On my sister’s laptop asus vivibook touchpad freezes randomly from time to time. This is a serious issue and I red somewhere that installing synaptics drivers helped.
So I installed xf86-input-synaptics package and restarted the system. However, the libinput packages are still there. My question is, which driver is used? My guess is that with libinput, it takes precedence and I need to uninstall it to check if synaptics helped. Or maybe I need to set it somewhere in the configs?
It could be that you need to remove
or move aside for testing
the present touchpad config /etc/X11/xorg.conf.d/30-touchpad.conf
not sure - because the default installed by this package /etc/X11/xorg.conf.d/70-synaptics.conf
will probably override (because of the bigger number) that original one
After installing xf86-input-synaptics, a default configuration file is located at /usr/share/X11/xorg.conf.d/70-synaptics.conf. Users can copy this file to /etc/X11/xorg.conf.d/ and edit it to configure the various driver options available.
Thanks. Will try to do that next week, because now I’m on vacation and don’t have the mouse, so if I made the touchpad inaccessible by any chance, it would be hard to fix it.
