd7bb0)
12:20:18 [8]: Loaded backend plugin: “pmlibpartedbackendplugin”
12:20:18 [1]: ViewModule loading self for instance “partition@partition”
ViewModule at address 0x122bcc0
Calamares::PluginFactory at address PartitionViewStepFactory(0x1238ff0)
ViewStep at address PartitionViewStep(0x1247d30)
12:20:18 [1]: ViewModule loading self for instance “users@users”
ViewModule at address 0x126a8e0
Calamares::PluginFactory at address UsersViewStepFactory(0x126d8d0)
ViewStep at address UsersViewStep(0x1275560)
12:20:18 [1]: ViewModule loading self for instance “summary@summary”
ViewModule at address 0x1296d30
Calamares::PluginFactory at address SummaryViewStepFactory(0x12967d0)
ViewStep at address SummaryViewStep(0x12974c0)
12:20:18 [1]: Module “partition@partition” already loaded.
12:20:18 [1]: QML import paths: (“/usr/share/calamares/qml”, “/usr/bin”, “qrc:/qt-project.org/imports”, “/usr/lib/qt/qml”)
12:20:18 [1]: LAST VS IS EVS!
12:20:18 [1]: Module “locale@locale” already loaded.
12:20:18 [1]: Module “keyboard@keyboard” already loaded.
12:20:18 [1]: Module “users@users” already loaded.
12:20:18 [0]: void Calamares::Module::loadConfigurationFile(const QString&) bad module configuration format “/usr/share/calamares/modules/umount.conf”
12:20:18 [1]: ViewModule loading self for instance “finished@finished”
ViewModule at address 0x12df7f0
Calamares::PluginFactory at address FinishedViewStepFactory(0x12e1d50)
ViewStep at address FinishedViewStep(0x12d7c40)
12:20:18 [1]: STARTUP: loadModules for all modules done
12:20:18 [1]: STARTUP: Window now visible and ProgressTreeView populated
12:20:18 [1]: Need at least storage bytes: 8482560409
12:20:19 [1]: Need at least ram bytes: 1073741824
12:20:19 [1]: A battery exists, checking for mains power.
12:20:19 [1]: enoughStorage, enoughRam, hasPower, hasInternet, isRoot: true true true true true
No layout variant specified on the command line
Trailing -variant option ignored
12:20:19 [1]: xkbmap selection changed to: “us” – “”
12:20:20 [1]: GeoIP reporting “America/Mexico_City”
13:20:20 [1]: WARNING: cannot acquire a list of available locales. The locale and localecfg modules will be broken as long as this system does not provide * a /usr/share/i18n/SUPPORTED file OR * a well-formed /etc/locale.gen OR * a complete pre-compiled locale-gen database which allows complete locale -a output.
07:20:20 [1]: WARNING: cannot acquire a list of available locales. The locale and localecfg modules will be broken as long as this system does not provide * a /usr/share/i18n/SUPPORTED file OR * a well-formed /etc/locale.gen OR * a complete pre-compiled locale-gen database which allows complete locale -a output.
07:20:21 [0]: blkid: unknown file system type “” on “/dev/sda2”
07:20:25 [8]: getting smart status failed for “/dev/sdb” : Operation not supported
07:20:25 [1]: LIST OF DETECTED DEVICES:
node capacity name prettyName
07:20:25 [1]: “/dev/sda” 120031511040 “ATA WDC WD1200BEVS-6” “ATA WDC WD1200BEVS-6 – 111.79 GiB (/dev/sda)”
07:20:30 [1]: checking if “/dev/sda1” can be resized.
07:20:30 [1]: “/dev/sda1” seems like a good path
07:20:30 [1]: found Partition* for “/dev/sda1”
07:20:30 [1]: Required storage B: 11166914969 “(10GB)”
07:20:30 [1]: Available storage B: 3696107520 “(3GB)”
07:20:31 [1]: checking if “/dev/sda5” can be resized.
07:20:31 [1]: “/dev/sda5” seems like a good path
07:20:31 [1]: found Partition* for “/dev/sda5”
07:20:31 [1]: Required storage B: 11166914969 “(10GB)”
07:20:31 [1]: Available storage B: 31421153280 “(29GB)”
07:20:31 [1]: Partition “/dev/sda5” authorized for resize + autopartition install.
07:20:31 [1]: “Osprober lines, clean:\n/dev/sda1:Windows 7 (loader):Windows:chain\n/dev/sda5:Manjaro Linux (17.0.2):ManjaroLinux:linux”
07:20:31 [1]: Updating partitioning state widgets.
07:20:31 [0]: QCoreApplication::postEvent: Unexpected null receiver
07:20:31 [0]: QObject::setParent: Cannot set parent, new parent is in a different thread
07:20:31 [1]: Available storage B: 3145728 “(0GB)”
07:20:31 [1]: Required storage B: 9019431321 “(8GB)”
07:20:31 [1]: Available storage B: 104303951872 “(97GB)”
07:20:31 [1]: Partition “/dev/sda2” authorized for replace install.
07:20:31 [1]: Updating partitioning preview widgets.
07:20:37 [1]: Selected locale “es_MX”
07:20:37 [8]: Translation: Calamares: Using system locale: “es_MX”
07:20:37 [8]: Translation: Qt: Using default locale, system locale one not found: “es_MX”
07:20:37 [0]: Could not parse stylesheet of object 0x126f160
07:20:37 [0]: Could not parse stylesheet of object 0x1277df0
07:20:37 [0]: Could not parse stylesheet of object 0x127ab00
07:20:37 [0]: Could not parse stylesheet of object 0x127deb0
07:20:54 [0]: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1855, resource id: 4195075, major code: 40 (TranslateCoords), minor code: 0
07:21:05 [1]: xkbmap selection changed to: “us” – “”
07:21:05 [1]: xkbmap selection changed to: “us” – “altgr-intl”
07:21:09 [1]: Updating partitioning preview widgets.
07:21:09 [0]: QCoreApplication::postEvent: Unexpected null receiver
07:21:14 [1]: Choice applied: 4
07:21:33 [1]: old boundaries: 4096 73404415 73400320
07:21:33 [1]: new boundaries: 4096 73404415
07:21:33 [1]: dirty status: false
07:21:42 [1]: old boundaries: 73406464 77600767 4194304
07:21:42 [1]: new boundaries: 73406464 77600767
07:21:42 [1]: dirty status: false
07:21:57 [1]: old boundaries: 77602816 203720703 126117888
07:21:57 [1]: new boundaries: 77602816 203720703
07:21:57 [1]: dirty status: false
07:22:42 [0]: QLayout: Attempting to add QLayout “” to QWidget “”, which already has a layout
07:22:42 [0]: QObject::setParent: Cannot set parent, new parent is in a different thread
07:22:42 [1]: PartitionCodeModule has been asked for jobs. About to return: “Quitar todos los puntos de montaje temporales.\n<b>Instalar /dev/sda en una partición existente</b><br/>Podrás elegir que partición borrar.\nFormatear la partición /dev/sda5 (sistema de archivos: ext4, tamaño: 35840 MB) en ATA WDC WD1200BEVS-6\nFormatear la partición /dev/sda6 (sistema de archivos: linuxswap, tamaño: 2048 MB) en ATA WDC WD1200BEVS-6\nFijar información de la partición. ”
07:22:42 [1]: Gathering UUIDs for partitions that exist now.
07:22:42 [1]: QHash((“/dev/sda1”, “7CAC392EAC38E474”)(“/dev/sda2”, “”)(“/dev/sda5”, “3e247e32-0bab-434d-a9f9-9314fb5ba186”)(“/dev/sda6”, “a80f7bad-356c-42c8-9203-2968f390f2ae”)(“/dev/sda7”, “8466e81e-b036-4f48-a511-645f09ee8009”))
07:22:42 [1]: Writing to GlobalStorage[“partitions”]
07:22:42 [1]: “/dev/sda2” mtpoint: “” fs: QVariant(QString, “extended”) “”
07:22:42 [1]: “/dev/sda5” mtpoint: “/” fs: QVariant(QString, “ext4”) “3e247e32-0bab-434d-a9f9-9314fb5ba186”
07:22:42 [1]: “/dev/sda6” mtpoint: “” fs: QVariant(QString, “linuxswap”) “a80f7bad-356c-42c8-9203-2968f390f2ae”
07:22:42 [1]: “/dev/sda7” mtpoint: “/home” fs: QVariant(QString, “ext4”) “8466e81e-b036-4f48-a511-645f09ee8009”
07:22:42 [1]: “/dev/sda1” mtpoint: “” fs: QVariant(QString, “ntfs”) “7CAC392EAC38E474”
07:22:42 [8]: QVariant(QString, “”) “/dev/sda2” “” “extended”
07:22:42 [8]: QVariant(QString, “3e247e32-0bab-434d-a9f9-9314fb5ba186”) “/dev/sda5” “/” “ext4”
07:22:42 [8]: QVariant(QString, “a80f7bad-356c-42c8-9203-2968f390f2ae”) “/dev/sda6” “” “linuxswap”
07:22:42 [8]: QVariant(QString, “8466e81e-b036-4f48-a511-645f09ee8009”) “/dev/sda7” “/home” “ext4”
07:22:42 [8]: QVariant(QString, “7CAC392EAC38E474”) “/dev/sda1” “” “ntfs”
07:22:52 [1]: PartitionCodeModule has been asked for jobs. About to return: “Quitar todos los puntos de montaje temporales.\n<b>Instalar /dev/sda en una partición existente</b><br/>Podrás elegir que partición borrar.\nFormatear la partición /dev/sda5 (sistema de archivos: ext4, tamaño: 35840 MB) en ATA WDC WD1200BEVS-6\nFormatear la partición /dev/sda6 (sistema de archivos: linuxswap, tamaño: 2048 MB) en ATA WDC WD1200BEVS-6\nFijar información de la partición. ”
07:22:52 [0]: Starting job “Quitar todos los puntos de montaje temporales.”
07:22:52 [1]: Opened mtab. Lines:
07:22:52 [1]: “proc /proc proc rw,nosuid,nodev,noexec,relatime 0 0”
07:22:52 [1]: “sys /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0”
07:22:52 [1]: “dev /dev devtmpfs rw,nosuid,relatime,size=1531296k,nr_inodes=382824,mode=755 0 0”
07:22:52 [1]: “run /run tmpfs rw,nosuid,nodev,relatime,mode=755 0 0”
07:22:52 [1]: “overlay / overlay rw,relatime,lowerdir=/ro_branch/live-image:/ro_branch/mhwd-image:/ro_branch/openbox-image:/ro_branch/root-image,upperdir=/rw_branch/upper,workdir=/rw_branch/work 0 0”
07:22:52 [1]: “/dev/sdb1 /bootmnt iso9660 ro,noatime 0 0”
07:22:52 [1]: “securityfs /sys/kernel/security securityfs rw,nosuid,nodev,noexec,relatime 0 0”
07:22:52 [1]: “tmpfs /dev/shm tmpfs rw,nosuid,nodev 0 0”
07:22:52 [1]: “devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0”
07:22:52 [1]: “tmpfs /sys/fs/cgroup tmpfs ro,nosuid,nodev,noexec,mode=755 0 0”
07:22:52 [1]: “cgroup /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/usr/lib/systemd/systemd-cgroups-agent,name=systemd 0 0”
07:22:52 [1]: “pstore /sys/fs/pstore pstore rw,nosuid,nodev,noexec,relatime 0 0”
07:22:52 [1]: “cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0”
07:22:52 [1]: “cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct 0 0”
07:22:52 [1]: “cgroup /sys/fs/cgroup/devices cgroup rw,nosuid,nodev,noexec,relatime,devices 0 0”
07:22:52 [1]: “cgroup /sys/fs/cgroup/blkio cgroup rw,nosuid,nodev,noexec,relatime,blkio 0 0”
07:22:52 [1]: “cgroup /sys/fs/cgroup/cpuset cgroup rw,nosuid,nodev,noexec,relatime,cpuset 0 0”
07:22:52 [1]: “cgroup /sys/fs/cgroup/net_cls cgroup rw,nosuid,nodev,noexec,relatime,net_cls 0 0”
07:22:52 [1]: “cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0”
07:22:52 [1]: “cgroup /sys/fs/cgroup/freezer cgroup rw,nosuid,nodev,noexec,relatime,freezer 0 0”
07:22:52 [1]: “systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=31,pgrp=1,timeout=0,minproto=5,maxproto=5,direct 0 0”
07:22:52 [1]: “mqueue /dev/mqueue mqueue rw,relatime 0 0”
07:22:52 [1]: “hugetlbfs /dev/hugepages hugetlbfs rw,relatime 0 0”
07:22:52 [1]: “tmpfs /tmp tmpfs rw,nosuid,nodev 0 0”
07:22:52 [1]: “configfs /sys/kernel/config configfs rw,relatime 0 0”
07:22:52 [1]: “debugfs /sys/kernel/debug debugfs rw,relatime 0 0”
07:22:52 [1]: “tmpfs /etc/pacman.d/gnupg tmpfs rw,relatime,mode=755 0 0”
07:22:52 [1]: “tmpfs /run/user/1000 tmpfs rw,nosuid,nodev,relatime,size=308372k,mode=700,uid=1000,gid=1000 0 0”
07:22:52 [1]: “fusectl /sys/fs/fuse/connections fusectl rw,relatime 0 0”
07:22:52 [1]: “gvfsd-fuse /run/user/1000/gvfs fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000 0 0”
07:22:52 [1]: ClearTempMountsJob finished. Here’s what was done:
07:22:52 [0]: Starting job “<b>Instalar /dev/sda en una partición existente</b><br/>Podrás elegir que partición borrar.”
Segmentation fault
Thanks a lot for beautifull distro
