Hallo Nachlese,
die zusätzliche Verkabelung ist vorgenommen, die gelockte HD steht bereit.
Habe es nicht lange ausgehalten und komme dank Deinem Angebot auf Dich zurück - vorausgesetzt es ist noch ‘aktuell’. Hier die erste LW Abfrage:
[miro@i7c4 ~]$ sudo hdparm -I /dev/sdb
/dev/sdb:
ATA device, with non-removable media
Model Number: WDC WD15EARS-00Z5B1
Serial Number: WD-WMAVU1588304
Firmware Revision: 80.00A80
Transport: Serial, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6
Standards:
Supported: 8 7 6 5
Likely used: 8
Configuration:
Logical max current
cylinders 16383 16383
heads 16 16
sectors/track 63 63
CHS current addressable sectors: 16514064
LBA user addressable sectors: 268435455
LBA48 user addressable sectors: 2930277168
Logical/Physical Sector size: 512 bytes
device size with M = 1024*1024: 1430799 MBytes
device size with M = 1000*1000: 1500301 MBytes (1500 GB)
cache/buffer size = unknown
Capabilities:
LBA, IORDY(can be disabled)
Queue depth: 32
Standby timer values: spec'd by Standard, with device specific minimum
R/W multiple sector transfer: Max = 16 Current = 16
Recommended acoustic management value: 128, current value: 128
DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6
Cycle time: min=120ns recommended=120ns
PIO: pio0 pio1 pio2 pio3 pio4
Cycle time: no flow control=120ns IORDY flow control=120ns
Commands/features:
Enabled Supported:
SMART feature set
* Security Mode feature set
* Power Management feature set
* Write cache
* Look-ahead
* Host Protected Area feature set
* WRITE_BUFFER command
* READ_BUFFER command
* NOP cmd
* DOWNLOAD_MICROCODE
Power-Up In Standby feature set
* SET_FEATURES required to spinup after power up
SET_MAX security extension
* Automatic Acoustic Management feature set
* 48-bit Address feature set
* Device Configuration Overlay feature set
* Mandatory FLUSH_CACHE
* FLUSH_CACHE_EXT
* SMART error logging
* SMART self-test
* General Purpose Logging feature set
* 64-bit World wide name
* {READ,WRITE}_DMA_EXT_GPL commands
* Segmented DOWNLOAD_MICROCODE
* Gen1 signaling speed (1.5Gb/s)
* Gen2 signaling speed (3.0Gb/s)
* Native Command Queueing (NCQ)
* Host-initiated interface power management
* Phy event counters
* NCQ priority information
* DMA Setup Auto-Activate optimization
* Software settings preservation
* SMART Command Transport (SCT) feature set
* SCT Features Control (AC4)
* SCT Data Tables (AC5)
unknown 206[12] (vendor specific)
unknown 206[13] (vendor specific)
Security:
Master password revision code = 65534
supported
enabled
locked
not frozen
not expired: security count
supported: enhanced erase
Security level high
336min for SECURITY ERASE UNIT. 336min for ENHANCED SECURITY ERASE UNIT.
Logical Unit WWN Device Identifier: 50014ee0ac954cf0
NAA : 5
IEEE OUI : 0014ee
Unique ID : 0ac954cf0
Checksum: correct
[miro@i7c4 ~]$
