Tribler chrashes and is not useable. Usually when I try to click on something.
I have done a series of pip installs suggested from AUR (en) - tribler, for it to even start.
From terminal:
QBackingStore::endPaint() called with active painter; did you forget to destroy it or call QPainter::end() on it?
QPaintDevice: Cannot destroy paint device that is being painted
/usr/bin/tribler: linje 38: 20213 Minnesegmentsfeil
I found an issue in Tribler. What should I do to report it?
We take bug reports very seriously and try to investigate each of them. When Tribler encounters a crash, you will be prompted with a dialog that allows you to send additional information to us. This helps us with debugging and fixing the issue. If you have a suggestion for us or another problem, you can either create a post in our forums or create an issue on Github.
