System: Kernel: 5.10.49-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: GNOME 40.3
Machine: Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <filter>
UEFI-[Legacy]: LENOVO v: EUCN19WW date: 05/12/2020
Battery: ID-1: BAT0 charge: 51.5 Wh (99.0%) condition: 52.0/60.0 Wh (86.7%) volts: 17.1
min: 15.4 model: Celxpert L19C4PC0 status: Unknown
CPU: Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 rev: 1 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 92662
Speed: 3909 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz): 1: 3909
2: 4144 3: 3898 4: 4097 5: 1866 6: 1476 7: 2273 8: 2330 9: 4280 10: 4292 11: 1904
12: 1905 13: 1904 14: 1907 15: 1890 16: 1517
Graphics: Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo driver: nvidia
v: 470.42.01 bus-ID: 01:00.0
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 05:00.0
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:2
Display: x11 server: X.org 1.20.11 driver: loaded: amdgpu,nvidia
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.49-1-MANJARO LLVM 12.0.0)
v: 4.6 Mesa 21.1.4 direct render: Yes
Audio: Device-1: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo driver: N/A
bus-ID: 05:00.5
Device-2: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 05:00.6
Sound Server-1: ALSA v: k5.10.49-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.31 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo
driver: r8169 v: kernel port: 2000 bus-ID: 03:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 2000 bus-ID: 04:00.0
IF: wlp4s0 state: down mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:3
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Drives: Local Storage: total: 476.94 GiB used: 142.72 GiB (29.9%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L2 size: 476.94 GiB
temp: 35.9 C
Partition: ID-1: / size: 459.79 GiB used: 142.6 GiB (31.0%) fs: ext4 dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 8.8 GiB used: 127.5 MiB (1.4%) dev: /dev/nvme0n1p2
Sensors: System Temperatures: cpu: 51.8 C mobo: N/A gpu: amdgpu temp: 38.0 C
Info: Processes: 378 Uptime: 7h 24m Memory: 15.07 GiB used: 5.49 GiB (36.4%) Init: systemd
Compilers: gcc: 11.1.0 Packages: 1498 Client: shell wrapper v: 5.1.8-release
inxi: 3.3.05
When I go to overview mode it just shows this screen but I have applications open. Anybody know how to fix this?
