[LXQT] ISO rebuild (18.0.2)
community-edition
lxqt
#1
LXQT ISO rebuild
Rebuild against latest stable repo (2019-02-18T23:00:00Z) .
dl-button
Full ISO
direct | sig | sha1 | sha256
Minimal ISO
To keep the releases apart I am using yywwd as identifier. That is the year, week of year, day of week.
So 19072 is created on day 2 of week 7 of year 2019.
$ echo $(date +%y%U%w)
19072
#4
Nice, I had wondering how to install LXQT for my old netbook. But there is one problem. I don’t know if it’s a bug or what, but on live preview keyboard doesn’t function normal. Lang is English US and you don’t get correct results when you type. e.g: M is 0, 0 is /, ‘’ is K etc. So it is unusable, can type my wifi pass because I need to find where are all keys I need :frowning:
#5
Sounds like your numlock is on?
You can probably switch it by using Fn with your NumLock.
Keys activated using Fn is usually marked with blue.
#6
Brilliant, would be even better if you could upload a torrent or metalink. Cheers.
So what’s the difference between theses and the 18.05 by the community?
#7
Yeah that was the problem. Thank you :slight_smile:
#8
The original torrent service is down and I have no information if a new torrent service is up.
#9
No bother, is this the same as the 18.05 beta? Or this is more “official” in some ways.
#10
There is no such release.
The next iteration is 18.0.3 and it will be announced at any moment now.
#11
Why still that same wallpaper :sweat_smile:
#12
Also previous one was made by fhdk in Manjaro community
18.05 was using testing branch
Because is a rebuild as title says
#13
However there is plenty of solid changes that I noticed on the first boot, very well done indeed.
No more octopussy!
#14
Want a minimal GNOME and XFCE build pls!
#15
use manjaro architect
as minimal are not functional.
for regular use.
#16
What you mean by not functional?
#17
Both the 18.03 regular and minimal iso are the same? I assumed that as they are both of the same size.
#18
There should be differences in size - I might have made an error.
#19
So I have to download another iso or I can just update from 18.02?
Also, I tried installing the Deepin and Cinnamon and they both hang while installing.
#20
You can do with 18.02 - it was build just before yesterdays stable update.
And I will upload new images of the 18.0.3 (lxqt)
#21
Cheers, you might want to have a look at Deepin and Cinnamon too. Both 18.02 regular and minimal LXQt installs fine, but not for all regular/minimal Cinnamon and Deepin.
#22
That would be a task for the relevant maintainer. I only maintain the LXDE, LXQT and Openbox Editions.
