[LxDE] 17.1.12.1 ISO rebuild (update)
lxde
community-edition
iso
#1
LxDE 17.1.12.1 stable ISO (update)
Download from OSDN
full edition:
direct | sig | sha1 | sha256 | torrent
minimal-edition:
#4
I’ve been running Manjaro 4.14.65 x86_64 GNU on a Dell Latitude D630 with no issues for about a year now. As long as my battery holds up I have no reason to change my daily driver, kudo’s to all you developers :slight_smile:
#5
'LLo,
If you like like (as me) light & nervous distro that start, run & stop like a plane, try this one !
Two minor things so far (in VM); gksu depreciated (PCManFM as root) & a strange terminal font
Otherwise, f…g great job ! :small_airplane:
Ps: Firefox a bit homemade OOTB would be not bad too :wink:
#6
You are right - which is why gksu is a symlink to gksu-polkit :slight_smile:
That makes everything work as before :slight_smile:
#7
@fhdk
Congratulations, the latest stable build is a fine piece of work. Thanks a lot. Very stable.
I like Gnome and LXDE both, though it sounds a little bit strange. Gnome is very innovative, and LXDE is very functional, traditional of course, and a nice way to make low end hardware or older machines flying again.
I have tested the LXQT spin as well. In my point of view the LXDE version is more intuitive, but that is just my point of view.
#8
HI,
ISO images are brokem, lightdm not start and boot stops after it, tried few times.
closed #9
